PZ1D4V2H
Zener Voltage Regulators
Description
The PZ1D4V2H is packaged in a SOD-123 surface mount package that
has a power dissipation of 500mW. They are designed to provide voltage
regulation protection and are especially attractive in situations where space
is at a premium.
Applications
Feature
Standard zener breakdown voltage range 5.1V
Cellular phones
SOD-123 package
Hand held portables
High density PC boards
Steady state power rating of 500mW
ESD rating of class 3(>16kV)per human body model
RoHS compliant transient
Mechanical Characteristics
Electronics Parameter
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Device meets MSL 1 requirements
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
I
IF
V
VZ VR
IR VF
IZT
Electrical characteristics per line@( unless otherwise specified)
Rev.06
Parameter
Symbol
Conditions
Reverse Zener Voltage
VZ
IZT = 5mA
Maximum Zener Impedance
ZZT
IZT = 5mA
55
Ω
ZZK
IZK =0.5mA
500
Ω
Reverse Leakage Current
IR
VR =4.2V
5
μA
Forward Voltage
VF
IF = 100mA
1.25
V
Max.Capacitance
C
VR=4V, f = 1MHz
300
pF
1
Min.
Typ.
Max.
5.1
Units
V
www.prisemi.com
PZ1D4V2H
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Total Device Dissipation FR-5 Board(Note 1)
PD
500
mW
Thermal Resistance,Juction-to-Ambient
RΘJA
340
℃/W
Storage Temperature
TJ,TSTG
-65 to +150
Typical Characteristics
1000
25℃ 0V 1MHz BIAS
C,Capacitance (pF)
IF,Forward Current(mA)
1000
100
10
100
10
25℃
1
1
0.6 0.7
0.8
0.9
1.0
1.1
1.2
1.3
1.4
4
5
10
Fig 1.Typical Forward Voltage
30
70
Fig 2. Typical Capacitance
10
100
Power Dissipation -%
IZ,Zener Current(mA)
VZ,Nominal Zener Voltage(V)
VF,Forward Voltage(V)
1
0.1
80
60
40
4
6
8
10
12
VZ, Zener Voltage(V)
50
75
100
125
150
Temperature - ℃
Fig 3.Zener Voltage versus Zener Current
Rev.06
Fig 4.Steady State Power Detating
2
www.prisemi.com
PZ1D4V2H
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
60
90
120
150
180
240
210
270
300
330
360
390
420
450
480
Time (sec)
Product dimension (SOD-123)
C
Inches
A
Millimeters
Dim
MIN
MAX
MIN
MAX
A
0.100
0.112
2.54
2.84
B
0.055
0.071
1.40
1.80
C
0.140
0.152
3.56
3.86
D
0.037
0.053
0.94
1.35
E
0.020
0.028
0.51
0.71
F
0.006
0.15
H
0.000
0.004
0.00
0.10
E
B
D
F
H
4.19
1.22
0.91
Rev.06
3
Unit:mm
www.prisemi.com
PZ1D4V2H
Ordering information
Rev.06
Device
Package
Shipping
PZ1D4V2H
SOD-123 (Pb-Free)
3000 / Tape & Reel
4
www.prisemi.com
PZ1D4V2H
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06
5
www.prisemi.com
很抱歉,暂时无法提供与“PZ1D4V2H”相匹配的价格&库存,您可以联系我们找货
