Document: W0803066, Rev:D
WM02P06H
H
P-Channel MOSFET
Features
D
VDS= -20 V, ID = -0.66 A
RDS(on) < 0.52Ω @ VGS = -4.5 V
RDS(on) < 0.78Ω @ VGS = -2.5V
Enables High Density PCB Manufacturing
Low Voltage Drive Makes this Device Ideal for Portable
G
Equipment
Advanced Trench Process Technology
ESD Protected
S
SOT-723
Mechanical Characteristics
SOT-723 Package
Marking : Making Code
RoHS Compliant
Schematic & PIN Configuration
D
G
D
G
S
S
S
Device symbol
SOT-723(Top View)
Absolute Maximum Rating
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
-20
V
Gate-Source Voltage
VGS
±10
V
Continuous Drain Current
ID
-0.66
A
Pulsed Drain Current
IDM
-1.2
A
Power Dissipation
PD
150
mW
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 to +150
°C
Thermal Resistance from Junction to Ambient
RθJA
833
°C/W
©2019 WAYON Corporation
www.way-on.com
1 / 4
P Channel MOSFET
WM02P06H
Electrical Characteristics (Tamb=25°C unless otherwise noted)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
-20
V
Static Characteristics
Drain-Source Breakdown Voltage
BVDSS
Zero Gate Voltage Drain Current
IDSS
VDS = -20V, VGS = 0V
-1
µA
Gate-Body Leakage Current
IGSS
VDS = 0V, VGS = ±10V
±20
µA
VGS = -4.5V, ID = -0.66A
450
520
VGS = -2.5V, ID = -0.60A
650
780
VGS = -1.8V, ID = -0.50A
950
VDS = VGS, ID = -250µA
-0.3
-0.65
-1.1
113
15
Drain-Source On-State Resistance1
Gate Threshold Voltage1
RDS(on)
VGS(th)
VGS = 0V, ID = - 250µA
mΩ
V
Dynamic Characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
9
Turn-on Delay Time2
td(on)
9
Turn-on Rise Time2
tr
5.7
Turn-off Delay Time2
td(off)
32.6
20.3
-1.2
VGS = 0V, VDS = -16V, f = 1MHz
pF
Switching Characteristics
Turn- off Fall Time2
VDS = -10V, VGS = -4.5V,
ID = -0.2A, RG= 10Ω
tf
ns
Source-Drain Diode Characteristics
Body Diode Voltage
VDS
IS= -0.5A, VGS = 0V
V
Notes :
1) Pulse Test: Pulse Width < 300µs, Duty Cycle ≤2%.
2) Guaranteed by design, not subject to production testing
www.way-on.com
2 / 4
P Channel MOSFET
WM02P06H
Typical Characteristics
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
Figure 3. RDS(ON) vs. ID
Figure 4. RDS(ON) vs. VGS
Figure 5. IS vs. VSD
Figure 6. Threshold Voltage
www.way-on.com
3 / 4
P Channel MOSFET
WM02P06H
Outline Drawing – SOT-723
PACKAGE OUTLINE
D
D
b1
G
θ
S
E1 E
DIMENSIONS
C
e
SYMBOL
b
MIN
MAX
A
0.430
0.500
0.017
0.020
b
0.170
0.270
0.007
0.011
b1
0.270
0.370
0.011
0.015
C
0.080
0.150
0.003
0.006
D
1.150
1.250
0.045
0.049
E
1.150
1.250
0.045
0.049
E1
0.750
0.850
0.030
0.033
DIM
INCHES
MILLIMETERS
C
0.0118
0.30
M
0.0390
1.00
e
0.0157
0.40
e1
0.0314
0.80
b
0.0165
0.42
M
e
e1
e
0.400BSC
0.016 BSC
θ
7°REF
7°REF
Notes
DIMENSIONS
C
INCHES
MAX
b
A
MILLIMETER
MIN
1. Dimensioning and tolerances per ANSI
Y14.5M, 1985.
2. Controlling Dimension: Millimeters.
Marking Codes
Part Number
WM02P06H
Marking Code
06K
Package Information
Qty:8k/Reel
CONTACT INFORMATION
No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207
Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com
WAYON website: http://www.way-on.com
For additional information, please contact your local Sales Representative.
® is registered trademark of Wayon Corporation.
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time.
Users should verify actual device performance in their specific applications.
www.way-on.com
4 / 4
很抱歉,暂时无法提供与“WM02P06H”相匹配的价格&库存,您可以联系我们找货
