Technical Data 11214
Effective November 2020
SMBJE
600 W Transient voltage suppressor
Applications
Product features
Low profile SMB package
Excellent clamping capability
600 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 1 μA above 10 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0 flammability
rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Solder plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized.
File No. : E198449 Guide QVGQ2
PIN configuration
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Mobile and wearables
Environmental compliance and general
specifications
HALOGEN
Pb HF
FREE
Ordering part number
SMBJE 5-0 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
SMBJE
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
5.0
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
600
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
100
A
Typical thermal resistance junction to lead
R
JL
°C/W
Typical thermal resistance junction to ambient
R
JA
100
°C/W
Storage operating junction temperature range
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm
Part marking
Millimeters
Inches
Dimension Minimum
Maximum
Minimum
Maximum
A
3.94
0.130
0.155
3.30
B
4.30
4.80
0.169
0.189
C
1.90
2.20
0.075
0.087
D
0.95
1.52
0.037
0.060
E
5.20
5.60
0.205
0.220
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.10
2.40
0.083
0.094
J
2.20
K
L
Cathode band (Uni-polar only)
Part marking: xxxx = Date code
yy- Refer to marking designator listed
in Electrical Characteristics table
0.087
2.60
2.30
Packaging information (mm)
0.102
0.091
Dimension
Millimeters
Inches
Drawing not to scale.
A0
3.76 ± 0.3
0.148 ± 0.012
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel
(EIA-481 compliant)
B0
5.69 ± 0.3
0.224 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.50 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.3145 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
2
www.eaton.com/electronics
SMBJE
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
Marking
Uni
Bi
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @ IPP
max (V)
IPP
(A)
SMBJE5-0A
SMBJE5-0CA
KE
AE
5
120
6.4
7
10
9.2
65.2
SMBJE6-0A
SMBJE6-0CA
KG
AG
6
120
6.67
7.37
10
10.3
58.3
SMBJE6-5A
SMBJE6-5CA
KK
AK
6.5
120
7.22
7.98
10
11.2
53.6
SMBJE7-0A
SMBJE7-0CA
KM
AM
7
50
7.78
8.6
10
12
50
SMBJE7-5A
SMBJE7-5CA
KP
AP
7.5
50
8.33
9.21
1
12.9
46.5
SMBJE8-0A
SMBJE8-0CA
KR
AR
8
9.83
1
13.6
44.1
SMBJE8-5A
SMBJE8-5CA
KT
AT
8.5
10
9.44
10.4
1
14.4
41.7
SMBJE9-0A
SMBJE9-0CA
KV
AV
9
5
10
11.1
1
15.4
39
SMBJE10A
SMBJE10CA
KX
AX
10
2
11.1
12.3
1
17
35.3
SMBJE11A
SMBJE11CA
KZ
AZ
11
1
12.2
13.5
1
18.2
33
SMBJE12A
SMBJE12CA
LE
BE
12
1
13.3
14.7
1
19.9
30.2
SMBJE13A
SMBJE13CA
LG
BG
13
1
14.4
15.9
1
21.5
27.9
SMBJE14A
SMBJE14CA
LK
BK
14
1
15.6
17.2
1
23.2
25.9
SMBJE15A
SMBJE15CA
LM
BM
15
1
16.7
18.5
1
24.4
24.6
SMBJE16A
SMBJE16CA
LP
BP
16
1
17.8
19.7
1
26
23.1
SMBJE17A
SMBJE17CA
LR
BR
17
1
18.9
20.9
1
27.6
21.8
SMBJE18A
SMBJE18CA
LT
BT
18
1
1
29.2
20.6
SMBJE20A
SMBJE20CA
LV
BV
22.2
24.5
1
32.4
18.6
SMBJE22A
SMBJE22CA
LX
BX
22
1
24.4
26.9
1
35.5
16.9
SMBJE24A
SMBJE24CA
LZ
BZ
24
1
26.7
29.5
1
38.9
15.4
SMBJE26A
SMBJE26CA
ME
CE
26
1
28.9
31.9
1
42.1
14.3
SMBJE28A
SMBJE28CA
MG
CG
28
1
31.1
34.4
1
45.4
13.2
SMBJE30A
SMBJE30CA
MK
CK
30
1
33.3
36.8
1
48.4
12.4
SMBJE33A
SMBJE33CA
MM
CM
33
1
36.7
40.6
1
53.3
11.3
SMBJE36A
SMBJE36CA
MP
CP
36
1
40
44.2
1
58.1
10.4
SMBJE40A
SMBJE40CA
MR
CR
40
1
44.4
49.1
1
64.5
9.3
SMBJE43A
SMBJE43CA
MT
CT
43
1
47.8
52.8
1
69.4
8.7
SMBJE45A
SMBJE45CA
MV
CV
45
1
50
55.3
1
72.7
8.3
SMBJE48A
SMBJE48CA
MX
CX
48
1
53.3
58.9
1
77.4
7.8
SMBJE51A
SMBJE51CA
MZ
CZ
51
1
56.7
62.7
1
82.4
7.3
SMBJE54A
SMBJE54CA
NE
DE
54
1
60
66.3
1
87.1
6.9
SMBJE58A
SMBJE58CA
NG
DG
58
1
64.4
71.2
1
93.6
6.4
SMBJE60A
SMBJE60CA
NK
DK
60
1
66.7
73.7
1
96.8
6.2
SMBJE64A
SMBJE64CA
NM
DM
64
1
71.1
78.6
1
103
5.8
SMBJE70A
SMBJE70CA
NP
DP
70
1
77.8
86
1
113
5.3
SMBJE75A
SMBJE75CA
NR
DR
75
1
83.3
92.1
1
121
5
SMBJE78A
SMBJE78CA
NT
DT
78
1
86.7
95.8
1
126
4.8
SMBJE85A
SMBJE85CA
NV
DV
85
1
94.4
104
1
137
4.4
SMBJE90A
SMBJE90CA
NX
DX
90
1
100
111
1
146
4.1
SMBJE100A
SMBJE100CA
NZ
DZ
100
1
111
123
1
162
3.7
SMBJE110A
SMBJE110CA
PE
EE
110
1
122
135
1
177
3.4
SMBJE120A
SMBJE120CA
PG
EG
120
1
133
147
1
193
3.1
SMBJE130A
SMBJE130CA
PK
EK
130
1
144
159
1
209
2.9
SMBJE150A
SMBJE150CA
PM
EM
150
1
167
185
1
243
2.5
SMBJE160A
SMBJE160CA
PP
EP
160
1
178
197
1
259
2.3
SMBJE170A
SMBJE170CA
PR
ER
170
1
189
209
1
275
2.2
SMBJE180A
SMBJE180CA
PT
ET
180
1
201
222
1
292
2.1
SMBJE190A
SMBJE190CA
PV
EV
190
1
211
234
1
307
2
SMBJE200A
SMBJE200CA
PX
EX
200
1
224
247
1
324
1.9
SMBJE210A
SMBJE210CA
PZ
EZ
210
1
233
258
1
337
1.8
SMBJE220A
SMBJE220CA
QE
FE
220
1
246
272
1
356
1.7
SMBJE250A
SMBJE250CA
QG
FG
250
1
279
309
1
405
1.5
SMBJE300A
SMBJE300CA
QK
FK
300
1
335
371
1
486
1.3
SMBJE350A
SMBJE350CA
QM
FM
350
1
391
432
1
567
1.1
SMBJE400A
SMBJE400CA
QP
FP
400
1
447
494
1
648
0.9
SMBJE440A
SMBJE440CA
QR
FR
440
1
492
543
1
713
0.8
3
SMBJE
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional TVS diode
Pulse derating curve
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
PPP derating in percentage (%)
Pulse waveform
Peak value
Half value
50
td
1.0
2.0
3.0
4.0
Peak pulse power dissipation vs. pulse width
100
Ppp (kW)
600 W at 10/1000 μs +25 °C
10
1.0
0.01
0.1
td-Pulse width (ms)
4
80
60
40
50
75
100
125
150
TJ-Initial junction temperature (°C)
t (ms)
0.1
0.001
100
1.0
10
175
SMBJE
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SMBJE250CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+10.62884
- 25+3.93531
- 100+2.18726
- 125+1.94130
- 285+1.84468
