Features
Applications
Built-in pull-up resistor
Power tools
High chopping frequency
Flow meters
Supports a wide voltage range
Valve and solenoid status
2.5 to 24V
BLDC motors with sensors
Operation from unregulated supply
Proximity sensing
Tachometers
Wide operating temperature range
Factory-programmed at end-of-line for optimum
Reverse battery protection
Over-voltage protection at all pins
Solid-state reliability
Small package
3-pin SIP
3-pin SOT-23
Description
The SC224X family, produced with BiCMOS technology,
is a chopper-stabilized Hall Effect Sensor that offers a
magnetic sensing solution with superior sensitivity stability
over temperature and integrated protection features.
Superior high-temperature performance is made possible
through dynamic offset cancellation, which reduces the
residual offset voltage normally caused by device over
molding, temperature dependencies, and thermal stress.
Each device includes on a single silicon chip a voltage
Output state
regulator, Hall-voltage generator, small-signal amplifier,
chopper stabilization, Schmitt trigger, and an output
circuit.
An onboard regulator permits with supply voltages of 2.5
to 24V which makes the device suitable for a wide range
of industrial and atuomotive applications
The device is available in a 3-pin SIP package (UA) and a
3-pin SOT-23 style package (SO). Both are lead (Pb) free,
with 100% matte tin leadframe plating.
Device Information
Part Number
Packing
Mounting
Ambient, TA
BOP(Typ.)
BRP(Typ.)
SC2242UA
Bulk, 1000 pieces/bag
SIP3
SC2242SO
Reel, 3000pieces/reel
SOT-23
-40℃ to 150℃
+2.0mT
-2.0mT
SC2246UA
SIP3
-40℃ to 150℃
+4.0mT
-4.0mT
SC2248UA
SIP3
-40℃ to 150℃
+8.0mT
-8.0mT
-2-
Terminal configuration and functions
Terminal
Name
Number
Type
Description
2.5 to 24 V power supply
UA
SO
VDD
1
1
PWR
GND
2
3
Ground
Ground terminal
OUT
3
2
Output
Internal pull-up resistor
-3-
Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted) (1)
Parameter
Symbol
Min.
Max.
Units
Power supply voltage
VDD
-28(2)
28
V
Output terminal voltage
VOUT
-0.5
28
V
Output terminal current sink
ISINK
mA
Operating ambient temperature
TA
-40
150
Maximum junction temperature
TJ
-55
165
TSTG
-65
175
Storage temperature
(1)
Stresses above those listed here may cause permanent damage to the device. Exposure to absolute maximum rating
conditions for extended periods may affect device reliability.
(2)
Ensured by design.
ESD Protection
Human Body Model (HBM) tests according to: standard AEC-Q100-002
Parameter
ESD-Protection
Symbol
Min.
Max.
Units
VESD
-4
4
KV
Thermal Characteristics
Symbol
Parameter
RθJA
UA Package thermal resistance
RθJA
SO Package thermal resistance
Test Conditions
Single-layer PCB, with copper limited to
solder pads
solder pads
-4-
Rating
Units
166
℃/W
228
℃/W
Electrical Characteristics
over operating free-air temperature range (VDD = 5.0V, unless otherwise noted)
Symbol
(1)
Parameter
Test Conditions
Min.
Typ.
Max.
Units
VDD
Operating voltage(1)
TJ < TJ(Max.)
2.5
24
V
VDDR
Reverse supply voltage
IDD < -10mA, TA=25℃
-10
V
IDD
Operating supply current
VDD=2.5 to 24 V, TA=25℃
1.2
1.6
2.0
mA
VDD=2.5 to 24 V, TA=125℃
1.3
1.7
2.1
mA
ton
Power-on time
25
40
µS
5.0
10
15
KΩ
Output Hi-Z
3
µA
VDD=5V, IO=10mA, TA=25℃
Ω
VDD=5V, IO=10mA, TA=125℃
30
Ω
RUP
IQL
Off-state leakage current
RDS(on)
FET on-resistance
td
Output delay time
B=BRP to BOP
15
25
µS
tr
Output rise time (10% to 90%)
R1=1Kohm Co=50pF
0.2
0.5
µS
tf
Output fall time (90% to 10%)
R1=1Kohm Co=50pF
0.1
0.2
µS
Maximum voltage must be adjusted for power dissipation and junction temperature, see Thermal Characteristics
-5-
Magnetic Characteristics
Symbol
Parameter
fBW
Bandwidth
Test Conditions
Min.
Typ.
Max.
Units
kHz
+1.0
+2.0
+3.0
mT
-3.0
-2.0
-1.0
mT
3.0
4.0
5.0
mT
-1.0
mT
+2.0
+4.0
+6.0
mT
-6.0
-4.0
-2.0
mT
6.0
8.0
10.0
mT
-2.0
mT
+6.0
+8.0
+10.0
mT
-10.0
-8.0
-6.0
mT
14.0
16.0
18.0
mT
-2.0
mT
SC2242 +2.0 / -2.0 mT
BOP
Operated point
BRP
Release point
BHYS
Hysteresis
BO
Magnetic offset
TA=25℃
BO=(BOP+BRP)/2
SC2246 +4.0 / -4.0 mT
BOP
Operated point
BRP
Release point
BHYS
Hysteresis
BO
Magnetic offset
TA=25℃
BO=(BOP+BRP)/2
SC2248 +8.0 / -8.0 mT
BOP
Operated point
BRP
Release point
BHYS
Hysteresis
BO
Magnetic offset
TA=25℃
BO=(BOP+BRP)/2
1mT=10Gs
Magnetic flux density, B, is indicated as a negative value for North-polarity magnetic fields, and as a positive value for
South-polarity magnetic fields.
-6-
Characteristic Data
-7-
Characteristic Data (Continued)
-8-
-9-
Function Description Overview
The SC224X device is a chopper-stabilized Hall sensor with a digital latched output for magnetic sensing applications.
The device can be powered with a supply voltage between 2.5 and 24V, and continuously survives continuous -10V
reverse-battery conditions. The device does not operate when -10 to 2.2V is applied to the VDD terminal (with respect
to the GND terminal). In addtion, the device can withstand voltages up to 40V for transient durations.
The output of SC224X switches low (turns on) when a magnetic field (South polarity) perpendicular to the Hall element
exceeds the operate point threshold, BOP. After turn-on, the output is capable of sinking 20mA and the output voltage is
VQ(sat). When the magnetic field is reduced below the release point, BRP, the device output goes high (turns off). The
difference in the magnetic operate and release points is the hysteresis, BHYS, of the device. This built-in hysteresis
allows clean switching of the output even in the presence of external mechanical vibration and electrical noise.
Functional Block Diagram
- 10 -
Field Direction Definition
A positive magnetic field is defined as a South pole near the marked side of the package.
Transfer Function
Powering-on the device in the hysteresis region, less than BOP and higher than BRP, allows an indeterminate output
state. The correct state is attained after the first excursion beyond BOP or BRP. If the field strength is greater than BOP,
then the output is pulled low. If the field strength is less than BRP, the output is released.
BOP—magnetic threshold for activation of the device output, turning in ON (low) state
BRP—magnetic threshold for release of the device output, turning in OFF (high) state.
BHYS= BOP - BRP
- 11 -
Typical Application
The SC224X contains an on-chip voltage regulator and can operate over a wide supply voltage range. In applications
that operate the device from an unregulated power supply, transient protection must be added externally. For
applications using a regulated line, EMI/RFI protection may still be required. R1 is for improved CI performance, and
could be 100 or 200 Ω typically.
Select a vaule for CL based on the system bandwidth specifications as:
2 × 𝑓 (𝐻𝑧) =
1
2π × 𝑅 × C
Most applications do not require this CL filtering capacitor.
- 12 -
Mechanical Dimensions
- 13 -
- 14 -
