DTC124EE-MS
DTC124EE-MS
    MSKSEMI(美森科)
    SOT-523-3
    晶体管类型:1个NPN-预偏置 功率(Pd):200mW 最小输入电压(VI(on)@Ic/Io,Vce/Vo):3V@20mA,0.3V 最大输入电压(VI(off)@Ic/Io,Vce/Vcc):...
DTC124EE-MS 数据手册
www.msksemi.com DTCXXXXX-MS Semiconductor Compiance Features:  Simplifies Circuit Design  Reduces Board Space  Reduces Component Count  RoHS Compliant  Green EMC  Matte Tin(Sn) Lead Finish  Weight: approx. 0.002g SOT-523 Electrical Symbol: Absolute Maximum Ratings (TA = 25°C unless otherwise noted) Symbol Parameter Value Units VCBO Collector-Base Voltage 50 V VCEO Collector-Emitter Voltage 50 V IC Collector Current 100 mA PD Power Dissipation 150 mW Thermal Resistance from Junction to Ambient 600 °C /W -55 to +150 °C RθJA TJ TSTG Junction & Storage Temperature Range These ratings are limiting values above which the serviceability of the device may be impaired. www.msksemi.com DTCXXXXX-MS Semiconductor Compiance Device Marking & Resistor Values: P/N Mark R1 (KΩ) R2 (KΩ) DTC114EE-MS 24 10 10 DTC124EE-MS 25 22 22 DTC144EE-MS 26 47 47 DTC114YE-MS 64 10 47 DTC114TE-MS 04 10 ∞ DTC143TE-MS 03 4.7 DTC123EE-MS 22 2.2 2.2 DTC143EE-MS 23 4.7 4.7 DTC143ZE-MS E23 4.7 47 DTC124XE-MS 45 22 47 DTC123JE-MS E42 2.2 47 Electrical Characteristics ∞ (T A = 25°C unless otherwise noted) Off Characteristics Symbol Parameter Test Condition Limits Min Typ Max Unit ICBO Collector-Base Cutoff Current VCB =50V, IE =0A - - 100 nA ICEO Collector-Emitter Cutoff Current VCE =50V, IB =0A - - 500 nA IEBO Emitter-Base Cutoff Current VEB =6.0V, IC =0A DTC114EE-MS - - 0.50 DTC124EE-MS - - 0.20 DTC144EE-MS - - 0.10 DTC114YE-MS - - 0.20 DTC114TE-MS - - 0.90 DTC143TE-MS - - 1.90 DTC123EE-MS - - 2.30 DTC143EE-MS - - 1.50 DTC143ZE-MS - - 0.18 DTC124XE-MS - - 0.13 DTC123JE-MS - - 0.20 V(BR)CBO Collector-Base Breakdown Voltage IC =10uA, IE =0A 50 - - V(BR)CEO Collector-Emitter Breakdown Voltage (Note 1) IC =2.0mA, IB =0A 50 - - mA Volts Volts Note 1: Pulse Test. Pulse width
DTC124EE-MS 价格&库存
很抱歉,暂时无法提供与“DTC124EE-MS”相匹配的价格&库存,您可以联系我们找货
