Page 1/6
Data sheet
P/N
313301xx
xx=number of poles
PT115xxHBBN Type 330
2023/06/28
Version: X
Illustrations
Dimensional drawing
Drill pattern
See enlarged drawings at the end of document
Product specification
• pin header, solderable
• centerline 5.00 mm, direction of connection 90°
• closed ends
• color black
• codeable
Data sheet
Page 2/6
P/N
313301xx
xx=number of poles
2023/06/28
Version: X
Technical Data
General Data
Solder pin length
3.45 mm
min. number of poles
2
max. number of poles
24
Insulating material class
CTI 600
clearance/creepage dist.
4 mm
Protection category
IP00
Rated current
10 A
Overvoltage category
III
III
II
Pollution degree
3
2
2
Rated voltage
320 V
800 V
800 V
Rated test voltage
4 kV
4 kV
4 kV
Approvals
V/A
approval UL - File No.
1.5 mm²
300 / 16
E121004
320 V / 4 kV / 13.5 A / 1.0 x 1.0 mm
Material
insulating material
PA66
flammability class
V0
contact pin material
CuFe
contact pin surface
Ni + Ag
Glow-Wire Flammability GWFI
960 °C acc. to IEC 60695-2-12
Glow-Wire Flammability GWIT
775 °C acc. to IEC 60695-2-13
Climatic Data
upper limit temperature
105 °C
lower limit temperature
-40 °C
general
Tolerance
ISO 2768 -mH
Solderability
Acc. to JEDEC JESD22-B102E 245°C/5s
Data sheet
Page 3/6
P/N
313301xx
xx=number of poles
2023/06/28
Version: X
Accessories
P/N
Designation
700024-01-9
Coding star white
700523-0157
Geh_Kappe_swg_Block
Data sheet
Page 4/6
P/N
313301xx
xx=number of poles
2023/06/28
Version: X
Counterpart of
P/N
Designation
313131
RP035xxHBLC Type 313
313141
RP035xxHBLD Type 314
31314103-08
RP035xxHBLD Typ 314
31314103-09
RP035xxHBLD Typ 314
313491
RP015xxVBLC Type 349
313501
RP015xxSBLC Type 350
ASP045
SP045xxVBNC ASP045
SP065XXVBNC
SP065xxVBNC
SP065XXVBPC
SP065xxVBPC
SP995XXVBNC
SP995xxVBNC
Data sheet
Page 5/6
P/N
313301xx
xx=number of poles
2023/06/28
Version: X
Illustrations
Dimensional drawing
L=(pole size - 1) x centerline + 6.2 mm [0.244]
Data sheet
Page 6/6
P/N
313301xx
xx=number of poles
2023/06/28
Version: X
Illustrations
Drill pattern
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“31330103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+3.2821625+0.39852
- 100+3.26682100+0.39666
- 250+3.26675250+0.39665
- 1000+3.266671000+0.39664
- 2500+3.266602500+0.39664
- 国内价格 香港价格
- 500+3.19224500+0.38761
- 1000+3.177321000+0.38579
- 1500+3.177251500+0.38579
- 2500+3.177172500+0.38578
- 5000+3.177115000+0.38577
- 国内价格
- 1+3.85560
- 10+3.22920
- 30+2.91600
