VBE16R02
VBE16R02
    VBSEMI(微碧)
    TO252
    类型:N沟道;漏源电压(Vdss):600V;连续漏极电流(Id):2A;功率(Pd):42W;导通电阻(RDS(on)@Vgs,Id):4.4Ω@10V,2A;阈值电压(Vgs(th)@Id):4V...
VBE16R02 数据手册
VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com Power MOSFET FEATURES PRODUCT SUMMARY • Halogen-free According to IEC 61249-2-21 Definition • Dynamic dV/dt Rating • Repetitive Avalanche Rated • Surface Mount (IRFRC20, SiHFRC20) • Straight Lead (IRFUC20, SiHFUC20) • Available in Tape and Reel • Fast Switching • Ease of Paralleling • Compliant to RoHS Directive 2002/95/EC 600 VDS (V) RDS(on) (Ω) VGS = 10 V Qg (Max.) (nC) 4.4 18 Qgs (nC) 3.0 Qgd (nC) 8.9 Configuration Single TO-251 TO-220AB D TO-220 FULLPAK TO-252 G G D S G D S Top View Top View VBM16R02 VBMB16R02 G D S S G D S Top View Top View VBE16R02 N-Channel MOSFET VBFB16R02 ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted PARAMETER Drain-Source Voltage Gate-Source Voltage Continuous Drain Current SYMBOL VDS VGS VGS at 10 V TC = 25 °C TC = 100 °C Currenta ID Pulsed Drain IDM Linear Derating Factor Linear Derating Factor (PCB Mount)e EAS Single Pulse Avalanche Energyb Repetitive Avalanche Currenta IAR Repetitive Avalanche Energya EAR TC = 25 °C Maximum Power Dissipation PD Maximum Power Dissipation (PCB Mount)e TA = 25 °C Peak Diode Recovery dV/dtc dV/dt Operating Junction and Storage Temperature Range TJ, Tstg Soldering Recommendations (Peak Temperature) for 10 s Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. VDD = 50 V, starting TJ = 25 °C, L = 37 mH, Rg = 25 Ω, IAS = 2.0 A (see fig. 12). c. ISD ≤ 2.0 A, dI/dt ≤ 40 A/μs, VDD ≤ VDS, TJ ≤ 150 °C. d. 1.6 mm from case. e. When mounted on 1" square PCB (FR-4 or G-10 material). LIMIT 600 ± 20 2.0 1.3 8.0 0.33 0.020 74 2.0 4.2 42 2.5 3.0 - 55 to + 150 260d UNIT V A W/°C mJ A mJ W V/ns °C * Pb containing terminations are not RoHS compliant, exemptions may apply 服务热线:400-655-8788 1 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com THERMAL RESISTANCE RATINGS SYMBOL MIN. TYP. MAX. Maximum Junction-to-Ambient PARAMETER RthJA - - 110 Maximum Junction-to-Ambient (PCB Mount)a RthJA - - 50 Maximum Junction-to-Case (Drain) RthJC - - 3.0 UNIT °C/W Note a. When mounted on 1" square PCB (FR-4 or G-10 material). SPECIFICATIONS TJ = 25 °C, unless otherwise noted PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static Drain-Source Breakdown Voltage VDS Temperature Coefficient Gate-Source Threshold Voltage VDS VGS = 0 V, ID = 250 μA 600 - - V ΔVDS/TJ Reference to 25 °C, ID = 1 mA - 0.88 - V/°C VGS(th) VDS = VGS, ID = 250 μA 2.0 - 4.0 V Gate-Source Leakage IGSS VGS = ± 20 V - - ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = 600 V, VGS = 0 V - - 100 VDS = 480 V, VGS = 0 V, TJ = 125 °C - - 500 Drain-Source On-State Resistance Forward Transconductance RDS(on) gfs ID = 1.2 Ab VGS = 10 V VDS = 50 V, ID = 1.2 A μA - 4.4 - Ω 1.4 - - S - 350 - - 48 - - 8.6 - - - 18 Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs - - 3.0 Gate-Drain Charge Qgd - - 8.9 Turn-On Delay Time td(on) - 10 - tr - 23 - - 30 - - 25 - - 4.5 - - 7.5 - - - 2.0 - - 8.0 - - 1.6 - 290 580 ns - 0.67 1.3 μC Rise Time Turn-Off Delay Time Fall Time td(off) VGS = 0 V, VDS = - 25 V, f = 1.0 MHz, see fig. 5 VGS = 10 V ID = 2.0 A, VDS = 360 V, see fig. 6 and 13b VDD = 300 V, ID = 2.0 A, Rg = 18 Ω, RD = 135 Ω, see fig. 10b tf Internal Drain Inductance LD Internal Source Inductance LS Between lead, 6 mm (0.25") from package and center of die contact pF nC ns D nH G S Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulsed Diode Forward Currenta ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Forward Turn-On Time ton MOSFET symbol showing the integral reverse p - n junction diode D A G S TJ = 25 °C, IS = 2.0 A, VGS = 0 Vb TJ = 25 °C, IF = 2.0 A, dI/dt = 100 A/μsb V Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD) Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width ≤ 300 μs; duty cycle ≤ 2 %. 服务热线:400-655-8788 2 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted Fig. 1 - Typical Output Characteristics, TC = 25 °C Fig. 2 - Typical Output Characteristics, TC = 150 °C Fig. 3 - Typical Transfer Characteristics Fig. 4 - Normalized On-Resistance vs. Temperature 服务热线:400-655-8788 3 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage Fig. 7 - Typical Source-Drain Diode Forward Voltage Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage Fig. 8 - Maximum Safe Operating Area 服务热线:400-655-8788 4 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com RD VDS VGS D.U.T. Rg + - VDD 10 V Pulse width ≤ 1 µs Duty factor ≤ 0.1 % Fig. 10a - Switching Time Test Circuit VDS 90 % 10 % VGS td(on) tr td(off) tf Fig. 9 - Maximum Drain Current vs. Case Temperature Fig. 10b - Switching Time Waveforms Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case 服务热线:400-655-8788 5 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com L Vary tp to obtain required IAS VDS VDS tp VDD D.U.T Rg + - I AS V DD VDS 10 V 0.01 Ω tp Fig. 12a - Unclamped Inductive Test Circuit IAS Fig. 12b - Unclamped Inductive Waveforms Fig. 12c - Maximum Avalanche Energy vs. Drain Current Current regulator Same type as D.U.T. 50 kΩ QG VGS 12 V 0.2 µF 0.3 µF QGS QGD + D.U.T. VG - VDS VGS 3 mA Charge IG ID Current sampling resistors Fig. 13a - Basic Gate Charge Waveform Fig. 13b - Gate Charge Test Circuit 服务热线:400-655-8788 6 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com Peak Diode Recovery dV/dt Test Circuit + D.U.T. Circuit layout considerations • Low stray inductance • Ground plane • Low leakage inductance current transformer + - - Rg • • • • + dV/dt controlled by Rg Driver same type as D.U.T. ISD controlled by duty factor “D” D.U.T. - device under test + - VDD Driver gate drive P.W. Period D= P.W. Period VGS = 10 Va D.U.T. lSD waveform Reverse recovery current Body diode forward current dI/dt D.U.T. VDS waveform Diode recovery dV/dt Re-applied voltage Inductor current VDD Body diode forward drop Ripple ≤ 5 % ISD Note a. VGS = 5 V for logic level devices Fig. 14 - For N-Channel 服务热线:400-655-8788 7 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com TO-220AB MILLIMETERS A E F D H(1) Q ØP 3 2 L(1) 1 M* L b(1) INCHES DIM. MIN. MAX. MIN. MAX. A 4.25 4.65 0.167 0.183 b 0.69 1.01 0.027 0.040 b(1) 1.20 1.73 0.047 0.068 c 0.36 0.61 0.014 0.024 D 14.85 15.49 0.585 0.610 E 10.04 10.51 0.395 0.414 e 2.41 2.67 0.095 0.105 e(1) 4.88 5.28 0.192 0.208 F 1.14 1.40 0.045 0.055 H(1) 6.09 6.48 0.240 0.255 J(1) 2.41 2.92 0.095 0.115 L 13.35 14.02 0.526 0.552 L(1) 3.32 3.82 0.131 0.150 ØP 3.54 3.94 0.139 0.155 Q 2.60 3.00 0.102 0.118 ECN: X12-0208-Rev. N, 08-Oct-12 DWG: 5471 Notes * M = 1.32 mm to 1.62 mm (dimension including protrusion) Heatsink hole for HVM C b e J(1) e(1) 8 服务热线:400-655-8788 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com TO-220 FULLPAK (HIGH VOLTAGE) A E A1 ØP n d1 d3 D u L1 V L b3 A2 b2 c b e MILLIMETERS DIM. A A1 A2 b b2 b3 c D d1 d3 E e L L1 n ØP u v ECN: X09-0126-Rev. B, 26-Oct-09 DWG: 5972 MIN. 4.570 2.570 2.510 0.622 1.229 1.229 0.440 8.650 15.88 12.300 10.360 INCHES MAX. 4.830 2.830 2.850 0.890 1.400 1.400 0.629 9.800 16.120 12.920 10.630 MIN. 0.180 0.101 0.099 0.024 0.048 0.048 0.017 0.341 0.622 0.484 0.408 13.730 3.500 6.150 3.450 2.500 0.500 0.520 0.122 0.238 0.120 0.094 0.016 2.54 BSC 13.200 3.100 6.050 3.050 2.400 0.400 MAX. 0.190 0.111 0.112 0.035 0.055 0.055 0.025 0.386 0.635 0.509 0.419 0.100 BSC 0.541 0.138 0.242 0.136 0.098 0.020 Notes 1. To be used only for process drawing. 2. These dimensions apply to all TO-220, FULLPAK leadframe versions 3 leads. 3. All critical dimensions should C meet Cpk > 1.33. 4. All dimensions include burrs and plating thickness. 5. No chipping or package damage. 服务热线:400-655-8788 9 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com TO-252AA CASE OUTLINE E MILLIMETERS A C2 e b2 D1 e1 E1 L gage plane height (0.5 mm) L4 b L5 H D L3 b3 C A1 INCHES DIM. MIN. MAX. MIN. MAX. A 2.18 2.38 0.086 0.094 A1 - 0.127 - 0.005 b 0.64 0.88 0.025 0.035 b2 0.76 1.14 0.030 0.045 b3 4.95 5.46 0.195 0.215 C 0.46 0.61 0.018 0.024 C2 0.46 0.89 0.018 0.035 D 5.97 6.22 0.235 0.245 D1 5.21 - 0.205 0.265 E 6.35 6.73 0.250 E1 4.32 - 0.170 - H 9.40 10.41 0.370 0.410 e 2.28 BSC 0.090 BSC e1 4.56 BSC 0.180 BSC L 1.40 1.78 0.055 0.070 L3 0.89 1.27 0.035 0.050 L4 - 1.02 - 0.040 L5 1.14 1.52 0.045 0.060 ECN: X12-0247-Rev. M, 24-Dec-12 DWG: 5347 Note • Dimension L3 is for reference only. 10 服务热线:400-655-8788 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com TOĆ251AA (DPAK) E A L2 b2 Dim A A1 b b1 b2 c c1 D E e L L1 L2 L3 D L3 L1 b1 L b MILLIMETERS c1 e c A1 INCHES Min Max Min Max 2.21 2.38 0.087 0.094 0.89 1.14 0.035 0.045 0.71 0.89 0.028 0.035 0.76 1.14 0.030 0.045 5.23 5.43 0.206 0.214 0.46 0.58 0.018 0.023 0.46 0.58 0.018 0.023 5.97 6.22 0.235 0.245 6.48 6.73 0.255 0.265 2.28 BSC 0.090 BSC 8.89 9.53 0.350 0.375 1.91 2.28 0.075 0.090 0.89 1.27 0.035 0.050 1.15 1.52 0.045 0.060 ECN: S-03946—Rev. E, 09-Jul-01 DWG: 5346 Note: Dimension L3 is for reference only. 服务热线:400-655-8788 11 VBM16R02 / VBMB16R02 VBE16R02 / VBFB16R02 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBE16R02 价格&库存
很抱歉,暂时无法提供与“VBE16R02”相匹配的价格&库存,您可以联系我们找货
VBE16R02
  • 50+2.41368
  • 300+2.35579
  • 1000+2.28974
