EJ050NA-01G-TP(带固定框)
    ZD(志达)
    5寸,点阵,TTL,彩色
EJ050NA-01G-TP(带固定框) 数据手册
CHIMEI INNOLUX DISPLAY CORPORATION LCD MODULE S P E C I F I C AT I O N Customer: Model Name: Date: Version: EJ050NA-01G 2011/12/01 01  Preliminary Specification  Final Specification For Customer ’s Acceptance Approved by Approved by Charlie Chou 2011/12/08 Comment Review ed by Green Fu 2011/12/08 Prepared by David Lee 2011/12/07 CHIMEI INNOLUX CHIMEI InnoLux copyright 2004 All rights reserved, Copying forbidden. Record of Revision Version Pre-spec.01 Revise Date 2010/12/01 Page Content Initial Release. CHIMEI INNOLUX Contents 1. General Specifications ………………………………………………………………………………1 2. Pin Assignment ………………………………………………………………………………...2 3. Operation Specifications …………………………………………………………………………5 3.1. Absolute Maximum Ratings ............................................................................................ 5 3.2. Typical operation conditions ........................................................................................... 6 3.3 Backlight Driving Conditions .......................................................................................... 7 3.4. Power Sequence ............................................................................................................ 8 3.5. Timing Characteristics .................................................................................................... 9 3.5.1. Timing Conditions ................................................................................................... 9 3.5.2. Timing Diagram .................................................................................................... 10 4. Optical Specifications…….…………………………………………………………… ………… ...13 5. Reliability Test Items ……………………………………………………………………………….17 6. General Precautions ……………………………………………………………………………….18 6.1. Safety ............................................................................................................................ 18 6.2. Handling ........................................................................................................................ 18 6.3. Static Electricity.............................................................................................................. 18 6.4. Storage .......................................................................................................................... 18 6.5. Cleaning ........................................................................................................................ 18 7. Mechanical Drawing ……………………………………………………………………………….19 8. Package Drawing ……………………………………………………………………………….20 8.1 Packaging Material Table.............................................................................................. 20 8.2 Packaging Quantity ...................................................................................................... 20 8.3 Packaging Drawing....................................................................................................... 21 CHIMEI INNOLUX Date :2011/12/01 Page:1/21 1. General Specifications No. Item Specification 1 LCD size 5.0 inch(Diagonal) 2 Driver element a-Si TFT active matrix 3 Resolution 800 × 3(RGB) × 480 4 Display mode Normally White, Transmissive 5 Dot pitch 0.045(W) ×0.135(H) mm 6 Active area 108.0(W) × 64.8(H) mm 7 Module size 120.7(W) × 76.3(H) × 3.1(D) mm 8 Surface treatment 9 Color arrangement RGB-stripe 10 Interface Digital 11 View direction(Gray Inversion) 6 O’Clock 11 Backlight Power consumption (0.868W) 12 Panel Power consumption (0.223 W) 13 Weight TBD(g) Plant Remark CHIMEI INNOLUX Date :2011/12/01 Page:2/21 2. Pin Assignment FPC Connector is used for the module electronics interface. The recommended model is FH12A-50S-0.5SH manufactured by Hirose. Pin No. Symbol I/O Function Remark 1 VLED+ P Power for LED backlight (Anode) 2 VLED+ P Power for LED backlight (Anode) 3 VLED- P Power for LED backlight (Cathode) 4 VLED- P Power for LED backlight (Cathode) 5 GND P Power ground 6 VCOM P Common voltage 7 DVDD P Power for Digital Circuit 8 MODE I DE/SYNC mode select 9 DE I Data Input Enable 10 VS I Vertical Sync Input 11 HS I Horizontal Sync Input 12 B7 I Blue data(MSB) 13 B6 I Blue data 14 B5 I Blue data 15 B4 I Blue data 16 B3 I Blue data 17 B2 I Blue data 18 B1 I Blue data Note 2 19 B0 I Blue data(LSB) Note 2 20 G7 I Green data(MSB) 21 G6 I Green data 22 G5 I Green data 23 G4 I Green data 24 G3 I Green data 25 G2 I Green data 26 G1 I Green data Note 2 27 G0 I Green data(LSB) Note 2 Note 1 CHIMEI INNOLUX Date :2011/12/01 Page:3/21 28 R7 I Red data(MSB) 29 R6 I Red data 30 R5 I Red data 31 R4 I Red data 32 R3 I Red data 33 R2 I Red data 34 R1 I Red data Note 2 35 R0 I Red data(LSB) Note 2 36 GND P Power Ground 37 DCLK I Sample clock 38 GND P Power Ground 39 L/R I Left / right selection Note 4,5 40 U/D I Up/down selection Note 4,5 41 VGH P Gate ON Voltage 42 VGL P Gate OFF Voltage 43 AVDD P Power for Analog Circuit 44 RESET I Global reset pin. 45 NC - No connection 46 VCOM P Common Voltage 47 DITHB I Dithering function 48 GND P Power Ground 49 NC - No connection 50 NC - No connection Note 3 Note 6 Note 7 I: input, O: output, P: Power Note 1: DE/SYNC mode select. Normally pull high. When select DE mode, MODE=”1”, VS and HS must pull high. When select SYNC mode, MODE= ”0”, DE must be grounded. Note 2: When input 18 bits RGB data, the two low bits of R,G and B data must be grounded. Note 3: Data shall be latched at the falling edge of DCLK. CHIMEI INNOLUX Date :2011/12/01 Page:4/21 Note 4: Selection of scanning mode Setting of scan control input Scanning direction U/D L/R GND DVDD Up to down, left to right DVDD GND Down to up, right to left GND GND Up to down, right to left DVDD DVDD Down to up, left to right Note 5: Definition of scanning direction. Refer to the figure as below: Note 6: Global reset pin. Active low to enter reset state. Suggest to connect with an RC reset circuit for stability. Normally pull high. Note 7: Dithering function enable control, normally pull high. When DITHB=”1”,Disable internal dithering function, When DITHB=”0”,Enable internal dithering function, CHIMEI INNOLUX Date :2011/12/01 Page:5/21 3. Operation Specifications 3.1. Absolute Maximum Ratings Item Symbol (Note 1) Values Min. Max. Unit Remark DVDD -0.3 5 V AVDD -0.5 13.5 V VGH -0.3 42 V VGL -20 0.3 V VGH-VGL - 40 V Operation Temperature TOP -20 70 ℃ Storage Temperature TST -30 80 ℃ LED Reverse Voltage VR - 3.3 V Each LED Note 2 LED Forward Current IF - 20 mA Each LED Power voltage Note 1: The absolute maximum rating values of this product are not allowed to be exceeded at any times. A module should be used with any of the absolute maximum ratings exceeded, the characteristics of the module may not be recovered, or in an extreme condition, the module may be permanently destroyed. Note 2: VR Conditions: Zener Diode 20mA CHIMEI INNOLUX Date :2011/12/01 Page:6/21 3.2.Typical operation conditions ( Note 1) Values Item Symbol Unit Remark Note 2 Min. Typ. Max. DVDD 3.0 3.3 3.6 V AVDD 10.2 10.4 10.6 V VGH 15.3 16.0 16.7 V VGL -6.7 -6.0 -5.3 V VCOM 3.09 4.09 5.09 V Input logic high voltage VIH 0.7 DVDD - DVDD V Input logic low voltage VIL 0 - 0.3 DVDD V Power voltage Input signal voltage Note 4 Note 3 Note 1: Be sure to apply DVDD and VGL to the LCD first, and then apply VGH. Note 2: DVDD setting should match the signals output voltage (refer to Note 3) of customer’s system board. Note 3: DCLK,HS,VS,RESET,U/D, L/R,DE,R0~R7,G0~G7,B0~B7,MODE,DITHB. Note 4: Typical VCOM is only a reference value. It must be optimized according to each LCM. Please use VR and base on below application circuit. CHIMEI INNOLUX Date :2011/12/01 Page:7/21 3.3.Current Consumption Values Item Symbol Unit Remark 1 mA VGH =16.0V (0.54) 1 mA VGL = -6.0V - (4.2) 10 mA DVDD =3.3V - (19) 50 mA AVDD =10.4V Min. Typ. Max. IGH - (0.50) IGL - IDVDD IAVDD Current for Driver 3.4.Backlight Driving Conditions Values Item Symbol Unit Min. Typ. Max. Voltage for LED Backlight VL 19.6 21.7 23.8 V Current for LED Backlight IL 36 40 44 mA LED life time - 20,000 - - Hr Remark Note 1 Note 2 Note 1: The LED Supply Voltage is defined by the number of LED at Ta=25℃ and IL =40mA. Note 2: The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL =40mA. The LED lifetime could be decreased if operating IL is lager than 40 mA. CHIMEI INNOLUX Date :2011/12/01 Page:8/21 3.5.Power Sequence To prevent a latch-up or DC operation of the LCD module, the power on/off sequence should be as the diagram below. a. Power on sequence: 50us >500us RESET >35ms Interface Signal Normal signal 20us VGL >40us VGH >120ms B/L b. Power off sequence: VDD RESET >=0ms Interface Signal Normal signal AVDD VCOM >100ms VGL VGH B/L >=0ms >50ms CHIMEI INNOLUX Date :2011/12/01 Page:9/21 3.6.Timing Characteristics 3.6.1. Timing Conditions Item Values Symbol Unit Min. Typ. Max. HS setup time Thst 8 - - ns HS hold time Thhd 8 - - ns VS setup time Tvst 8 - - ns VS hold time Tvhd 8 - - ns Data setup time Tdsu 8 - - ns Data hole time Tdhd 8 - - ns DE setup time Tesu 8 - - ns DE hole time Tehd 8 - - ns DVDD Power On Slew rate TPOR - - 20 ms RESET pulse width TRst 1 - - ms DCLK cycle time Tcoh 20 - - ns DCLK pulse duty Tcwh 40 50 60 % Remark From 0 to 90% DVDD CHIMEI INNOLUX 3.6.2. Timing Diagram Date :2011/12/01 Page:10/21 CHIMEI INNOLUX Date :2011/12/01 Page:11/21 3.6.3. Timing Values Item Symbol Unit Min. Typ. Max. Horizontal Display Area thd - 800 - DCLK DCLK Frequency fclk 26.4 33.3 46.8 MHz th 862 1056 1200 DCLK thpw 1 - 40 DCLK HS Blanking thb 46 46 46 DCLK HS Front Porch thfp 16 210 354 DCLK One Horizontal Line HS pulse width Remark Values Item Symbol Unit Min. Typ. Max. Vertical Display Area tvd - 480 - TH VS period time tv 510 525 650 TH VS pulse width tvpw 1 - 20 TH VS Blanking tvb 23 23 23 TH VS Front Porch tvfp 7 22 147 TH Remark CHIMEI INNOLUX 3.6.4. Data Input Format Date :2011/12/01 Page:12/21 CHIMEI INNOLUX Date :2011/12/01 Page:13/21 4. Optical Specifications Item Viewing angle (CR≥ 10) Values Symb ol Condition θL θR Unit Min. Typ. Max. Φ=180°(9 o’clock) 60 70 - Φ=0°(3 o’clock) 60 70 - Remark degree Note 1 θT Φ=90°(12 o’clock) 40 50 - θB Φ=270°(6 o’clock) 60 70 - TON - 10 20 msec Note 3 TOFF - 15 30 msec Note 3 CR 400 500 - - Note 4 0.26 0.31 0.36 - WY 0.28 0.33 0.38 - Note 2 Note 5 Note 6 Luminance L 280 350 - cd/m² Note 6 Luminance uniformity YU 70 75 - % Note 7 Response time Contrast ratio WX Color chromaticity Normal θ=Φ=0° Test Conditions: 1. VDD =3.3V, IL=40mA (Backlight current), the ambient temperature is 25℃. 2. The test systems refer to Note 2. CHIMEI INNOLUX Date :2011/12/01 Page:14/21 Note 1: Definition of viewing angle range Normal line θ=Φ=0° Φ=90° 12 o’clock direction θL θR θB θT Φ=180° Φ=0° Active Area Φ=270° 6 o’clock direction Fig. 4-1 Definition of viewing angle Note 2: Definition of optical measurement system. The optical characteristics should be measured in dark room. After 30 minutes operation, the optical properties are measured at the center point of the LCD screen. (Response time is measured by Photo detector TOPCON BM-7, other items are measured by BM-5A/Field of view: 1° /Height: 500mm.) Photo detector 500mm Normal line θ=Φ=0° Φ=90° 12 o’clock direction Φ=180° Φ=0° Active Area Φ=270° 6 o’clock direction Fig. 4-2 Optical measurement system setup CHIMEI INNOLUX Date :2011/12/01 Page:15/21 Note 3: Definition of Response time The response time is defined as the LCD optical switching time interval between “White” state and “Black” state. Rise time (TON) is the time between photo detector output intensity changed from 90% to 10%. And fall time (TOFF) is the time between photo detector output intensity changed from 10% to 90%. Photo detector output (Relative value) White (TFT OFF) Black (TFT ON) White (TFT OFF) 100% 90% 10% 0% TON TOFF Fig. 4-3 Definition of response time Note 4: Definition of contrast ratio Contrast ratio (CR) = Luminance measured when LCD on the " White" state Luminance measured when LCD on the " Black" state Note 5: Definition of color chromaticity (CIE1931) Color coordinates measured at center point of LCD. Note 6: Definition of luminance: Measured at the center area of the panel when LCD panel is driven at “white” state CHIMEI INNOLUX Date :2011/12/01 Page:16/21 Note 7: Definition of Luminance Uniformity Active area is divided into 9 measuring areas (Refer to Fig. 4-4 ).Every measuring point is placed at the center of each measuring area. Luminance Uniformity (Yu) = L-------Active area length B min B max W----- Active area width L/6 L/3 L/3 W/3 W W/3 W/6 L Fig. 4-4 Definition of measuring points Bmax: The measured maximum luminance of all measurement position. Bmin: The measured minimum luminance of all measurement position. CHIMEI INNOLUX Date :2011/12/01 Page:17/21 4. Reliability Test Items (Note3) Item Test Conditions Remark High Temperature Storage Ta = 80℃ 240 hrs Note 1,Note 4 Low Temperature Storage Ta = -30℃ 240hrs Note 1,Note 4 High Temperature Operation Ts = 70℃ 240hrs Note 2,Note 4 Low Temperature Operation Ta = -20℃ 240hrs Note 1,Note 4 Operate at High Temperature and Humidity +60℃, 90% RH 240 hrs Note 4 Thermal Shock -20℃/30 min ~ +70℃/30 min for a total 100 cycles, Start with cold temperature and end with high temperature Note 4 Frequency range:10~55Hz Stroke:1.5mm Vibration Test Sweep:10Hz~55Hz~10Hz 2 hours for each direction of X. Y. Z. (6 hours for total) 100G 6ms,±X, ±Y, ±Z 3 times for each Mechanical Shock direction Random Vibration : 0.015G*G/Hz from 5-200HZ, Package Vibration Test -6dB/Octave from 200-500HZ 2 hours for each direction of X. Y. Z. (6 hours for total) Height:60 cm Package Drop Test 1 corner, 3 edges, 6 surfaces ± 2KV, Human Body Mode, Electro Static Discharge 100pF/1500Ω Note 1: Ta is the ambient temperature of samples. Note 2: Ts is the temperature of panel’s surface. Note 3: In the standard condition, there shall be no practical problem that may affect the display function. After the reliability test, the product only guarantees operation, but doesn’t guarantee all the cosmetic specification. Note 4: Before cosmetic and function tests, the product must have enough recovery time, at least 2 hours at room temperature. CHIMEI INNOLUX Date :2011/12/01 Page:18/21 5. General Precautions 6.1. Safety Liquid crystal is poisonous. Do not put it in your mouth. If liquid crystal touches your skin or clothes, wash it off immediately by using soap and water. 6.2. Handling 1. The LCD panel is plate glass. Do not subject the panel to mechanical shock or to excessive force on its surface. 2. The polarizer attached to the display is easily damaged. Please handle it carefully to avoid scratch or other damages. 3. To avoid contamination on the display surface, do not touch the module surface with bare hands. 4. Keep a space so that the LCD panels do not touch other components. 5. Put cover board such as acrylic board on the surface of LCD panel to protect panel from damages. 6. Transparent electrodes may be disconnected if you use the LCD panel under environmental conditions where the condensation of dew occurs. 7. Do not leave module in direct sunlight to avoid malfunction of the ICs. 6.3. Static Electricity 1. Be sure to ground module before turning on power or operating module. 2. Do not apply voltage which exceeds the absolute maximum rating value. 6.4. Storage 1. Store the module in a dark room where must keep at 25±10℃ and 65%RH or less. 2. Do not store the module in surroundings containing organic solvent or corrosive gas. 3. Store the module in an anti-electrostatic container or bag. 6.5. Cleaning 1. Do not wipe the polarizer with dry cloth. It might cause scratch. 2. Only use a soft sloth with IPA to wipe the polarizer, other chemicals might permanent damage to the polarizer. CHIMEI INNOLUX 6. Mechanical Drawing Date :2011/12/01 Page:19/21 CHIMEI INNOLUX Date :2011/12/01 Page:20/21 7. Package Drawing 8.1 Packaging Material Table No Item Unit Weight Quantity (Kg) (pcs) 120.7× 76.3 × 3.1 TBD 100 510 × 178 0.047 4 512 × 349 0.074 3 512 × 349 × 112 0.073 2 Model (Material) Dimensions(mm) EJ050NA-01G 1 LCM module 2 Corrugated Bar Corrugated Board B Corrugated Paper B Corrugated Paper 4 Partition BC Corrugated Paper 5 Dust-Proof Bag PE 700 × 530 0.060 1 6 A/S Bag PE 145 ×145 0.001 100 7 Carton Corrugated Paper 530 × 355 × 255 1.100 1 8 Total weight 3 TBD± 5%KG 8.2 Packaging Quantity (1) LCM quantity per Partition: 2 row x 25 pcs = 50pcs (2) Total LCM quantity in Carton: 2 layer x 50 pcs/Partition = 100 pcs Remark CHIMEI INNOLUX 8.3 Packaging Drawing Date :2011/12/01 Page:21/21
EJ050NA-01G-TP(带固定框) 价格&库存
很抱歉,暂时无法提供与“EJ050NA-01G-TP(带固定框)”相匹配的价格&库存,您可以联系我们找货
