FAS101-M THRU FAS107-M
1.0A Surface Mount Fast
Recovery Rectifiers-50-1000V
Package outline
Features
• Batch process design, excellent power dissipation offers
SOD-123
better reverse leakage current and thermal resistance.
• Low profile surface mounted application in order to
optimize board space.
• Tiny plastic SMD package.
• High current capability.
• Fast switching for high efficiency.
• High surge current capability.
• Glass passivated chip junction.
• Lead-free parts meet RoHS requirments.
• Suffix "-H" indicates Halogen-free parts, ex. F
0.154(3.9)
0.138(3.5)
0.012(0.3) Typ.
0.075(1.9)
0.060(1.5)
S 101-M-H.
Mechanical data
0.067(1.7)
0.051(1.3)
• Epoxy : UL94-V0 rated flame retardant
• Case : Molded plastic, SOD-123 / MINI SMA
• Terminals :Plated terminals, solderable per MIL-STD-750,
0.028(0.7) Typ.
0.028(0.7) Typ.
Method 2026
• Polarity : Indicated by cathode band
• Mounting Position : Any
• Weight : Approximated 0.018 gram
Dimensions in inches and (millimeters)
Maximum ratings and Electrical characteristics (AT
PARAMETER
T A=25 oC unless otherwise noted)
CONDITIONS
Forward rectified current
See Fig.2
Forward surge current
8.3ms single half sine-wave (JEDEC methode)
V R = V RRM T J = 25 OC
Reverse current
Diode junction capacitance
UNIT
IO
1.0
A
I FSM
30
A
MIN.
TYP.
5.0
IR
V R = V RRM T J = 125 OC
Thermal resistance
MAX.
Symbol
Junction to ambient
R θJA
75
Junction to case
R θJC
55
CJ
15
f=1MHz and applied 4V DC reverse voltage
Storage temperature
T STG
SYMBOLS
*1
V RRM
(V)
V RMS*2
(V)
*3
VR
(V)
FAS101-M
50
35
50
FAS102-M
100
70
100
FAS103-M
200
140
200
FAS104-M
400
280
400
FAS105-M
600
420
600
FAS106-M
800
560
800
FAS107-M
1000
700
1000
*4
VF
(V)
Operating
temperature
T J, ( OC)
*5
t rr
(ns)
μA
100
O
pF
+175
-65
C/W
O
C
*1 Repetitive peak reverse voltage
*2 RMS voltage
150
*3 Continuous reverse voltage
1.30
-55 to +150
250
*4 Maximum forward voltage@I F=1.0A
*5 Maximum Reverse recovery time, note 1
500
Note 1. Reverse recovery time test condition, I F =0.5A, I R =1.0A, I RR =0.25A
Document ID
Page 1
A S-121202
Issued Date
2008/02/10
Revised Date
Revision
Page.
2010/03/10
D
7
Rating and characteristic curves (FAS101-M THRU FAS107-M)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
1.2
1.0
0.8
0.6
0.4
0.2
TJ=25 C
60
80
100
120
140
160
180
200
LEAD TEMPERATURE (°C)
Pulse Width 300us
1% Duty Cycle
0.1
.01
.6
.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PULSE
GENERATOR
(NOTE 2)
PEAK FORWAARD SURGE CURRENT,(A)
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
50
40
30
8.3ms Single Half
TJ=25 C
JEDEC method
10
5
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
-0.25A
100
FIG.5-TYPICAL JUNCTION CAPACITANCE
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
+0.5A
50
10
NUMBER OF CYCLES AT 60Hz
OSCILLISCOPE
(NOTE 1)
trr
Sine Wave
1W
NONINDUCTIVE
35
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
50
30
25
10
5
-1.0A
1cm
.01
SET TIME BASE FOR
.05
.1
.5
1
5
10
50
100
Revised Date
Revision
Page.
2010/03/10
D
7
REVERSE VOLTAGE,(V)
50 / 10ns / cm
Document ID
Page 2
A S-121202
Issued Date
2008/02/10
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
FAS101 -M
FAS102 -M
FAS103 -M
FAS104 -M
FAS105 -M
FAS106 -M
FAS107 -M
F1
F2
F3
F4
F5
F6
F7
Suggested solder pad layout
C
A
B
PACKAGE
A
B
C
SOD-123
0.075 (1.90)
0.055 (1.40)
0.075 (1.90)
Document ID
Page 3
A S-121202
Issued Date
2008/02/10
Revised Date
Revision
Page.
2010/03/10
D
3
很抱歉,暂时无法提供与“FAS103-M”相匹配的价格&库存,您可以联系我们找货
