KL816M-A
KL816M-A
    KINGLIGHT(晶台)
    DIP-4
    晶体管光耦(DC),电流传输比80~160%,正向电压1.2V,反向电流10uA,Min击穿电压80V,Max暗电流100nA,隔离电压5000V,总消耗功率200mW,上升时间4us,下降时间3us...
KL816M-A 数据手册
KL816 Datasheet KL816 PHOTO TRANSISTOR DIP4 晶体管光耦 *本文档中包含的信息反映了具有代表性的使用场景,仅供技术参考。 The information contained in this document reflects representative usage scenarios and is intended for technical reference only. *本文档中提到的产品型号和规格如有更改或改进,恕不另行通知。在生产使用之前,客户应参考产品规格书的最新数据表。 Product models and specifications mentioned in this document are subject to change or improvement without notice. Customers should refer to the latest data sheets in the product specifications prior to production use. *在使用本文档中引用的产品时,请确保产品在数据手册中规定的环境和电气限制范围内运行。如果客户使用超过指定的限制,晶台将不会对任何后续问 题负责。 When using the products referenced in this document, ensure that the products are operated within the environmental and electrical limits specified in the data sheet. If the customer uses the product beyond the specified limits, Kinglight will not be responsible for any subsequent problems. *本文档中的信息适用于电子元器件应用中的典型用法。如有任何特殊用途,请向晶台咨询,以获得进一步的帮助。 The information in this document applies to typical use in electronic component applications. For special applications, please contact Kinglight for further assistance. *未经晶台允许,不得复制或转载本文件的内容和信息。对于最新的信息,请参考官方网站 Http://www.kinglight-OC.com。 The contents and information in this document may not be copied or reproduced without the permission of Kinglight. For the latest information, please visit the official website Http://www.kinglight-OC.com. KL816 Datasheet 1. 产品特点 Product features • 电流转换率(Current transfer ratio) CTR: 50~600% at IF =5mA, VCE =5V • 输入与输出高隔离电压(Viso=5000 V rms) High isolation voltage between inputs and output (Viso=5000 V rms) • tr/tf响应时间(在VCE=2V时,IC=2mA,RL=100Ω, tr Typ.4us、tf Typ.3us) Response time(tr Typ.4µs、tf Typ.3us at VCE = 2V, IC = 2mA, RL = 100Ω ) • 工作温度可达+110℃ Operating temperature up to +110°C • 4PIN引脚封装模式 4PIN DIP encapsulation mode • 无Pb且符合ROHS标准 Pb free and RoHS compliant • 静电放电:人体模式8000V、机器模式2000V ESD pass HBM 8000V/MM2000V • 安全审批 Safety approval CQC认证已批准(编号:CQC23001407997) CQC approved (No. CQC23001407997) UL认证已批准 (编号:UL-CA-2340753-0) UL approved (No: UL-CA-2340753-0 ) 2. 产品描述 Product Description • KL816光耦合器由一块砷化镓发射器和一块NPN晶体管组成 KL816 photo coupler consist of one piece of GaAs emitter and one piece of NPN • 它们采用4引脚DIP封装, 并提供宽引线间距和SMD选项 Packaged in a 4-pin DIP package and available in wide-lead spacing and SMD option 3. 产品应用 Product Applications • 电流表、计算机 Ammeter、Computer • 开关电源 Switching power supply • 仪器应用、测量仪器 Instrumental application、measuring instruments • 家用电器, 如风扇加热器等 Home appliances, such as fan heaters, etc. • 电信设备 Telecommunication equipments • 复印机、自动化设备 Copiers, automation equipment 4. 功能图 Functional Diagram 1 4 引脚配置 Pin Configuration 1. 阳极Anode 2. 阴极Cathode 2 Http://www.kinglight-OC.com 3 3. 发射极Emitter 4. 集电极Collector 第 2 页 共 17 页 Rev 1.0 KL816 Datasheet 5. 光电特性 Electrical-Optical characteristics • 最大限度额定值(温度=25ºC) Absolute Maximum Ratings(Ta=25℃) 参数 符号 额定值 单位 Parameter Symbol Rated Value Unit IF 60 mA IFP 1 A 反向电压 Reverse voltage VR 6 V 输入功率 Input Power PD 100 mW IC 50 mA VCEO 80 V VECO 6 V PC 150 mW 总消耗功率 Total Consume Power PTOT 200 mW 隔离电压 ( 1* )Isolation Voltage Viso 5000 Vrms 工作温度 Operating temperature TOPR -55 to +110 ℃ 储存温度 Storage temperature TSTG -55 to +125 ℃ 焊接温度 ( 2* ) Soldering temperature TSOL 260 ℃ 正向电流 Forward current 峰值正向电流(100us脉冲,100Hz频率) Peak forward 输入 Input current (100us pulse,100Hz frequency) 集电极电流 Collector current 输出 Output 集电极与发射极间电压 Collector and emitter Voltage 发射极与集电极间电压 Emitter and Collector Voltage 输出功率 Output Power 附注(Notes): 1* 交流电源1分钟内, 相对湿度40~60%环境下, 隔离电压测试方法, 1&2脚短接在一起, 3&4脚短接在一起 AC for 1 minute, 40~60%RH in this test, Pin 1,2 are shorted together, and3,4 are shorted together 2* 焊接时间为10秒 Soldering time is 10 seconds Http://www.kinglight-OC.com 第 3 页 共 17 页 Rev 1.0 KL816 Datasheet 6. 电气特性(Ta=25℃,除非另有规定) Electrical Characteristics(Ta=25℃ unless specified otherwise) 参数 符号 最小值 规格值 最大值 单位 条件 Parameter Symbol Min. Typ. Max. Unit Condition VF - 1.2 1.4 V IF=20mA IR - - 10 µA VR=4V Cin - 30 250 pF V=0, f=1kHz ICEO - - 100 nA VCEO 80 - - V VECO 6 - - V VCE(sat) - 0.1 0.2 V CTR 50 - 600 % IC 2.5 - 30 mA RISO 5×1010 1×1012 - Ω Cf - 0.6 1.0 pF 正向电压 Forward voltage 输入 In put 反向电流 Reverse current 输入电容 Input capacitance 集电极与发射极间暗电流 Collector-Emitter dark current 输出 Out put 集电极与发射极间击穿电压 Collector-Emitter breakdown voltage 发射极与集电极间击穿电压 Emitter-Collector breakdown voltage 集电极与发射极间饱和电压 Collector-Emitter saturation voltage 电流传输比 Current transfer ratio(1*) 集电极电流 Collector Current 传输特性 Transfer Characteristics 隔离电阻 Isolation resistance 浮动电容 Floating capacitance 截止频率 Cut-off frequency 上升时间 Rise time 下降时间 Fall time VCE=20V IF =0mA IC=0.1mA IF=0mA IE=0.1mA IF=0mA IF=20mA IC=1mA IF=5mA VCE=5V IF=5mA VCE=5V VIO=500Vdc 40~60% R.H. VIO=0, f=1MHz VCE=5V, fc - 80 - kHz IC=2mA RL=100, -3dB tr - 4 18 µs VCE=2V, IC=2mA, tf - 3 18 µs RL=100Ω 1* 当前转换比率=IC/IF*100%, CTR公差:±3% Current Conversion Ratio = IC / IF × 100% , CTR Tolerance:±3%. Http://www.kinglight-OC.com 第 4 页 共 17 页 Rev 1.0 KL816 Datasheet • 传输特性等级表(Ta=25℃, 除非另有规定) Transfer Characteristics level table (Ta=25℃ unless specified otherwise) 参数 符号 最小值 规格值 最大值 单位 条件 Parameter Symbol Min. Typ.* Max. Unit Condition KL816 50 - 600 KL816A 80 - 160 KL816B 130 - 260 200 - 400 KL816D 300 - 600 电流传输比 KL816X 100 - 200 Current KL816Y 150 - 300 Transferratio KL816I 63 - 125 KL816J 100 - 200 KL816K 160 - 320 22 - - KL816J 34 - - KL816K 56 - - KL816C KL816I Http://www.kinglight-OC.com CTR CTR 第 5 页 共 17 页 % IF=5mA VCE=5V IF=10mA VCE=5V % IF=1mA VCE=5V Rev 1.0 KL816 Datasheet 7. 可靠性试验 Reliability Test 序号 试验项目 NO. Test Items 温度循环 1 TC 高温操作寿命 2 HTOL 高温反向偏压 3 HTRB 温湿度反向偏 4 压寿命试验 H3TRB 5 允收水准 Test conditions Test process Qty.(pcs) LTPD 300cycle 45 0/45 45 0/45 45 0/45 45 0/45 45 0/45 45 0/45 45 0/45 10sec*3times 45 0/45 3sec*1times 22 0/22 H:125±5℃ 15min JESD22-A104C ∫5min L:-55±5℃ 15min HTOL@110±5°C JESD22-A108C IF=10mA IC=10mA JESD22-A108C JESD22-A101B Vce=60V 1000hrs H3TRB@ 85±5℃、 85±5%RH Vce=60V 100±5%RH, 2atm JESD22-A103C HTS@125±5℃ JESD22-A119 LTS@-55±5℃ JESD22-B106C RSH@260±5℃ RSH 可焊性 SD JESD22-B102D 1000hrs 168、500、 C 耐锡热试验 168、500、 HTRB@125±5℃ Autoclave LTS 9 试验数 Ta=121±5℃, 低温储存 8 试验过程 JESD22-A102- HTS 7 Reference 试验条件 压力锅 高温储存 6 参考标准 Pb-free@ 245±5℃ 168、500、 1000hrs 96hrs 168、500、 1000hrs 168、500、 1000hrs 以上试验项目如与客户试验要求存在差异或者特殊客户特殊要求的,可根据实际情况按照客户的要求进行试 备注 作,客户未要求依我司试验标准试作,不同产品使用不同电流进行测试 Rem All the tests should be performed according to customers’ actual requirements, while difference arks of test standard or special requirements exist. Otherwise, all the tests are performed according to the standard listed above. Different current is applied to the tests of different product models Http://www.kinglight-OC.com 第 6 页 共 17 页 Rev 1.0 KL816 Datasheet 8. 特性曲线 Characteristic Curves Http://www.kinglight-OC.com 第 7 页 共 17 页 Rev 1.0 KL816 Datasheet Http://www.kinglight-OC.com 第 8 页 共 17 页 Rev 1.0 KL816 Datasheet 9. 订单信息 Order Information • 零件编号 Part Number KL816X(Y)(Z)-V (料号PN:KL816X-Y-Z-V) 附注(Notes): X = 表示引脚形式选项(S、S1、S2、M 或 无) Lead form option (S, S1, S2, M or none) Y = 表示CTR等级(A、B、C、D、X、Y、I、J、K 或 无) CTR Rank (A, B, C, D, X, Y, I, J, K or none) Z = 表示料带和卷盘选项(TA、TB、TU、TD 或 无) Tape and reel option (TA, TB, TU, TD or none) V = 表示VDE标识(客户指定镭射字符才加"V") VDE (Only add "V" to laser characters specified by the customer) 选项 描述 包装数量 Option Description Packing quantity 直脚None M S (TA) S (TB) S1 (TA) S1 (TB) 标准DIP-4 每管100pcs Standard DIP-4 100 units per tube 折弯脚(0.4英寸间距) 每管100pcs Wide lead bend (0.4 inch spacing) 表面贴装脚型方式+ TA料带 & 卷轴选择 Surface mount lead form + TA tape & reel option 表面贴装脚型方式+ TB料带 & 卷轴选择 Surface mount lead form + TB tape & reel option 表面贴装脚型方式(低轮廓)+ TA料带 & 卷轴选择 Surface mount lead form (low profile) + TA tape & reel option 表面贴装脚型方式(低轮廓)+ TB料带 & 卷轴选择 Surface mount lead form (low profile) + TB tape & reel option 100 units per tube 每卷1000pcs 1000 units per reel 每卷1000pcs 1000 units per reel 每卷1000pcs 1000 units per reel 每卷1000pcs 1000 units per reel S2 (TA) 表面贴装脚型方式(翅形)+ TA料带 & 卷轴选择 Surface mount lead form (Gull-wing) + TA tape & reel option 每卷1000pcs 1000 units per reel S2 (TB) 表面贴装脚型方式(翅形)+ TB料带 & 卷轴选择 Surface mount lead form (Gull-wing) + TB tape & reel option 每卷1000pcs 1000 units per reel S (TU) S (TD) S1 (TU) S1 (TD) 表面贴装脚型方式+ TU料带 & 卷轴选择 Surface mount lead form + TU tape & reel option 表面贴装脚型方式+ TD料带 & 卷轴选择 Surface mount lead form + TD tape & reel option 表面贴装脚型方式(低轮廓)+ TU料带 & 卷轴选择 Surface mount lead form (low profile) + TU tape & reel option 表面贴装脚型方式(低轮廓)+ TD料带 & 卷轴选择 Surface mount lead form (low profile) + TD tape & reel option Http://www.kinglight-OC.com 第 9 页 共 17 页 每卷1500pcs 1500 units per reel 每卷1500pcs 1500 units per reel 每卷1500pcs 1500 units per reel 每卷1500pcs 1500 units per reel Rev 1.0 KL816 Datasheet 10. 封装尺寸(单位:毫米) Package Drawing(Unit:mm) • 标准DIP型号 Standard DIP Type • 选择M型号 Option M Type Http://www.kinglight-OC.com 第 10 页 共 17 页 Rev 1.0 KL816 Datasheet • 选择S型号 Option S Type • 选择S1型号 Option S1 Type Http://www.kinglight-OC.com 第 11 页 共 17 页 Rev 1.0 KL816 Datasheet • 选项S2型号 Option S2 Type • 表面贴装引线框架 推荐焊盘布局 Recommended pad layout for surface mount leadform S和S1脚型选项 The S and S1 foot-type S2脚型选项 The S2 foot-type options 附注(Notes): a. 建议焊盘尺寸仅供参考Suggested pad dimension is just for reference only b. 请根据个人需要修改焊盘尺寸Please modify the pad dimension based on individual need Http://www.kinglight-OC.com 第 12 页 共 17 页 Rev 1.0 KL816 Datasheet 11. 设备标记 Device marking (范本参考 Template reference) 附注(Notes): KL = 表示晶台光电有限公司 denotes KingLight 816 = 表示材料部件号 denotes Device Part Number R = 表示CTR等级 denotes CTR Rank Y = 表示1位年份代码 denotes 1 digit Year code WW = 表示2位周别代码 denotes 2 digit Week code V = 表示VDE标识(客户指定镭射字符才加"V") VDE (Only add "V" to laser characters specified by the customer) Http://www.kinglight-OC.com 第 13 页 共 17 页 Rev 1.0 KL816 Datasheet 12. 料带和卷轴包装规格 Tape & Reel Packing Specifications • 选择TA Option TA • 选择TB Option TB 卷轴进给方向 Direction of feed from reel 卷轴进给方向 Direction of feed from reel 料带尺寸Material belt size 尺寸编号 Dimension No. 尺寸(mm) Dimension(mm) 尺寸编号 Dimension No. 尺寸(mm) Dimension(mm) A B D0 D1 E F 10.4±0.1 4.55±0.1 1.5±0.1 1.5±0.1 1.75±0.1 7.5±0.1 P0 P1 P2 t W K 4.0±0.1 12.0±0.1 2.0±0.1 0.33±0.1 16.0+0.3/-0.1 4.55±0.1 Http://www.kinglight-OC.com 第 14 页 共 17 页 Rev 1.0 KL816 Datasheet • 选择TD Option TD • 选择TU Option TU 卷轴进给方向 Direction of feed from reel 卷轴进给方向 Direction of feed from reel 料带尺寸Material belt size 尺寸编号 Dimension No. 尺寸(mm) Dimension(mm) 尺寸编号 Dimension No. 尺寸(mm) Dimension(mm) A B C D1 E F 16±0.3 7.5±0.1 1.75±0.1 8.0±0.1 2.0±0.1 4.0±0.1 G H I J K 1.5+0.1/-0 10.4±0.1 0.4±0.05 4.55±0.1 5.1±0.1 Http://www.kinglight-OC.com 第 15 页 共 17 页 Rev 1.0 KL816 Datasheet 13. 焊接温度曲线 Temperature Profile Of Soldering • 回流焊温度曲线 Reflow soldering 建议在下面所示的温度和时间分布条件下, 进行一次回流焊作业, 不得超过三次 One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. 项目 符号 最小值 最大值 单位 Item Symbol Min. Max. Unit Ts 150 200 ℃ ts 60 120 s - - 3 ℃/s 预热温度 Preheat Temperature 预热时间 Preheat Time 升温速率 Ramp-Up Rate (TL to TP) 液相线温度 Liquidus Temperature 高于液相线温度(TL )的时间 Time above Liquidus Temperature TL 峰值温度 Peak Temperature Tc 在(TP-5)和 TP之间的时间 Time During Which Tc Is Between (TP-5) and TP 降温速率 Ramp-down Rate(TP to TL ) Http://www.kinglight-OC.com TL 217 ℃ tL 60 100 s TP - 260 ℃ tp - 30 s - - 6 ℃/s 第 16 页 共 17 页 Rev 1.0 KL816 Datasheet • 波峰焊温度曲线 Wave Soldering 温度条件下, 建议一次焊接 One time soldering is recommended within the condition of temperature 300 260+0/-5℃ 250 200 温度 第一波 +200℃/秒 First wave +200℃/sec 150 Temperature 第二波-5℃/秒 Second wave -5℃/sec +2℃/sec 100 50 260℃+0/-5℃ 时间 10秒 Time 10S 预热温度 25至140℃ Preheat temperature 25 to 140℃ 预热时间 30至80秒 Preheat time 30 to 80S 预热区 Preheat zone 25℃ 1 Http://www.kinglight-OC.com 2 3 第 17 页 共 17 页 4 Time(min) Rev 1.0
KL816M-A 价格&库存
很抱歉,暂时无法提供与“KL816M-A”相匹配的价格&库存,您可以联系我们找货
