SMD Power Inductors
-YSPIT0430A Series
■ Features
● Molding Inductor.
● High reliability.
● High current,low DCR,high efficiency.
● Very low acoustic noise and very low leakage flux noise.
● Operating temperature:-55℃ ~ +125℃(Including self-temperature rise).
■ Applications
● General Electronic.
● Video Device,TV,TFT.
● Power Module for PC.
● NB/Lap Top Computer.
● Server,VGA Card/Module.
● DC/DC converter.
■ Product Identification
⑴ :Type
⑵ :Dimensions
⑶ :Inductance value
⑷ :Inductance Tolerance:N=±30%,M=±20%
■ Shapes and Dimensions (Unit:mm)
TYPE
A
YSPIT0430A 4.1±0.3
B
C
D
4.1±0.3
2.8±0.2
3.4±0.3
深圳市益嘉源电子有限公司
http://www.yjycoin.com
E
F
0.88±0.3 1.7±0.3
G Ref.
H Ref.
L Ref.
1.4
3.8
3.4
-1-
SMD Power Inductors
-YSPIT0430A Series
■ YSPIT0430A Series
Inductance
(uH)
@100KHz/0.1V
DCR Max.
(mΩ)
YSPIT0430A-R47M
0.47±20%
YSPIT0430A-R90M
Part Number
Saturation Current (A)
Heat Rating Current
Typ.(A)
Max.
Typ.
20℃ rise
40℃ rise
7.3
15.0
17.0
10.0
14.0
0.90±20%
10.1
9.0
10.0
8.2
11.2
YSPIT0430A-1R0M
1.0±20%
10.1
9.2
9.8
8.0
11.0
YSPIT0430A-1R2M
1.2±20%
11.5
8.7
9.2
7.8
9.8
YSPIT0430A-1R5M
1.5±20%
13.2
7.0
8.0
7.0
9.0
YSPIT0430A-2R2M
2.2±20%
22.6
6.1
7.0
6.0
7.8
YSPIT0430A-3R3M
3.3±20%
28.6
5.3
6.2
5.0
6.6
YSPIT0430A-4R7M
4.7±20%
44.1
4.0
4.5
3.9
5.1
YSPIT0430A-6R8M
6.8±20%
74.1
3.0
3.6
3.0
3.9
※ The saturation current value is the DC current value having inductance decrease down to 30%.(at 25℃)
※ The temperature rise current value is the DC current value having temperature increase up to 40℃. (at
25℃)
※ The rated current is the DC current value that satisfies both of current value saturation current value and
temperature rise current value.
深圳市益嘉源电子有限公司
-2-
SMD Power Inductors
-YSPIT0430A Series
■ Mechanical Reliability
Item
Specification and Requirement
Solderability
1. No case deformation
or change in visual
2. New solder coverage
More than 95%
Mechanical
shock
or change in visual
2. △L/Lo≦±10%
Mechanical
vibration
or change in visual
2. △L/Lo≦±10%
Test Method
1.Preheat:155℃±5℃ ,60S±2S
2.Tin: lead-free.
3.Temperature:240℃±5℃,flux 3.0S±0.5S.
1. Acceleration: 100G
2. Pulse time::6ms
3. 3 times in each positive and negative
direction of 3 mutual perpendicular directions
1. Reflow: 2times
2. Frequency: 10HZ~50HZ~10HZ,20
Min/Cycles
3. Amplitude: 1.52 mm±10%
4. Directions: X,Y,Z
5. Time: 12 cycle / direction
■ Endurance Reliability
Item
Inductance change:
Within ± 10% Without distinct
Thermal Shock
damage in visual
Biased
Humidity
Low
temperature
storage
High
temperature
storage
Inductance change:
damage in visual
Inductance change:
damage in visual
Inductance change:
damage in visual
深圳市益嘉源电子有限公司
Test Method
1. First -55℃ for 30 minutes,last 125℃ for 30
minutes as 1 cycle. Go through 1000 cycles.
2. Max transfer time is 3 minutes.
3. Measured at room temperature after placing
for 24±2 hours
1.Reflow 2 times,
2.85℃±3℃,85%±3%RH,1000 hours
3.Measured at room temperature after placing
for 24±2 hours
1. Temperature:-55 ± 2℃
2. Time:1000 hours
for 24±2 hours
1. Temperature:+125 ± 2℃
2. Time:1000 hours
distinct
for 24±2 hours
-3-
SMD Power Inductors
-YSPIT0430A Series
■ Recommended Soldering Technologies
Re-flowing Profile
Preheat condition: 150 ~200℃/60~120sec.
Allowed time above 217℃: 60~90sec.
Peak temp: 260℃
Max time at Peak temp: 10 sec.
Solder paste: Sn/3.0Ag/0.5Cu
Allowed Reflow time: 2x max
Iron Soldering Profile
3sec. Max.
Pre-heating: 150℃/60sec.
350℃
Soldering Iron
Power: max. 30W
Diameter of Soldering
Iron 1.0mm max.
Tc ℃
深圳市益嘉源电子有限公司
Iron soldering power: Max. 30W
Soldering Tip temperature: 350℃ Max.
Soldering time: 3sec. Max.
Max.1 times for iron soldering
-4-
SMD Power Inductors
-YSPIT0430A Series
■ Taping Dimensions(Unit:mm)
TYPE
W
P
P0
P2
D0
D1
T
A0
B0
K0
E
F
MPQ
YSPIT0430A
12.0
±0.3
8.0
±0.1
4.0
±0.1
2.0
±0.1
1.5
±0.1
1.5
±0.1
0.35
±0.05
4.5
±0.1
4.5
±0.1
3.3
±0.1
1.75
±0.1
5.5
±0.1
2000
■ Reel Dimensions(Unit:mm)
TYPE
W
W1
W2
W3
YSPIT0430A
330±2.0
12.4±2.0
18.4MAX
11.9 Min
深圳市益嘉源电子有限公司
A
13.0±0.5
B
21.0±0.8
C
2.0±0.5
D
97±0.5
-5-
SMD Power Inductors
-YSPIT0430A Series
■ Direction of rolling
■ Cover tape peel off condition
Cover tape peel force shall be 0.1N to 1.3N.
Reference peel speed 300±10mm/min.
深圳市益嘉源电子有限公司
-6-
很抱歉,暂时无法提供与“YSPIT0420A-R56M”相匹配的价格&库存,您可以联系我们找货
