BZT52C2V0 THRU BZT52C75
Silicon Planar Zener Diodes
PINNING
Features
• Total power dissipation: max. 500 mW
• Small plastic package suitable for surface mounted design
• Tolerance approximately ± 5%
PIN
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Simplified outline SOD-123 and symbol
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Power Dissipation
Ptot
500
mW
Junction Temperature
TJ
150
O
TStg
- 55 to + 150
O
Symbol
Max.
RthA
340
VF
0.9
Storage Temperature Range
C
C
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 10 mA
1 of 4
Unit
C/W
O
V
Zener Voltage Range 1)
Type
V znom
V
BZT52C2V0
BZT52C2V2
BZT52C2V4
BZT52C2V7
BZT52C3V0
BZT52C3V3
BZT52C3V6
BZT52C3V9
BZT52C4V3
BZT52C4V7
BZT52C5V1
BZT52C5V6
BZT52C6V2
BZT52C6V8
BZT52C7V5
BZT52C8V2
BZT52C9V1
BZT52C10
BZT52C11
BZT52C12
BZT52C13
BZT52C15
BZT52C16
BZT52C18
BZT52C20
BZT52C22
BZT52C24
BZT52C27
BZT52C30
BZT52C33
BZT52C36
BZT52C39
BZT52C43
BZT52C47
BZT52C51
BZT52C56
BZT52C62
BZT52C68
BZT52C75
2.0
2.2
2.4
2.7
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
1)
l ZT for
V ZT
mA
V
5
1.8...2.15
5
2.08...2.33
5
2.28...2.56
5
2.5...2.9
5
2.8...3.2
5
3.1...3.5
5
3.4...3.8
5
3.7...4.1
5
4...4.6
5
4.4...5
5
4.8...5.4
5
5.2...6
5
5.8...6.6
5
6.4...7.2
5
7...7.9
5
7.7...8.7
5
8.5...9.6
5
9.4...10.6
5
10.4...11.6
5
11.4...12.7
5
12.4...14.1
5
13.8...15.6
5
15.3...17.1
5
16.8...19.1
5
18.8...21.2
5
20.8...23.3
5
22.8...25.6
5
25.1...28.9
5
28...32
5
31...35
5
34...38
2.5
37...41
2.5
40...46
2.5
44...50
2.5
48...54
2.5
52...60
2.5
58...66
2.5
64...72
2.5
70...79
VZ is tested with pulses (20 ms).
ZZT is measured at IZ by given a very small A.C. current signal.
2)
2 of 4
Dynamic Impedance 2)
ZZT (Max.)
Ω
100
100
100
110
120
130
130
130
130
130
130
80
50
30
30
30
30
30
30
35
35
40
40
45
50
55
60
70
80
80
90
100
130
150
180
180
200
250
300
at I Z
mA
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
Reverse Leakage Current
I R (Max.)
μA
120
120
120
120
50
5
5
2
2
1
1
0.5
0.5
0.5
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
2
2
2
1
1
0.2
0.2
0.2
at VR
V
0.5
0.7
1
1
1
1
1
1
1
1
1.5
2.5
3
3.5
4
5
6
7
8
9
10
11
12
13
15
17
19
21
23
25
27
30
33
36
39
43
47
52
57
Breakdown characteristics
Tj = constant (pulsed)
mA
50
Tj=25o C
3V9
2V7
6V8
4V7
Iz
3V3
40
8V2
5V6
30
Test current Iz
5mA
10
3
2
4
5
6
8
7
9
10 V
Vz
mA
30
Tj=25 oC
10
12
Iz
15
22
27
Test current Iz
5mA
10
33
Vz
3 of 4
40 V
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
4 of 4
很抱歉,暂时无法提供与“BZT52C36”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10855
- 500+0.08829
- 3000+0.06905
- 6000+0.06229
- 24000+0.05643
- 51000+0.05328
