MMBT3906M
MMBT3906M
    DOESHARE(德芯)
    SOT-723-3
    PNP -40V -200mA 100-300 SOT-723
MMBT3906M 数据手册
MMBT3906M MMBT3906M PNP General Purpose Transistor General description • PNP General Purpose Transistor FEATURES • SOT-723 General Purpose Transistors. • VCEO -40V • Ic -200mA • PC 100mW • Complementary to MMBT3904M • Small Outline Surface Mount Package. • RoHS Compliant / Green EMC. Type MMBT3904M Marking 3N Absolute Maximum Ratings(Ta=25℃) Parameter Symbol Limit Unit Collector-Base Voltage VCBO -40 V Collector-Emitter Voltage VCEO -40 V Emitter-Base Voltage VEBO 5 V Collector Current -Continuous IC -0.2 A Power Dissipation PC 0.1 W Thermal Resistance from Junction to Ambient RθJA 1250 ℃/W Junction Temperature TJ 150 ℃ Storage Temperature TSTG -55~+150 ℃ www.doeshare.net MMBT3906M ELECTRICAL CHARACTERISTICS @ 25°C Unless Otherwise Specified Parameter Symbol Conditions Min Typ Max Units Collector-base breakdown voltage V(BR)CBO IC=10µA,IE=0 -40 V Collector-emitter breakdown voltage V(BR)CEO IC=1mA,IB=0 -40 V Emitter-base breakdown voltage V(BR)EBO IE=10µA,IC=0 -5 V Collector cut-off current ICEX VCE=-30V,VEB(off)=-3V -50 nA Emitter cut-off current IEBO VEB=-5V,IC=0 -100 nA DC current gain VCE=-1V,IC=-0.1mA 40 VCE=-1V,IC=-1mA 70 VCE=-1V,IC=-10mA 100 VCE=-1V,IC=-50mA 60 hFE -0.2 IC=-10mA,IB=-1mA Collector-emitter saturation voltage IC=-10mA,IB=-1mA -0.3 -0.65 V -0.85 V -0.95 V VBE(sat) IC=-50mA,IB=-5mA Transition frequency fT Output capacitance Cob Input capacitance Cib Noise figure NF www.doeshare.net V VCE(sat) IC=-50mA,IB=-5mA Base-emitter saturation voltage 300 VCE=-20V,IC=-10mA,f=100MHz VCB=-5V,IE=0,f=1MHz VEC =-0.5V,IC=0,f=1MHz VCE=-5V,IC=0.1mA,f=1MHz,RS=1kΩ MHz 300 4 pF 8 pF 5 dB MMBT3906M Parameter Symbol Delay time td Rise time tr Storage time Fall time www.doeshare.net ts tf Conditions VCC=-3V,VBE(off)=-0.5V, IC=10mA,IB1=-1mA Min Typ Max Units 35 ns 25 ns 225 ns 75 ns VCC=-3V,IC=-10mA IB1=IB2=1mA MMBT3906M TYPICAL CHARACTERICTIC www.doeshare.net MMBT3906M PACKAGE DIMENSIONS Symbol A Dimensions In Millimeters Min Max 1.100 1.300 B 0.8typ C 1.100 1.300 D 0.700 0.900 E 0.200 0.300 F 0.400 0.500 G 0.150 0.250 H 0.060 0.160 L 0.150 0.250 www.doeshare.net MMBT3906M Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
MMBT3906M 价格&库存
很抱歉,暂时无法提供与“MMBT3906M”相匹配的价格&库存,您可以联系我们找货
