LNG04R120
LNG04R120
    LONTEN(龙腾半导体)
    TO252
    类型:N沟道;漏源电压(Vdss):40V;连续漏极电流(Id):47A;功率(Pd):54W;导通电阻(RDS(on)@Vgs,Id):16mΩ@4.5V,10A;阈值电压(Vgs(th)@Id):...
LNG04R120 数据手册
LNH04R120/LNG04R120 Lonten N-channel 40V, 47A, 12mΩ Power MOSFET Description Product Summary These N-Channel enhancement mode power field VDSS 40V effect RDS(on).max@ VGS=10V 12mΩ ID 47A transistors are using trench DMOS technology. This advanced technology has been especially tailored to minimize on-state resistance, provide superior switching performance, and with stand high energy pulse in the avalanche and commutation mode. These devices are well suited Pin Configuration for high efficiency fast switching applications. Features  40V,47A,RDS(ON).max=12mΩ@VGS=10V  Improved dv/dt capability  Fast switching  100% EAS Guaranteed  Green device available D TO-251 TO-252 G S Applications  Motor Drives  UPS  DC-DC Converter N-Channel MOSFET Absolute Maximum Ratings Pb TC = 25°C unless otherwise noted Parameter Symbol Value Unit VDSS 40 V 47 A 30 A IDM 188 A Gate-Source voltage VGSS ±20 V Avalanche energy2) EAS 42 mJ Power Dissipation ( TC = 25°C ) PD 54 W TSTG -55 to +150 °C TJ -55 to +150 °C Symbol Value Unit RθJC 2.3 °C/W Drain-Source Voltage Continuous drain current ( TC = 25°C ) ID Continuous drain current ( TC = 100°C ) Pulsed drain current 1) Storage Temperature Range Operating Junction Temperature Range Thermal Characteristics Parameter Thermal Resistance, Junction-to-Case Version 1.0, 2018 1 www.lonten.cc LNH04R120/LNG04R120 Package Marking and Ordering Information Device Device Package Marking LNH04R120 TO-251 LNH04R120 LNG04R120 TO-252 LNG04R120 Electrical Characteristics Parameter TJ = 25°C unless otherwise noted Symbol Test Condition Min. Typ. Max. Unit Static characteristics Drain-source breakdown voltage BVDSS VGS=0 V, ID=250uA 40 --- --- V Gate threshold voltage VGS(th) VDS=VGS, ID=250uA 1.0 --- 2.0 V VDS=40 V, VGS=0 V, TJ = 25°C --- --- 1 μA VDS=32 V, VGS=0 V, TJ = 125°C --- --- 10 μA Drain-source leakage current IDSS Gate leakage current, Forward IGSSF VGS=20 V, VDS=0 V --- --- 100 nA Gate leakage current, Reverse IGSSR VGS=-20 V, VDS=0 V --- --- -100 nA VGS=10 V, ID=20 A --- 9.2 12 mΩ VGS=4.5 V, ID=10 A --- 11.8 16 mΩ VDS =5 V , ID=20A --- 49 --- S --- 1287 --- --- 165 --- Drain-source on-state resistance Forward transconductance RDS(on) gfs Dynamic characteristics Input capacitance Ciss Output capacitance Coss VDS = 20 V, VGS = 0 V, pF F = 1MHz Reverse transfer capacitance Crss --- 120 --- Turn-on delay time td(on) --- 14.8 --- --- 18.7 --- td(off) --- 73.5 --- Fall time tf --- 2.5 --- Gate resistance Rg --- 4.2 --- --- 6 --- --- 3.2 --- --- 24.2 --- IS --- --- 47 A ISM --- --- 188 A --- --- 1.2 V --- 18.2 --- ns --- 5.5 --- nC Rise time tr VDD = 20V,VGS=10V, ID =10 A Turn-off delay time VGS=0V, VDS=0V, F=1MHz ns Ω Gate charge characteristics Gate to source charge Qgs Gate to drain charge Qgd VDS=20V, ID=10A, nC VGS= 10V Gate charge total Qg Drain-Source diode characteristics and Maximum Ratings Continuous Source Current Pulsed Source Current 3) Diode Forward Voltage VSD Reverse Recovery Time trr VGS=0V, IS=10A, TJ=25℃ IS=10A,di/dt=100A/us, TJ=25℃ Reverse Recovery Charge Qrr Notes: 1: Repetitive Rating: Pulse width limited by maximum junction temperature. 2: VDD=20V, VGS=10V, L=0.5mH, IAS=13A, RG=25Ω, Starting TJ=25℃. 3: Pulse Test:Pulse Width ≤300μs, Duty Cycle≤2%. Version 1.0, 2018 2 www.lonten.cc LNH04R120/LNG04R120 Electrical Characteristics Diagrams Figure 1. Typ. Output Characteristics Drain current ID (A) From Bottom to Top Common Source Tc = 25°C Pulse test Common Source VDS=5 V Pulse test Drain current ID (A) VGS=4V, 4.5V, 5.5V, 6.5V, 8.5V,10V Figure 2. Transfer Characteristics VGS=3.5V VGS=3V Tc =125°C Tc = 25°C Drain−source voltage VDS (V) Gate−source voltage VGS (V) Figure 3. Capacitance Characteristics Figure 4. Gate Charge Waveform Ciss = Cgs + Cgd (Cds = shorted) Coss = Cds + Cgd Crss = Cgd Vgs = 10 V Vds = 20 V Gate-Source Voltage VGS (V) Capacitance (pF) Notes: f = 1 MHz VGS=0 V Ciss Coss Crss Drain-Source Voltage VDS (V) Total Gate Charge QG (nC) Figure 6. Rdson-Drain Current ON-Resistance Rdson (mohm) Reverse Drain current IS (A) Figure 5. Body-Diode Characteristics Tc =1 25°C Tc = 25°C Source-Drain Voltage VSD (V) Version 1.0, 2018 ID = 10 A VGS = 4.5V VGS = 10V Drain Current ID (A) 3 www.lonten.cc LNH04R120/LNG04R120 Figure 7. Rdson-Junction Temperature(℃) Figure 8. Maximum Safe Operating Area Normalized On-Resistance 10us Drain current I (A) Limited by R DC 1ms D VGS = 10V ID = 20A 100us DS(on) Notes: T = 25°C c T = 150°C j Single Pulse T -Junction Temperation (°C) Drain-Source Voltage V J DS (V) Normalized Transient θJC Z Thermal Resistance Figure 6. Normalized Maximum Transient Thermal Impedance (RthJC) Pulse Width t (s) Version 1.0, 2018 4 www.lonten.cc LNH04R120/LNG04R120 Test Circuit & Waveform Figure 8. Gate Charge Test Circuit & Waveform Figure 9. Resistive Switching Test Circuit & Waveforms Figure 10. Unclamped Inductive Switching (UIS) Test Circuit & Waveform Figure 11. Diode Recovery Circuit & Waveform Version 1.0, 2018 5 www.lonten.cc LNH04R120/LNG04R120 Mechanical Dimensions for TO-251 COMMON DIMENSIONS MM INCH SYMBOL MIN NOM MAX MIN NOM MAX A 2.20 2.30 2.38 0.087 0.091 0.094 A2 0.97 1.07 1.17 0.038 0.042 0.046 b 0.68 0.78 0.90 0.027 0.031 0.035 b2 0.00 0.04 0.10 0.000 0.002 0.004 b2' 0.00 0.04 0.10 0.000 0.002 0.004 b3 5.20 5.33 5.46 0.205 0.210 0.215 c 0.43 0.53 0.61 0.017 0.021 0.024 D 5.98 6.10 6.22 0.235 0.240 0.245 D1 5.30REF 0.209REF E 6.40 6.60 6.73 0.252 0.260 0.265 E1 4.63 - - 0.182 - - e 2.286BSC 0.090BSC H 16.22 16.52 16.82 0.639 0.650 0.662 L1 9.15 9.40 9.65 0.360 0.370 0.380 L3 0.88 1.02 1.28 0.035 0.040 0.050 L5 1.65 1.80 1.95 0.065 0.071 0.077 TO-251 Part Marking Information Lonten Logo Lonten LNH04R120 Part Number ABYWW99 “AB” Foundry & Assembly code “99” Manufacturing code “YWW” Date Code Version 1.0, 2018 6 www.lonten.cc LNH04R120/LNG04R120 Mechanical Dimensions for TO-252 COMMON DIMENSIONS MM INCH SYMBOL MIN NOM MAX MIN NOM MAX A 2.20 2.30 2.38 0.087 0.091 0.094 A1 0.00 - 0.20 0.000 - 0.008 A2 0.97 1.07 1.17 0.038 0.042 0.046 b 0.68 0.78 0.90 0.027 0.031 0.035 b3 5.20 5.33 5.46 0.205 0.210 0.215 c 0.43 0.53 0.61 0.017 0.021 0.024 D 5.98 6.10 6.22 0.235 0.240 0.245 D1 5.30REF 0.209REF E 6.40 6.60 6.73 0.252 0.260 0.265 E1 4.63 - - 0.182 - - e 2.286BSC 0.090BSC H 9.40 10.10 10.50 0.370 0.398 0.413 L 1.38 1.50 1.75 0.054 0.059 0.069 L1 2.90REF 0.114REF L2 0.51BSC 0.020BSC L3 0.88 - 1.28 0.035 - 0.050 L4 0.50 - 1.00 0.020 - 0.039 L5 1.65 1.80 1.95 0.065 0.071 0.077 θ 0° - 8° 0° - 8° TO-252 Part Marking Information Lonten Logo Lonten LNG04R120 ABYWW99 “AB” Foundry & Assembly code Part Number “99” Manufacturing code “YWW” Date Code Version 1.0, 2018 7 www.lonten.cc LNH04R120/LNG04R120 Disclaimer The content specified herein is for the purpose of introducing LONTEN's products (hereinafter "Products"). The information given in this document shall in no event be regarded as a guarantee of conditions or characteristics. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. LONTEN does not assume any liability for infringement of patents, copyrights, or other intellectual property rights of third parties by or arising from the use of the Products or technical information described in this document. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). LONTEN shall bear no responsibility in any way for use of any of the Products for the above special purposes. Although LONTEN endeavors to improve the quality and reliability of its products, semiconductor products have specific characteristics such as the occurrence of failure at a certain rate and malfunctions under certain use conditions. Please be sure to implement safety measures to guard them against the possibility of physical injury, and injury or damage caused by fire in the event of the failure of a LONTEN product. The content specified herein is subject to change for improvement without notice. When using a LONTEN product, be sure to obtain the latest specifications. Version 1.0, 2018 8 www.lonten.cc
LNG04R120 价格&库存
很抱歉,暂时无法提供与“LNG04R120”相匹配的价格&库存,您可以联系我们找货
