PJ78M05TE
3-Terminal Voltage Regulator
Features
TO-252
Input voltage:up to 35V
Output voltage:5V
Output current up to 500 mA, internal thermal overload
protection and short-circuit current limiting.
1. VIN 2. GND 3. VOUT
Marking code
78M05: Product code
78M05
YW
78M05
YW
2022
2023
2024
2025
2026
2027
2028
2029
2030
2031
G
H
J
K
A
B
C
D
E
F
Y: Year code
Weaks
1~26
27~52
53
code
A~Z
a~z
z
W: Wek code
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
VI
35
V
Thermal Resistance,Junction-to-Air
RθJA
100
°C/W
Operating Temperature Range
TOPR
-40 to +125
°C
Storage Temperature Range
TSTG
-65 to +150
°C
Input Voltage
Vi
C1
0.33 µF
www.pingjingsemi.com
Revision:4.0 Feb-2022
1
PJ78M05TE
2
Vo
3
C2
0.1 µF
1/4
PJ78M05TE
Electrical Characteristics
Ratings at VI=10V,IO=350mA, CI=0.33μF,CO=0.1μF,TJ = 25℃, unless otherwise specified.
Parameter
Symbol
Min.
Typ.
Max.
4.8
5.0
5.2
VI=7V to 20V, 5mA≤IO≤350mA
4.75
5.0
5.25
VI=7V to 25V, IO=200mA
100
mV
VI=10V, 5mA≤IO≤200mA
50
mV
VI=10V,5mA≤IO≤500mA
100
mV
IO=350mA
2
V
6
mA
VI=10V, 5mA≤IO≤350mA
0.5
mA
8V≤VI≤25V, IO=200mA
0.8
mA
△VO/△T
IO=5mA, 0 ≤TJ ≤125°C
0.5
mV/°C
SVR
8V≤VI≤18V, f=120Hz,IO=300mA
62
dB
Output Noise Voltage
VN
10Hz≤f≤100Hz
40
μV
Short Circuit Current
ISC
VI=35V
200
mA
Output Voltage
VO
Line Regulation
△VO
Load Regulation
△VO
Dropout Voltage
VD
Quiescent Current
IQ
Quiescent Current Change
Output Voltage Drift
Supply Voltage Rejection
△IQ
Test Conditions
Unit
V
2/4
PJ78M05TE
Typical Characteristic Curves
7
5.6
IO=0mA
5
5.2
Output Voltage VO (V)
TJ=25℃
TJ=25℃
6
4
3
2
IO=0.2A、0.35A、0.5A
4.4
4.0
3.6
1
10
15
Input Voltage VI
25
30
3.2
5.8
35
6.2
6.4
6.6
Input Voltage VI
6.8
7.0
7.2
(V)
6
IO=0mA
VI=10V
TJ=25℃
TJ=25℃
Pulsed
5
VO (V)
4
3
Output Voltage
IQ (mA)
Quiescent Current
6.0
(V)
5
2
1
A
I =0
O
4.8
4
3
2
1
10
15
Input Voltage VI
25
30
35
0.5
1.0
1.5
2.0
2.5
Output Current IO (A)
(V)
7
1.50
VI=10V
IO=5mA
1.25
Power Dissipation PD (W)
6
Output Voltage
VO
(V)
5
4
3
2
0.75
0.50
0.25
1
1.00
50
Junction Temperature TJ
75
100
125
0.00
-25
50
75
100
125
3/4
PJ78M05TE
Package Outline
TO-252
Dimensions in mm
Symbol
*A
*A1
A2
*b
b1
*b3
b4
b5
*c
c1
*D
D1
*E
E1
*e
*H
L
L1
L2
*L3
*L4
L5
L6
θ
*θ1
θ2
K
mm
Nom.
2.30
-1.07
0.78
0.76
5.33
4.32
0.88
0.53
0.51
6.10
5.30REF
6.50
6.60
4.70
4.83
2.286BSC
9.90
10.10
1.40
1.50
2.90REF
0.51BSC
0.90
-0.60
0.80
1.70
1.80
0°
-5°
7°
5°
7°
0.40REF
带*为检验尺寸
Min.
2.20
0.00
0.97
0.72
0.71
5.23
4.27
0.72
0.47
0.46
6.00
Max.
2.38
0.10
1.17
0.85
0.81
5.46
4.37
0.93
0.58
0.56
6.20
6.70
4.92
10.30
1.70
1.25
1.00
1.90
0.123
8°
9°
9°
Ordering Information
Device
Package
Shipping
PJ78M05TE
TO-252
2,500PCS/Reel&13inches
4/4
很抱歉,暂时无法提供与“PJ78M05TE”相匹配的价格&库存,您可以联系我们找货
