LINEAR INTEGRATED CIRCUIT
UTC3843D/E
CURRENT MODE PWM CONTROL
CIRCUITS
DESCRIPTION
The UTC3843D/E provides the necessary features to
implement off-line or DC to DC fixed frequency current mode
control schemes with a minimal external parts count. Internally
implemented circuits include under-voltage lockout featuring
start up current less than 1mA,a precision reference trimmed
for accuracy at the error amp input, logic to insure latched
operation, a PWM comparator which also provides current limit
control,and a totem pole output stage designed to source or
sink high peak current.The output stage, suitable for driving N
channel MOSFETs,is low in the off state.
DIP-8
SOP-8
FEATURES
*Optimized for off-line and DC to DC converts
*Low start up current(15mA
ON/OFF Command
to rest of IC
7
Von=8.4V
Voff=7.6V
5k )
INTERNAL
CLOCK
Timing Resistance Vs Frequency
100
100
td ( s)
CT=1nF
RT (k )
CT=2.2nF
10
CT=4.7nF
10
CT=10nF
CT=22nF
1
CT=47nF
CT=100nF
1
0.1
1
10
10
100
2
10
3
10
4
10
5
10
6
Frequency (Hz)
CT (nF)
YOUWANG ELECTRONICS CO.LTD
5
2006.07.11
UTC3843
SHUTDOWN TECHNIQUES
1k
Shutdown UTC3843D/E can be accomplished by
two methods;either raise pin 3 above 1V or pull Pin
1 b el ow a volt age t w o diode drops above
ground.Either method caused the output of PWM
comparator to be high(refer to block diagram).The
PWM latch is reset dominant so that the output will
rem ain low until the next clock cycle after the
shutdown condition at pins a and/or 3 is removed .In one example, an externally latched shut down may be accomplished by adding an SCR
which be reset by cycling Vcc below the lower
UVLO threshold. At this point tyhe reference turns
off allowing the SCR to reset.
1
8
330
Shutdown
500
3
Shutdown
To current
Sense resistor
TYPICAL PERFORMANCE CHARACTERISTICS
Vref Temperature Drift
Istart Temperature Drift
5.02
550
Vref (V)
5.01
500
Vcc=15V
Io=1mA
Vcc=9V
450
Istart (mA)
5.00
4.99
400
4.98
350
4.97
300
4.96
-50
-25
50
75
100
125
250
-50
150
-25
50
75
100
125
150
T
T
15
Icc (mA)
14
Vcc=15V
Io=1mA
13
12
11
10
9
-50
-25
50
75
100
125
150
T
Icc Temperature Drift
6
2006.07.11
UTC3843
4
100
80
Voltage Gain (dB)
Saturation Voltage (V)
3
2
a
2
5
5
a
60
-45
40
-90
PHASE (Degree)
Vcc=15V
T
T
1
0.1
1
10
Output Current
(Sourse or Sink Current) (A)
2
10
10
3
10
4
10
5
10
6
10
7
Frequency (Hz)
Output Saturation Characteristics
Error Amplifier Open-Loop
Frequency Response
7
2006.07.11
UTC3843
PACKAGE DIMENSIONS
DIP-8-300-2.54
SOP-8-225-1.27
8
2006.07.11
UTC3843
Attach
Revision History
Data
REV
1.0
2006.07.11
1.1
Description
Page
Original
Add “OREDRING INFORMATION”and package outline”SOP-8”
9
1,8
2006.07.11
很抱歉,暂时无法提供与“UTC3843D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.09631
- 50+0.85936
- 150+0.76994
- 500+0.65826
- 2000+0.60858
- 4000+0.57878
