SHANGHAI
June 2006
MICROELECTRONICS CO., LTD.
MM1Z2V0~MM1Z120
Silicon Planar Zener Diodes
Revision:A
General Description
Features
Silicon planar zener diode in a small plastic SMD
z
z
SOD-123 package.
Total power dissipation: max. 500mW
Small plastic package suitable for surface
mounted design
z
Wide variety of voltage ranges: nom. 2.0 to 120V
z
Tolerance approximately ±5%
Functional diagram
SOD-123
Note: 1-Cathode;2-Anode
Absolute Maximum Ratings (Ta=25℃)
Symbol
Parameter
Value
Unit
Power Dissipation
500
mW
Tj
Junction Temperature
175
TS
Storage Temperature Range
-55 to +175
Zener Current see Table “Characteristics”
Ptot
Characteristics at Tamb=25℃
Thermal Resistance Junction to Ambient Air
Forward Voltage at IF=100mA
ShangHai Sino-IC Microelectronics Co., Ltd.
Symbol
Min.
Typ.
Max.
Unit
RthA
0.3
K/mW
VF
1
V
1.
MM1Z2V0~MM1Z120
Electrical Characteristics
Zener Voltage Range
Type
Vznom
IZT for VZT
Dynamic
Revers Leakage
Impedance
Current
ZZ(Max) at IZ
IR(Max) at
Temp.
coefficient of
Zener Voltage
VR
TKvz
V
mA
V
Ω
mA
μA
V
%/K
MM1Z2V0
2.0
5
1.80…2.15
100
5
120
0.5
-0.09…-0.06
MM1Z2V2
2.2
5
2.08...2.33
100
5
120
0.7
-0.09…-0.06
MM1Z2V4
2.4
5
2.28...2.56
100
5
120
1.0
-0.09…-0.06
MM1Z2V7
2.7
5
2.5...2.9
110
5
120
1.0
-0.09…-0.06
MM1Z3V0
3.0
5
2.8...3.2
120
5
50
1.0
-0.08...-0.05
MM1Z3V3
3.3
5
3.1...3.5
130
5
-0.08...-0.05
MM1Z3V6
3.6
5
3.4...3.8
130
5
10
1.0
-0.08...-0.05
MM1Z3V9
3.9
5
3.7...4.1
130
5
10
1.0
-0.08...-0.05
MM1Z4V3
4.3
5
4.0...4.6
130
5
10
1.0
-0.06...-0.03
MM1Z4V7
4.7
5
4.4...5.0
130
5
10
1.0
-0.05...+0.02
MM1Z5V1
5.1
5
4.8...5.4
130
5
5
1.5
-0.02...+0.02
MM1Z5V6
5.6
5
5.2...6.0
80
5
5
2.5
-0.05...+0.05
MM1Z6V2
6.2
5
5.8...6.6
50
5
2
3.0
0.03...0.06
MM1Z6V8
6.8
5
6.4...7.2
30
5
2
3.5
0.03...0.07
MM1Z7V5
7.5
5
7.0...7.9
30
5
2
4.0
0.03...0.07
MM1Z8V2
8.2
5
7.7...8.7
30
5
2
5.0
0.03...0.08
MM1Z9V1
9.1
5
8.5...9.6
30
5
2
6.0
0.03...0.09
MM1Z10
10
5
9.4...10.6
30
5
2
7.0
0.03...0.1
MM1Z11
11
5
10.4…11.6
30
5
2
8.0
0.03…0.11
MM1Z12
12
5
11.4...12.7
35
5
2
9.0
0.03...0.11
MM1Z13
13
5
12.4...14.1
35
5
2
10
0.03...0.11
MM1Z15
15
5
13.8...15.6
40
5
2
11
0.03...0.11
MM1Z16
16
5
15.3...17.1
40
5
2
12
0.03...0.11
MM1Z18
18
5
16.8...19.1
45
5
2
13
0.03...0.11
MM1Z20
18.8...21.2
50
5
2
15
0.03...0.11
MM1Z22
22
5
20.8...23.3
55
5
2
17
0.04...0.12
MM1Z24
24
5
22.8…25.6
60
5
2
19
0.04…0.12
MM1Z27
27
5
25.1...28.9
70
2
2
21
0.04...0.12
MM1Z30
30
5
28...32
80
2
2
23
0.04...0.12
MM1Z33
33
5
31...35
80
2
2
25
0.04...0.12
MM1Z36
36
5
34...38
90
2
2
27
0.04...0.12
MM1Z39
39
2.5
37...41
100
2
2
30
0.04...0.12
MM1Z43
43
2.5
40...46
130
2
2
33
0.04...0.12
MM1Z47
47
2.5
44...50
150
2
2
36
0.04...0.12
MM1Z51
51
2.5
48…54
180
2
1
39
0.04…0.12
MM1Z56
56
2.5
52…60
180
2
1
43
0.04…0.12
MM1Z62
62
2.5
58…66
200
2
0.2
47
0.04…0.12
2.
MM1Z2V0~MM1Z120
Zener Voltage Range
Type
Vznom
IZT for VZT
Dynamic
Revers Leakage
Impedance
Current
ZZ(Max) at IZ
IR(Max) at
Temp.
coefficient of
Zener Voltage
VR
TKvz
V
mA
V
Ω
mA
μA
V
%/K
MM1Z68
68
2.5
64…72
250
2
0.2
52
0.04...0.12
MM1Z75
75
2.5
70...79
300
2
0.2
57
0.04...0.12
MM1Z82
82
2.5
77...87
300
2
0.2
63
0.05...0.12
MM1Z91
91
1
85...96
700
1
0.2
69
0.05...0.12
MM1Z100
100
1
94...106
700
1
0.2
76
0.05...0.12
MM1Z110
110
1
104...116
800
1
0.2
84
0.05...0.12
MM1Z120
120
1
114...127
900
1
0.2
91
0.05...0.12
1) VZ is tested with pulses (20 ms).
2) ZZ is measured at IZ by given a very small A.C. current signal.
Breakdown characteristics TJ=constant (pulse)
Fig 1
Fig 2
3.
MM1Z2V0~MM1Z120
SOD-123 Mechanical Data
Dimensions (mm are the original dimensions)
UNIT
A
A1
bP
c
D
E
HE
LP
Q
v
mm
1.15
0.1
0.6
0.135
2.7
1.65
4.0
0.4
0.77
0.2
1.05
0.127
2.6
1.55
3.6
0.2
0.67
Note
(1) The marking bar indicates the cathode.
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402 33932403 33932405 33933508 33933608
Fax: +86-21-33932401
Email: szrxw002@126.com
Website: http://www.sino-ic.net
4.
很抱歉,暂时无法提供与“MM1Z3V3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09647
- 500+0.07703
- 3000+0.06623
- 6000+0.05975
- 24000+0.05413
- 51000+0.05111
