OH Series hall IC—OH9253
OH9253 Omnipolar Hall-Effect Switch
General Description:
Part Number:OH9253
Temperature Range:-40 to 125°C Package: 3000pcs/reel
OH9253 Hall-effect sensor is a temperature stable, stress-resistant switch,including the following items
on a single silicon chip: voltage regulator, Hall voltage generator, small-signal amplifier, chopper
stabilization, Schmitt trigger, open-drain output. Advanced CMOS wafer fabrication processing is used to
take advantage of low-voltage requirements, component matching, very low input-offset errors, and small
component geometries.
Features
Applications
• CMOS Hall IC Technology
• Solid state switch
• Solid-State Reliability much better than reed switch
• Omni polar output switches with absolute value
• Lid close sensor for power supply devices
• Magnet proximity sensor for reed switch replacement
of North or South pole from magnet
• Omipolar hall IC in high duty cycle applications.
• Low power consumption(2.6mA)
• Safety Key Revolution counter
• High Sensitivity for reed switch replacement
• Speed sensor
• ESD HBM ±4KV Min
• Position Sensor
• COST competitive
• Rotation Sensor
Absolute Maximum Ratings (TA=25℃)
Supply Voltage VCC·············· 6V
Supply Current (Average) ICC ············2.6 mA
Output Voltage VOUT ··············6V
Output Current IOUT ··············25 mA
Storage Temperature
·············-55
to 150 °C
Junction Temperature
Output Voltage vs. Magnetic Flux Density
············150
°C
Typical Application
Page 1
Nanjing Ouzhuo Technology co., Ltd
Tel:86-25-83247886,FAX: 86-25-52312738
Website: www.ohhallsensor.com www.zbling.com
E-mail: sale@ohhallsensor.com
ouzhuo@zbling.com
Functional Block Diagram
NOTE : Electronic semiconductor products are sensitive to Electro Static Discharge (ESD). Always
observe Electro Static Discharge control procedures whenever handling semiconductor products.
Electrical Characteristics
Vcc =5V, TA=25°C, unless otherwise specified
Value
Parameter
Symbol
Supply Voltage
VCC
Supply Current
Icc
Output Current
IOUT
Output Leakage Current
ILEAK
BBOPS,VOUT=low(output on)
GS
North pole to branded side
BOPN
B>BOPN,VOUT=low(output on)
-60
-30
GS
5
25
GS
South pole to branded side
BRPS
Release Point
BRPN
Hysteresis
B
很抱歉,暂时无法提供与“OH9253-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.85728
- 50+1.49440
- 150+1.33888
