H8118 Synchronous Step-Up DCDC Converter with PFM Control
Features
External parts:Coil, capacitor
Accuracy of ±2%
Output voltage: Settable to between
High efficiency :95%
2.1V to 5.5V in 0.1V steps
Package: SOT23-5 and SOT89
Maximum Oscillation
frequency :300KHz
Applications
Digital cameras
Cameras , video equipment
Electronic notebooks and PDAS
Communications equipment
Portable CD/MD players
Power supply for microcomputers
General Description
an external coil, capacitor. The built-in
DC/DC Converter with PFM Control.
MOSFET is turned off by a protection circuit
With the H8118 Series, a step-up switching
when the voltage at the LX pin exceeds the
DC/DC converter can be configured by using
limit to prevent it from being damaged.
IN
The H8118 Series is a Synchronous step-up
SI
PR
O
Block Diagram
Order Information
H8118①②③④⑤
Designator
Ver1.5
Symbol
Description
①
A
②③
Integer
④
P
⑤
M5
R
Package:SOT23-5
RoHS / Pb Free
G
Halogen Free
Standard
Output Voltage(2.1V~5.5V)
e.g:3.3V=②:3;③:3
Package:SOT89
1
Shanghai Siproin Microelectronics Co.
Pin Assignment
Table1 H8118A series (SOT23-5 PKG)
4
5
PIN NO.
PIN NAME
FUNCTION
1
EN
Shutdown pin
“H”: Normal operation
“L”: Step-up stopped
1
2
3
SOT23-5(Top View)
2
VOUT
Output voltage pin
3
NC
(N.C.)
4
GND
GND pin
5
LX
External inductor connection pin
IN
Table2 H8118A series (SOT89 PKG)
PIN NO.
PIN NAME
FUNCTION
1
GND
GND pin
VOUT
Output voltage pin
1
PR
O
2
2
3
3
LX
SOT89(Top View)
Absolute Maximum Ratings
(Unless otherwise specified, Ta=25℃)
SYMBOL
RATINGS
UNITS
VOUT Pin Voltage
VOUT
VSS-0.3~VSS+8
V
EN Pin Voltage
EN
VSS-0.3~VSS+8
V
LX Pin Voltage
VLX
VSS-0.3~VSS+8
V
LX Pin Current
ILX
1000
mA
250
mW
500
mW
SI
PARAMETER
Power
SOT23-5
Dissipation
SOT-89-3
PD
Operating Temperature
TOPR
-40~+85
Storage Temperature
TSTG
-40~+125
Soldering Temperature & Time
TSOLDER
260℃,10s
Note: These are stress ratings only. Stresses exceeding the range specified under “Absolute Maximum
Ratings” may cause substantial damage to the device. Functional operation of this device at other
conditions beyond those listed in the specification is not implied and prolonged exposure to extreme
conditions may affect device reliability.
Ver1.5
2
Electrical Characteristics
(Unless otherwise specified,Ta = 25℃)
PARAMETER
SYMBOL
Output Voltage
VOUT
Input Voltage
VIN
Operation Start Voltage
VST1
VST1
Input Current At No
Current Consumption
During Shutdown
Maximum Oscillation
CONDITION
V
7.5
V
0.9
V
IOUT=1mA, VOUT =2.2V~4.2V
1.2
V
IOUT=1mA, VOUT =4.2V~5.5V
15
25
uA
VIN=1.8V, VOUT=3.0V
25
35
uA
VIN=0.9V, VOUT=3.0V
ISS2
6
10
uA
VOUT=VOUT(s)+0.5V
ISSS
×0.98
VOUT
VOUT(S)
×1.02
300
Duty1
70
78
EFF1
uA
KHz
PR
O
fosc
1.0
85
90
VSH
0.75
V
VSL1
0.3
V
Shutdown Pin Input
Voltage
VEN=0V
VOUT=0.95xVOUT(s), measure
Waveform at LX pin
VOUT=0.95xVOUT(s)
SI
Efficiency
UNITS
VOUT(S)
MAX
IN
Current Consumption 2
Duty Ratio1
TYP
ISS
Load
Frequency
MIN
VOUT=0.95xVOUT(s), judge
Oscillation at LX pin
stop at LX pin
Shutdown Pin input
ISH
-0.1
0.1
uA
VEN=6V
Current
ISL
-0.1
0.1
uA
VEN=0V
Remark: VOUT(S) specified above is the set output voltage value,and VOUT is the typical value of the
actual output voltage
Application Circuits
1) H8118A without CE
Ver1.5
3
2) H8118A with CE
1)
L=47uH(Sumida)
2)
CF=47uF/16V(Tantalum)
IN
Note:External Component Recommendation:
PR
O
TYPICAL PERFORMANCE CHARACTERISTICS
SI
(Cin=Cout=100uF,L=47uH)
Ver1.5
4
Package Information
SI
PR
O
IN
5-pin SOT23-5L Outline Dimensions
Ver1.5
5
SI
PR
O
IN
3-pin SOT89-3 Outline Dimensions
Ver1.5
6
很抱歉,暂时无法提供与“H8118A40PR”相匹配的价格&库存,您可以联系我们找货
