Technical Data ELX1063
Effective June 2021
SMBJE
Automotive grade 600 W Transient voltage suppressor
Applications
Product features
Automotive grade (AEC-Q101 qualified)
Low profile SMB package
Excellent clamping capability
High reliability application
600 W peak pulse power capability at 10/1000
μs waveform
Typical IR less than 1 μA above 9 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
Plastic package meets UL 94 V-0
flammability rating
Meets moisture sensitivity level (MSL) level 1
Terminal: tin plated, solderable per J-STD-002
UL 497B recognized.
File No. : E198449 Guide QVGQ2
Automotive chassis and safety systems
Advanced driver assistance systems (ADAS)
Communication and infotainment systems
Network systems and body electronics
Power Train controls
xEV and battery systems
Environmental compliance and general
specifications
AEC-Q101 qualified
Ordering part number
SMBJE 5-0 C A H
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
PIN configuration
SMBJE
Effective June 2021
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
5
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
600
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
100
A
Typical thermal resistance junction to lead
R
JL
°C/W
Typical thermal resistance junction to ambient
R
JA
100
°C/W
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm/inches
Millimeters
Part marking
Inches
Dimension Minimum
Maximum
Minimum
Maximum
A
3.30
3.94
0.130
0.155
B
4.30
4.80
0.169
0.189
C
1.90
2.20
0.075
0.087
D
0.95
1.52
0.037
0.060
E
5.20
5.60
0.205
0.220
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.10
2.40
0.083
0.094
J
2.00
0.087
K
2.60
0.102
L
2.30
0.091
Cathode band (uni-polar only)
Part marking:
xxxx = Date code
yy- Refer to marking designator listed in Electrical
characteristics table
Packaging information - mm/inches
Drawing not to scale.
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant)
2
www.eaton.com/electronics
Dimensions
Millimeters
Inches
A0
3.76 ± 0.3
0.148 ± 0.012
B0
5.69 ± 0.3
0.224 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.50 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.3145 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
SMBJE
Electrical specifications (+25 °C)
Part number
Effective June 2021
* = not UL497B recognized
VR
IR @ VR
VBR @ IT
IT
VC @ IPP
IPP
Uni-polar
Bi-polar
Marking
Uni
Bi
(V)
(µA)
min (V)
max (V)
(mA)
max (V)
(A)
SMBJE5-0AH
SMBJE5-0CAH
KE
AE
5
120
6.4
7
10
9.2
65.2
SMBJE6-0AH
SMBJE6-0CAH
KG
AG
6
120
6.67
7.37
10
10.3
58.3
SMBJE6-5AH
SMBJE6-5CAH
KK
AK
6.5
120
7.22
7.98
10
11.2
53.6
SMBJE7-0AH
SMBJE7-0CAH
KM
AM
7
50
7.78
8.6
10
12
50
SMBJE7-5AH
SMBJE7-5CAH
KP
AP
7.5
50
8.33
9.21
1
12.9
46.5
SMBJE8-0AH
SMBJE8-0CAH
KR
AR
8
9.83
1
13.6
44.1
SMBJE8-5AH
SMBJE8-5CAH
KT
AT
8.5
10
9.44
10.4
1
14.4
41.7
SMBJE9-0AH
SMBJE9-0CAH
KV
AV
9
5
10
11.1
1
15.4
39
SMBJE11AH
SMBJE11CAH
KZ
AZ
11
1
12.2
13.5
1
18.2
33
SMBJE12AH
SMBJE12CAH
LE
BE
12
1
13.3
14.7
1
19.9
30.2
SMBJE13AH
SMBJE13CAH
LG
BG
13
1
14.4
15.9
1
21.5
27.9
SMBJE14AH
SMBJE14CAH
LK
BK
14
1
15.6
17.2
1
23.2
25.9
SMBJE15AH
SMBJE15CAH
LM
BM
15
1
16.7
18.5
1
24.4
24.6
SMBJE16AH
SMBJE16CAH
LP
BP
16
1
17.8
19.7
1
26
23.1
SMBJE17AH
SMBJE17CAH
LR
BR
17
1
18.9
20.9
1
27.6
21.8
SMBJE18AH
SMBJE18CAH
LT
BT
18
1
1
29.2
20.6
SMBJE20AH
SMBJE20CAH
LV
BV
22.2
24.5
1
32.4
18.6
SMBJE22AH
SMBJE22CAH
LX
BX
22
1
24.4
26.9
1
35.5
16.9
SMBJE24AH
SMBJE24CAH
LZ
BZ
24
1
26.7
29.5
1
38.9
15.4
SMBJE26AH
SMBJE26CAH
ME
CE
26
1
28.9
31.9
1
42.1
14.3
SMBJE28AH
SMBJE28CAH
MG
CG
28
1
31.1
34.4
1
45.4
13.2
SMBJE30AH
SMBJE30CAH
MK
CK
30
1
33.3
36.8
1
48.4
12.4
SMBJE33AH
SMBJE33CAH
MM
CM
33
1
36.7
40.6
1
53.3
11.3
SMBJE36AH
SMBJE36CAH
MP
CP
36
1
40
44.2
1
58.1
10.4
SMBJE40AH
SMBJE40CAH
MR
CR
40
1
44.4
49.1
1
64.5
9.3
SMBJE43AH
SMBJE43CAH
MT
CT
43
1
47.8
52.8
1
69.4
8.7
SMBJE45AH
SMBJE45CAH
MV
CV
45
1
50
55.3
1
72.7
8.3
SMBJE48AH
SMBJE48CAH
MX
CX
48
1
53.3
58.9
1
77.4
7.8
SMBJE51AH
SMBJE51CAH
MZ
CZ
51
1
56.7
62.7
1
82.4
7.3
SMBJE54AH
SMBJE54CAH
NE
DE
54
1
60
66.3
1
87.1
6.9
SMBJE58AH
SMBJE58CAH
NG
DG
58
1
64.4
71.2
1
93.6
6.4
SMBJE60AH
SMBJE60CAH
NK
DK
60
1
66.7
73.7
1
96.8
6.2
SMBJE64AH
SMBJE64CAH
NM
DM
64
1
71.1
78.6
1
103
5.8
SMBJE70AH
SMBJE70CAH
NP
DP
70
1
77.8
86
1
113
5.3
SMBJE75AH
SMBJE75CAH
NR
DR
75
1
83.3
92.1
1
121
5
SMBJE78AH
SMBJE78CAH
NT
DT
78
1
86.7
95.8
1
126
4.8
SMBJE85AH
SMBJE85CAH
NV
DV
85
1
94.4
104
1
137
4.4
SMBJE90AH
SMBJE90CAH
NX
DX
90
1
100
111
1
146
4.1
SMBJE100AH
SMBJE100CAH
NZ
DZ
100
1
111
123
1
162
3.7
SMBJE110AH
SMBJE110CAH
PE
EE
110
1
122
135
1
177
3.4
SMBJE120AH
SMBJE120CAH
PG
EG
120
1
133
147
1
193
3.1
SMBJE130AH
SMBJE130CAH
PK
EK
130
1
144
159
1
209
2.9
SMBJE150AH
SMBJE150CAH
PM
EM
150
1
167
185
1
243
2.5
SMBJE160AH
SMBJE160CAH
PP
EP
160
1
178
197
1
259
2.3
SMBJE170AH
SMBJE170CAH
PR
ER
170
1
189
209
1
275
2.2
SMBJE180AH
SMBJE180CAH
PT
ET
180
1
201
222
1
292
2.1
SMBJE190AH
SMBJE190CAH
PV
EV
190
1
211
234
1
307
2
SMBJE200AH
SMBJE200CAH
PX
EX
200
1
224
247
1
324
1.9
SMBJE210AH
SMBJE210CAH
PZ
EZ
210
1
233
258
1
337
1.8
SMBJE220AH
SMBJE220CAH
QE
FE
220
1
246
272
1
356
1.7
SMBJE250AH
SMBJE250CAH
QG
FG
250
1
279
309
1
405
1.5
SMBJE300AH
SMBJE300CAH
QK
FK
300
1
335
371
1
486
1.3
SMBJE350AH
SMBJE350CAH
QM
FM
350
1
391
432
1
567
1.1
SMBJE400AH
SMBJE400CAH
QP
FP
400
1
447
494
1
648
0.9
SMBJE440AH
SMBJE440CAH
QR
FR
440
1
492
543
1
713
0.8
SMBJE460AH*
SMBJE460CAH*
QT
FT
460
1
510
560
1
735
0.8
3
Effective June 2021
SMBJE
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional
Pulse waveform
IPPM (% IRSM)
PPP derating in percentage (%)
Pulse derating curve
t (ms)
TJ (°C)
PPP (KW)
Peak pulse power dissipation curve
td - Pulse width (ms)
4
SMBJE
Effective June 2021
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SMBJE26CAH”相匹配的价格&库存,您可以联系我们找货
