BCX56
BIPOLAR TRANSISTOR (NPN)
FEATURES
Complementary to BCX53
High Current
Low Voltage
For Stages of Audio Amplifiers Application
Surface Mount device
SOT-89
MECHANICAL DATA
Case: SOT-89
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.055 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Collector-Base Voltage
Collector-Emitter Voltage
Emitter-Base Voltage
Collector Current
Base Current
Peak Base Current
Collector Power Dissipation
Thermal Resistance From Junction To Ambient
Junction Temperature
Storage Temperature
ELECTRICAL CHARACTERISTICS
Parameter
Collector-base breakdown voltage
Collector-emitter breakdown voltage
Emitter-base breakdown voltage
Collector cut-off current
Emitter cut-off current
DC current gain
Collector-emitter saturation voltage
Base-emitter voltage
Transition frequency
CLASSIFICATION OF hFE
Rank
Range
Marking
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
Symbol
VCBO
VCEO
VEBO
IC
IB
IBM
PC
RθJA
TJ
TSTG
Value
100
80
5
1
0.1
0.2
500
250
150
-55 ~+150
Unit
V
V
V
A
A
A
mW
°C/W
°C
°C
(TA = 25°C unless otherwise specified)
Symbol Min Typ Max Unit
Conditions
V(BR)CBO
IC=100uA,IE=0
100
V
V(BR)CEO
IC=10mA,IB=0
80
V
V(BR)EBO
IE=10uA,IC=0
5
V
ICBO
0.1
uA VCB=60V, IE=0
IEBO
0.1
uA VEB=5V, IC=0
VCE=2V, IC=5mA
hFE1*
40
VCE=2V, IC=150mA
hFE2*
63
250
VCE=2V, IC=0.5A
hFE3*
25
IC=0.5A,IB=50mA
VCE(sat)*
0.5
V
VCE=2V, IC=0.5A
VBE*
1
V
fT
130
MHz VCE=5V,IC=10mA,f=100MHz
H
63-250
BH
K
63-160
BK
E-mail:hkt@heketai.com
L
100-250
BL
1/4
BCX56
Typical Characteristics
Static Characteristic
COLLECTOR CURRENT IC (mA)
250
DC CURRENT GAIN hFE
0.9mA
0.8mA
150
IC
COMMON EMITTER
VCE=2V
COMMON
EMITTER
Ta=25℃
1.0mA
200
hFE
1000
0.7mA
0.6mA
100
0.5mA
0.4mA
0.3mA
50
Ta=100℃
300
Ta=25℃
100
30
0.2mA
IB=0.1mA
2
3
4
COLLECTOR-EMITTER VOLTAGE
VCEsat
1000
VCE
5
1
IC
VBEsat
1.0
BASE-EMMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMMITTER SATURATION
VOLTAGE VCEsat (mV)
IC
1000
(mA)
IC
β=10
300
100
Ta=100℃
Ta=25℃
30
10
0.8
Ta=25℃
Ta=100℃
0.6
0.4
1
10
100
COLLECTOR CURRENT
IC
1000
IC
1000
1
10
(mA)
100
COLLECTOR CURRENT
VBE
Cob/ Cib
300
COMMON EMITTER
VCE=2V
CAPACITANCE C (pF)
100
Ta=25℃
10
1
0.2
0.4
0.6
0.8
BASE-EMITTER VOLTAGE
500
fT
VBE
VCB/ VEB
f=1MHz
IE=0/IC=0
Ta=25℃
10
1
0.3
(V)
PC
600
100
COMMON EMITTER
VCE=5V
10
3
REVERSE BIAS VOLTAGE
IC
1000
(mA)
Cob
1
0.1
1.0
IC
Cib
100
Ta=100℃
COLLECTOR POWER DISSIPATION
PC (mW)
100
COLLECTOR CURRENT
β=10
TRANSITION FREQUENCY fT (MHz)
10
(V)
V
(V)
Ta
500
400
300
200
100
Ta=25℃
10
10
100
30
COLLECTOR CURRENT
IC
(mA)
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
2/4
BCX56
SOT-89 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.400
1.600
0.055
0.063
b
0.320
0.520
0.013
0.020
b1
0.400
0.580
0.016
0.023
c
0.350
0.440
0.014
0.017
D
4.400
4.600
0.173
0.181
D1
1.550REF
0.061REF
E
2.300
2.600
0.091
0.102
E1
3.940
4.250
0.155
0.167
e
1.500TYP
0.060TYP
e1
3.000TYP
0.118TYP
L
0.900
1.200
0.035
0.047
SOT-89 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
BCX56
SOT-89 Tape and Reel
SOT-89 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOT-89
4.85
4.45
1.85
Ø1.50
1.75
5.50
4.00
8.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOT-89 Tape Leader and Trailer
SOT-89 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
13.20
16.50
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“BCX56 BH HD”相匹配的价格&库存,您可以联系我们找货
