HZ Series
Silicon Epitaxial Planar Zener Diodes
for stabilized power supply
Max. 0.5
Min. 27.5
Max. 1.9
Features
• Low leakage, low zener impedance and maximum
power dissipation of 500 mW are ideally suited for
stabilized power supply, etc.
• Wide spectrum from 1.8 V through 38 V of zener
voltage provide flexible application.
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
XXX
Max. 3.9
ST
Min. 27.5
Glass Case DO-35
Dimensions in mm
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Power Dissipation
Ptot
Junction Temperature
Tj
Storage Temperature Range
Tstg
Zener Voltage 1)
VZ
Min. (V)
Max. (V)
1.8
2
1.9
2.1
2
2.2
2.1
2.3
2.2
2.4
2.3
2.5
2.4
2.6
2.5
2.7
2.6
2.8
2.7
2.9
2.8
3
2.9
3.1
3
3.2
3.1
3.3
3.2
3.4
3.3
3.5
3.4
3.6
3.5
3.7
3.6
3.8
3.7
3.9
3.8
4
3.9
4.1
4
4.2
4.1
4.3
Type
HZ2A3
HZ2B1
HZ2B2
HZ2B3
HZ2C1
HZ2C2
HZ2C3
HZ3A1
HZ3A2
HZ3A3
HZ3B1
HZ3B2
HZ3B3
HZ3C1
HZ3C2
HZ3C3
HZ4A1
HZ4A2
HZ4A3
HZ4B1
HZ4B2
HZ4B3
HZ4C1
HZ4C2
at lZT
(mA)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
Reverse Leakage Current
IR
at VR
Max. (µA)
(V)
25
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
0.5
5
1
5
1
5
1
5
1
5
1
5
1
5
1
5
1
M
E
S
H
C
Unit
500
mW
175
O
- 55 to + 175
O
E
T
Characteristics at Ta = 25 OC (VF = 1 V Max. at IF = 100 mA)
Value
C
C
Dynamic Resistance
ZZT
at lZT
Max. (Ω)
(mA)
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
SEMTECH ELECTRONICS LTD.
Dated: 14//07/2014
Rev:01
HZ Series
Zener Voltage
VZ
Min. (V)
Max. (V)
4.2
4.4
4.3
4.5
4.4
4.6
4.5
4.7
4.6
4.8
4.7
4.9
4.8
5
4.9
5.1
5
5.2
5.1
5.3
5.2
5.5
5.3
5.6
5.4
5.7
5.5
5.8
5.6
5.9
5.7
6
5.8
6.1
6
6.3
6.1
6.4
6.3
6.6
6.4
6.7
6.6
6.9
6.7
7
6.9
7.2
7
7.3
7.2
7.6
7.3
7.7
7.5
7.9
7.7
8.1
7.9
8.3
8.1
8.5
8.3
8.7
8.5
8.9
8.7
9.1
8.9
9.3
9.1
9.5
9.3
9.7
9.5
9.9
9.7
10.1
9.9
10.3
10.2
10.6
10.4
10.8
10.7
11.1
10.9
11.3
11.1
11.6
11.4
11.9
Type
HZ4C3
HZ5A1
HZ5A2
HZ5A3
HZ5B1
HZ5B2
HZ5B3
HZ5C1
HZ5C2
HZ5C3
HZ6A1
HZ6A2
HZ6A3
HZ6B1
HZ6B2
HZ6B3
HZ6C1
HZ6C2
HZ6C3
HZ7A1
HZ7A2
HZ7A3
HZ7B1
HZ7B2
HZ7B3
HZ7C1
HZ7C2
HZ7C3
HZ9A1
HZ9A2
HZ9A3
HZ9B1
HZ9B2
HZ9B3
HZ9C1
HZ9C2
HZ9C3
HZ11A1
HZ11A2
HZ11A3
HZ11B1
HZ11B2
HZ11B3
HZ11C1
HZ11C2
HZ11C3
1)
at lZT
(mA)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
IR
at VR
Max. (µA)
(V)
5
1
5
1.5
5
1.5
5
1.5
5
1.5
5
1.5
5
1.5
5
1.5
5
1.5
5
1.5
5
2
5
2
5
2
5
2
5
2
5
2
5
2
5
2
5
2
1
3.5
1
3.5
1
3.5
1
3.5
1
3.5
1
3.5
1
3.5
1
3.5
1
3.5
1
5
1
5
1
5
1
5
1
5
1
5
1
5
1
5
1
5
1
7.5
1
7.5
1
7.5
1
7.5
1
7.5
1
7.5
1
7.5
1
7.5
1
7.5
M
E
S
E
T
Dynamic Resistance
ZZT
at lZT
Max. (Ω)
(mA)
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
100
5
40
5
40
5
40
5
40
5
40
5
40
5
40
5
40
5
40
5
15
5
15
5
15
5
15
5
15
5
15
5
15
5
15
5
15
5
25
5
25
5
25
5
25
5
25
5
25
5
25
5
25
5
25
5
H
C
Dated: 14//07/2014
Rev:01
HZ Series
Zener Voltage
VZ
Min. (V)
Max. (V)
11.6
12.1
11.9
12.4
12.2
12.7
12.4
12.9
12.6
13.1
12.9
13.4
13.2
13.7
13.5
14
13.8
14.3
14.1
14.7
14.5
15.1
14.9
15.5
15.3
15.9
15.7
16.5
16.3
17.1
16.9
17.7
17.5
18.3
18.1
19
18.8
19.7
19.5
20.4
20.2
21.1
20.9
21.9
21.6
22.6
22.3
23.3
22.9
24
23.6
24.7
24.3
25.5
25.2
26.6
26.2
27.6
27.2
28.6
28.2
29.6
29.2
30.6
30.2
31.6
31.2
32.6
32.2
33.6
33.2
34.6
34.2
35.7
35.3
36.8
36.4
38
Type
HZ12A1
HZ12A2
HZ12A3
HZ12B1
HZ12B2
HZ12B3
HZ12C1
HZ12C2
HZ12C3
HZ15-1
HZ15-2
HZ15-3
HZ16-1
HZ16-2
HZ16-3
HZ18-1
HZ18-2
HZ18-3
HZ20-1
HZ20-2
HZ20-3
HZ22-1
HZ22-2
HZ22-3
HZ24-1
HZ24-2
HZ24-3
HZ27-1
HZ27-2
HZ27-3
HZ30-1
HZ30-2
HZ30-3
HZ33-1
HZ33-2
HZ33-3
HZ36-1
HZ36-2
HZ36-3
at lZT
(mA)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
IR
at VR
Max. (µA)
(V)
1
9.5
1
9.5
1
9.5
1
9.5
1
9.5
1
9.5
1
9.5
1
9.5
1
9.5
1
11
1
11
1
11
1
12
1
12
1
12
1
13
1
13
1
13
1
15
1
15
1
15
1
17
1
17
1
17
1
19
1
19
1
19
1
21
1
21
1
21
1
23
1
23
1
23
1
25
1
25
1
25
1
27
1
27
1
27
M
E
S
1)
1)
E
T
Dynamic Resistance
ZZT
at lZT
Max. (Ω)
(mA)
35
5
35
5
35
5
35
5
35
5
35
5
35
5
35
5
35
5
40
5
40
5
40
5
45
5
45
5
45
5
55
5
55
5
55
5
60
2
60
2
60
2
65
2
65
2
65
2
70
2
70
2
70
2
80
2
80
2
80
2
100
2
100
2
100
2
120
2
120
2
120
2
140
2
140
2
140
2
H
C
Tested with pulses tp = 20 ms.
Dated: 14//07/2014
Rev:01
HZ Series
Fig.1- Zener current versus zener voltage
-2
HZ30-2
HZ20-2
HZ16-2
HZ12B2
HZ9B2
HZ24-2
-4
10
HZ36-2
Zener Current Iz (A)
HZ6B2
-3
10
HZ4B2
HZ2B2
10
-5
10
-6
10
-7
10
-8
10
5
15
Zener voltage Vz (v)
Zener voltage
temperature coefficient z (mV / C)
Zener voltage
E
T
H
C
40
Power dissipation Ptot ( mW )
( %/ C)
M
E
%/ C
S
35
Fig. 3 Power dissipation Vs.
Ambient temperature
Fig.2 Temperature Coefficient
Vs. Zener voltage
mV / C
30
Zener voltage VZ ( V )
Ambient temperature Ta ( C )
Dated: 14//07/2014
Rev:01
很抱歉,暂时无法提供与“HZ3C3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.13717
- 50+0.11143
- 125+0.08772
