ECLB40W-110S33
ECLB40W-110S33
    CINCON
    DIP6 模块
    隔离模块 直流转换器 1 输出 3.3V 10A 43V - 160V 输入
ECLB40W-110S33 数据手册
V15 ECLB40W SERIES 40 WATT 4:1 INPUT DC-DC CONVERTERS ︳ FEATURES * 40W Isolated Output * Efficiency to 91% * 2.05’’x1.2x0.4’’ Six-Sided Shield Metal Case * 4:1 Input Range * Regulated Outputs * Fixed Switching Frequency * Low No Load Power Consumption * Input Under Voltage Protection * Over Current Protection * Remote On/Off * Continuous Short Circuit Protection * No Tantalum Capacitor Inside * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE ECLB40W-24S33 9-36 VDC ECLB40W-24S05 OUTPUT CURRENT INPUT CURRENT % EFF. MIN. MAX. NO LOAD 3.3 VDC 0 mA 10000 mA 8 mA 1528 mA 88.5 9-36 VDC 5 VDC 0 mA 8000 mA 8 mA 1842 mA 89.5 90.5 8000µF ECLB40W-24S12 9-36 VDC 12 VDC 0 mA 3333 mA 10 mA 1832 mA 90.5 3300µF ECLB40W-24S15 9-36 VDC 15 VDC 0 mA 2666 mA 10 mA 1842 mA 90.5 90.5 2700µF ECLB40W-24D12 9-36 VDC ±12 VDC 0 mA ±1667 mA 10 mA 1873 mA 89.5 89 1650µF ECLB40W-24D15 9-36 VDC ±15 VDC 0 mA ±1333 mA 10 mA 1862 mA 90 89.5 1350µF ECLB40W-48S33 18-75 VDC 3.3 VDC 0 mA 10000 mA 6 mA 764 mA 89 90 10000µF ECLB40W-48S05 18-75 VDC 5 VDC 0 mA 8000 mA 6 mA 921 mA 90 90.5 8000µF ECLB40W-48S12 18-75 VDC 12 VDC 0 mA 3333 mA 8 mA 921 mA 91.5 90.5 3300µF ECLB40W-48S15 18-75 VDC 15 VDC 0 mA 2666 mA 8 mA 921 mA 91 90.5 2700µF ECLB40W-48D12 18-75 VDC ±12 VDC 0 mA ±1667 mA 8 mA 932 mA 90 89.5 1650µF ECLB40W-48D15 18-75 VDC ±15 VDC 0 mA ±1333 mA 8 mA 926 mA 90.5 90 1350µF NOTE: 1. Nominal Input Voltage 24 or 48 VDC 2. Measured at Nominal Input Voltage 3. Measured at 12VDC for 24Vin, 24VDC for 48Vin 1 FULL LOAD (3) CAPACITOR (2) LOAD MAX. 90 91 10000µF V15 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....……………..............…. 24VDC ................ 9 – 36VDC 48VDC ….……. 18 – 75VDC Input Surge Voltage (100ms max.) ………….. 24VDC ..…...... 50VDC max. 48VDC ……... 100VDC max. Under Voltage Lockout …………... 24Vin power up .……..……. 8.5VDC typ. 24Vin power down ….…….. 8.0VDC typ. 48Vin power up ….….....….. 17VDC typ. 48Vin power down ……....... 16VDC typ. Input Filter ……………………………………..……….……………. PI Type Remote On/Off Control (note3) Efficiency ............................................………..………............ See Table Isolation Voltage ................... Input/Output ....……..….. 1500VDC min. Input/Case, Output/Case ….. 1000VDC min. Isolation Resistance …..................…….………….………. 109 ohm min. Isolation Capacitance ………. Input/Output …....……..…… 1500pF typ. Input/Case …..……………. 1000pF typ. Output/Case ……........…… 1000pF typ. Switching Frequency ...............................……...................... 300KHz typ. EMI/RFI ………………………………….…. Six-Sided Continuous Shield OUTPUT SPECIFICATIONS: De-rating, Above 60℃ ……………..…. Linearly to Zero Power at +105℃ Voltage Accuracy ………………....………..……….......……...…… ±1.5% max. Voltage Balance (Dual) …….…..…………………………….…….…. ±1% max. Transient Response: 75% - 100% Step Load Change Error Band ……..… ±5% Vout nominal, Recovery Time ………….. 3.5VDC to 75VDC or open circuit Module off ……………..………………….…………. 0 to
ECLB40W-110S33 价格&库存
很抱歉,暂时无法提供与“ECLB40W-110S33”相匹配的价格&库存,您可以联系我们找货
