HX1001
HX3141
Tiny Package, High Efficiency, Step-up
DC/DC Converter
Features
Description
Input Voltage Range: 1.1V ~ 5.5V
The HX3141 is a compact, high efficiency, and
Internal MOSFET with High Switch
low voltage step-up DC/DC converter including
Current up to 3A
an error amplifier, ramp generator, comparator,
90% Efficiency
switch pass element and driver in which
Up to 450kHz Switching Frequency
providing a stable and high efficient operation
SOT-23-6L Package
Applications
PDA
DSC
LCD Panel
RF-Tags
MP3
Portable Instruments
Wireless Equipments
w w w. h x s e m i . c o m
over a wide range of load currents. It operates in
stable
waveforms
without
external
compensation.
The high switching rate minimized the size of
external
components.
Besides,
the
low
quiescent current together with high efficiency
maintains long battery lifetime. The output
voltage is set with two external resistors.
The HX3141 is available in the industry
standard SOT-23-6L power packages.
1
HX3141
Typical Application Circuit
*VOUT = 1.212V • [1 + (R1/R2)].
Figure 1: (1.1V Stat-up Input Voltage)
Absolute Maximum Ratings (Note 1)
Supply Voltage…………………………………………………………………………..….…−0.3V ~ 6V
SW Pin Switch Voltage………………………………………………………………..………−0.3V ~ 6V
Other I/O Pin Voltages……………………………………………………………………...…−0.3V ~ 6V
SW Pin Switch Current ………………………………………………………………...………………..4A
Operating Junction Temperature…………………………………………………….…-40℃ ~ +125℃
Storage Temperature Range ………………………………………………………….−65℃ ~ +150℃
Lead Temperature (Soldering 10 sec.) …………………………………………………………...+ 265℃
Note 1: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device.
Exposure to absolute maximum rating conditions for extended periods may remain possibility to affect device reliability.
Pin Description
www.hxsemi.com
PIN
NAME
FUNCTION
1/3
GND
Ground
2
SW
Switch Node for Output
4
FB
Feedback
5
VDD
Input Positive Power Pin
6
EN
ON/OFF Control(High Enable)
2
HX3141
Electrical Characteristics
Operating Conditions: TA = 25°C, VIN = 1.5V, VDD set to 3.3V, unless otherwise specified.
SYMBOL
VSTART
VIN
INO LOAD
PARAMETER
Start-up Voltage
CONDITIONS
ILOAD=1mA
Operating Voltage range
VIN=1.5V, VOUT=3.3V
VFB
Feedback Reference Voltage
Close Loop, VDD=3.3V
fOSC
Switching Frequency
VDD=3.3V
RON
SW ON Resistance
VDD=3.3V
Line Regulation
ΔVLOAD
Load Regulation
VENH
En Input High
VENL
En Input Low
www.hxsemi.com
TYP
MAX
1.1
1.1
No Load Current (VIN)
ΔVLINE
MIN
V
5.5
70
1.182
VIN=1.5V ~ 2.5V,
ILOAD=100mA
VIN=2.5V,
ILOAD=1mA ~ 300mA
1.212
UNITS
V
μA
1.242
V
450
kHz
0.07
Ω
25
mV/V
0.05
mV/mA
1
V
0.6
V
3
HX3141
Typical Performance Characteristics
Efficiency vs. Output Current
(VOUT=5V)
100
100
90
90
80
70
80
VIN =3V
VIN =2V
VIN =4.2V
60
Efficiency (%)
Efficiency (%)
(Vout=3.3V)
50
40
30
40
30
10
10
1200 1600
2000 2400
Output Current (mA)
320
640
960
1280
1600
Output Current (mA)
Supply Current vs. Supply Voltage
(VOUT=3.3V Io=0A)
(VOUT=5V Io=0A)
0.1
0.35
0.3
0.08
Supply Current(mA)
Supply Current(mA)
VIN =2V
50
VIN =1.5V
60
VIN =3V
70
0.25
0.2
0.15
0.1
0.06
0.04
0.02
0.05
1.5
2
2.5
3
3.5
4
Supply Voltage (V)
www.hxsemi.com
4.5
5
1.5
1.8
2.1
2.4
2.7
3
Supply Voltage (V)
4
HX3141
Output Voltage vs. Load Current
(VIN=3V,VOUT=5V)
5.1
(VIN=3V,VOUT=3.3V)
3.4
3.35
5
Output Voltage (V)
Output Voltage (V)
3.3
4.9
4.8
4.7
4.6
3.25
3.2
3.15
3.1
3.05
4.5
3
600
900
1200
1500
Load Current (mA)
640
960
1280
1600
Load Current (mA)
Pin Information
GND (Pin 1/3): Signal and Power Ground. Provide a short direct PCB path between GND and the (–)
side of the output capacitor(s).
SW (Pin 2): Switch Pin. Connect inductor between SW and VIN. Keep these PCB trace lengths as short
and wide as possible to reduce EMI and voltage overshoot.
FB (Pin 4): Feedback Input to the gm Error Amplifier. Connect resistor divider tap to this pin. The output
voltage can be adjusted from 1.8V to 5.5V by: VOUT = 1.212V • [1 + (R1/R2)]
VDD (Pin 5): Input Positive Power Pin.
EN (Pin 6): En Control Input. Forcing this pin above 1V enables the part. Forcing this pin below 0.6V
shuts down the device. Do not leave EN floating.
www.hxsemi.com
5
HX3141
Application Information
Output Voltage Setting
Referring to Typical Application Circuits, the output voltage of the switching regulator (VOUT) can be set
with Equation (1).
Feedback Loop Design
Referring to the Typical Application Circuits. The selection of R1 and R2 based on the trade-off between
quiescent current consumption and interference immunity is stated below:
Follow Equation (1)
Higher R reduces the quiescent current (Path current = 1.212V/R2), however resistors beyond
5MW are not Recommended.
Lower R gives better noise immunity, and is less sensitive to interference, layout parasitics, FB
node leakage, and improper probing to FB pin.
For applications without standby or suspend modes, lower values of R1 and R2 are preferred. For
applications concerning the current consumption in standby or suspend modes, the higher values of R1
and R2 are needed. Such high impedance feedback loop is sensitive to any interference, which requires
careful PCB layout and avoid any interference, especially to FB pin. To improve the system stability, a
proper value capacitor between FB pin and GND pin is suggested. An empirical suggestion is around
22pF.
PCB Layout Guide
PCB Layout shall follow these guidelines for better system stability:
A full GND plane without gap break.
VDD to GND noise bypass - Short and wide connection for the 20-100μF capacitor between Pin 5
and Pin 1.
VIN to GND noise bypass - Add a 10μF capacitor close to L1 inductor, when VIN is not an idea
voltage source.
Minimized FB node copper area and keep far away from noise sources.
www.hxsemi.com
6
HX3141
Packaging Information
SOT-23-6L Package Outline Dimension
Symbol
Dimensions In Millimeters
Min
Max
Dimensions In Inches
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
Subject changes without notice.
www.hxsemi.com
7
Information furnished by Hexin Semiconductor is believed to be accurate and reliable. However, no responsibility is assumed for its use.
很抱歉,暂时无法提供与“HX3141-AF”相匹配的价格&库存,您可以联系我们找货
