P6SMB39CA
P6SMB39CA
    EATON(伊顿)
    SMB(DO-214AA)
    53.9V 夹子 11.3A Ipp TVS - 二极管 表面贴装型 SMB
P6SMB39CA 数据手册
Technical Data 11212 Effective November 2020 P6SMB 600 W Transient voltage suppressor Applications Product features • Low profile SMB package • Excellent clamping capability • 600 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 12 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. : E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Mobile and wearables Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number P6SMB 6-8 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance P6SMB 600 W Transient voltage suppressor  Technical Data 11212 Effective November 2020 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 5.0 W Peak pulse power dissipation on 10/1000 μs waveform PPP 600 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 100 A Typical thermal resistance junction to lead R JL 20 °C/W Typical thermal resistance junction to ambient R JA 100 °C/W Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm Millimeters Dimension Minimum Part marking Inches Maximum Minimum Maximum A 3.30 3.94 0.130 0.155 B 4.30 4.80 0.169 0.189 C 1.90 2.20 0.075 0.087 D 0.95 1.52 0.037 0.060 E 5.20 5.60 0.205 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.10 2.40 0.083 0.094 J 2.20 K L 0.087 2.60 0.102 2.30 Packaging information (mm) Cathode band (Uni-polar only) Part marking: xxxx = Date code yyyy- Refer to marking designator listed in Electrical Characteristics table 0.091 Dimension Millimeters Inches Drawing not to scale. A0 3.76 ± 0.3 0.148 ± 0.012 Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) B0 5.69 ± 0.3 0.224 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.5 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.315 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 2 www.eaton.com/electronics Technical Data 11212 P6SMB 600 W Transient voltage suppressor Effective November 2020  Electrical characteristics (+25 °C) Part number Uni-polar Bi-polar Marking Uni Bi VR (V) IR @ VR (μA) VBR @ IT min (V) max (V) IT (mA) VC @ IPP max (V) IPP (A) P6SMB6-8A P6SMB6-8CA 6V8A 6V8C 5.8 150 6.45 7.14 10 10.5 58.1 P6SMB7-5A P6SMB7-5CA 7V5A 7V5C 6.4 120 7.13 7.88 10 11.3 54 P6SMB8-2A P6SMB8-2CA 8V2A 8V2C 7.02 50 7.79 8.61 10 12.1 50.4 P6SMB9-1A P6SMB9-1CA 9V1A 9V1C 7.78 20 8.65 9.55 1 13.4 45.5 P6SMB10A P6SMB10CA 10A 10C 8.55 10 9.5 10.5 1 14.5 42.1 P6SMB11A P6SMB11CA 11A 11C 9.4 5 10.5 11.6 1 15.6 39.1 P6SMB12A P6SMB12CA 12A 12C 10.2 2 11.4 12.6 1 16.7 36.5 P6SMB13A P6SMB13CA 13A 13C 11.1 1 12.4 13.7 1 18.2 33.5 P6SMB15A P6SMB15CA 15A 15C 12.8 1 14.3 15.8 1 21.2 28.8 P6SMB16A P6SMB16CA 16A 16C 13.6 1 15.2 16.8 1 22.5 27.1 P6SMB18A P6SMB18CA 18A 18C 15.3 1 17.1 18.9 1 25.2 24.2 P6SMB20A P6SMB20CA 20A 20C 17.1 1 19 21 1 27.7 21.7 P6SMB22A P6SMB22CA 22A 22C 18.8 1 20.9 23.1 1 30.6 19.7 P6SMB24A P6SMB24CA 24A 24C 20.5 1 22.8 25.2 1 33.2 18.4 P6SMB27A P6SMB27CA 27A 27C 23.1 1 25.7 28.4 1 37.5 16.3 P6SMB30A P6SMB30CA 30A 30C 25.6 1 28.5 31.5 1 41.4 14.7 P6SMB33A P6SMB33CA 33A 33C 28.2 1 31.4 34.7 1 45.7 13.3 P6SMB36A P6SMB36CA 36A 36C 30.8 1 34.2 37.8 1 49.9 12.2 P6SMB39A P6SMB39CA 39A 39C 33.3 1 37.1 41 1 53.9 11.3 P6SMB43A P6SMB43CA 43A 43C 36.8 1 40.9 45.2 1 59.3 10.3 P6SMB47A P6SMB47CA 47A 47C 40.2 1 44.7 49.4 1 64.8 9.4 P6SMB51A P6SMB51CA 51A 51C 43.6 1 48.5 53.6 1 70.1 8.7 P6SMB56A P6SMB56CA 56A 56C 47.8 1 53.2 58.8 1 77 7.9 P6SMB62A P6SMB62CA 62A 62C 53 1 58.9 65.1 1 85 7.2 P6SMB68A P6SMB68CA 68A 68C 58.1 1 64.6 71.4 1 92 6.6 P6SMB75A P6SMB75CA 75A 75C 64.1 1 71.3 78.8 1 103 5.9 P6SMB82A P6SMB82CA 82A 82C 70.1 1 77.9 86.1 1 113 5.4 P6SMB91A P6SMB91CA 91A 91C 77.8 1 86.5 95.5 1 125 4.9 P6SMB100A P6SMB100CA 100A 100C 85.5 1 95 105 1 137 4.5 P6SMB110A P6SMB110CA 110A 110C 94 1 105 116 1 152 4 P6SMB120A P6SMB120CA 120A 120C 102 1 114 126 1 165 3.7 P6SMB130A P6SMB130CA 130A 130C 111 1 124 137 1 179 3.4 P6SMB150A P6SMB150CA 150A 150C 128 1 143 158 1 207 2.9 P6SMB160A P6SMB160CA 160A 160C 136 1 152 168 1 219 2.8 P6SMB170A P6SMB170CA 170A 170C 145 1 162 179 1 234 2.6 P6SMB180A P6SMB180CA 180A 180C 154 1 171 189 1 246 2.5 P6SMB200A P6SMB200CA 200A 200C 171 1 190 210 1 274 2.2 P6SMB220A P6SMB220CA 220A 220C 185 1 209 231 1 328 1.9 P6SMB250A P6SMB250CA 250A 250C 214 1 237 263 1 344 1.8 P6SMB300A P6SMB300CA 300A 300C 256 1 285 315 1 414 1.5 P6SMB350A P6SMB350CA 350A 350C 300 1 332 368 1 482 1.3 P6SMB400A P6SMB400CA 400A 400C 342 1 380 420 1 548 1.1 P6SMB440A P6SMB440CA 440A 440C 376 1 418 462 1 602 1 P6SMB480A P6SMB480CA 480A 480C 408 1 456 504 1 658 0.9 P6SMB510A P6SMB510CA 510A 510C 434 1 485 535 1 698 0.9 P6SMB540A P6SMB540CA 540A 540C 460 1 513 567 1 740 0.8 P6SMB600A P6SMB600CA 600A 600C 512 1 570 630 1 828 0.75 www.eaton.com/electronics 3 P6SMB 600 W Transient voltage suppressor  Technical Data 11212 Effective November 2020 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional TVS diode Pulse derating curve 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 Peak value Half value 50 0 0 td 1.0 2.0 3.0 4.0 t (ms) 100 Ppp (kW) 600 W at 10/1000 μs +25 °C 10 1.0 0.1 0.001 0.01 0.1 td-Pulse width (ms) www.eaton.com/electronics 100 80 60 40 20 0 0 25 50 75 100 125 150 TJ-Initial junction temperature (°C) Peak pulse power dissipation vs. pulse width 4 PPP derating in percentage (%) Pulse waveform 1.0 10 175 Technical Data 11212 P6SMB 600 W Transient voltage suppressor Effective November 2020  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
P6SMB39CA 价格&库存
很抱歉,暂时无法提供与“P6SMB39CA”相匹配的价格&库存,您可以联系我们找货
