JST80N30T2A
30V N-Channel Mosfet
TO-252-2L
FEATURES
RDS(ON)≤ 5m Ω @VGS=10V
RDS(ON)≤ 7.5m Ω @VGS=4.5V
APPLICATIONS
Load Switch
PWM Application
Power Management
N-CHANNEL MOSFET
MARKING
YYMM:Date Code(year&month)
Absolute Maximum Ratings (TC=25℃ unless otherwise specified)
Symbol
bol
Param
Max.
Units
VDSS
Drain-Source Voltage
30
V
VGSS
Gate-Source Voltage
±20
V
TC = 25℃
90
A
TC = 100℃
58
A
360
A
250
mJ
90
W
1.67
℃/W
-55 to +175
ID
IDM
Continuous Drain Current
Pulsed Drain Current
note1
EAS
Single Pulsed Avalanche Energy
PD
Power Dissipation
RθJC
TJ, TSTG
note2
TC = 25℃
Thermal Resistance, Junction to Case
Operating and Storage Temperature Range
Version :J-B
1/5
JST80N30T2A
Electrical Characteristics (TC=25℃ unless otherwise specified)
Symbol
bol
Param
Test Condition
Min.
Typ.
Max.
Units
30
V
Off Characteristic
V(BR)DSS
Drain-Source Breakdown Voltage
VGS=0V,ID=250μA
A
IDSS
Zero Gate Voltage Drain Current
VDS =30V, VGS = 0V,
1.0
μA
IGSS
Gate to Body Leakage Current
VDS =0V,VGS = ±20V
±100
nA
Gate Threshold Voltage
VDS= VGS, ID=250μA
1
1.0
.0
1.5
2.5
V
On Characteristics
VGS(th)
RDS(on)
gFS
Static Drain-Source on-Resistance
VGS =10V, ID =20A
3.6
5
note3
VGS =4.5V, ID =15A
5
7.5
Forward Transconductance
VDS=5V, ID=15A
28
S
1950
pF
320
pF
240
pF
42
nC
4
nC
14
nC
13
ns
36
ns
43
ns
16
ns
mΩ
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain(“Miller”) Charge
ha
VDS =15V, VGS =0V,
f = 1.0MHz
VDS =25V, ID=20A,
VGS =10V
Switching Characteristics
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-off Delay Time
tf
Turn-off Fall Time
VDS=15V,
Rl=0.75Ω, RGEN=3Ω,
VGS=10V
Drain-Source Diode Characteristics and Maximum Ratings
IS
Maximum Continuous Drain to Source Diode Forward
Current
90
A
ISM
Maximum Pulsed Drain to Source Diode Forward Current
360
A
VSD
Voltage
1.2
V
16
ns
5
nC
trr
Body Diode Reverse Recovery Time
Qrr
Charge
VGS = 0V, IS=30A
3
IF=20A,dI/dt=100A/μs
Notes:1. Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature
2.. EAS condition TJ=25℃,VDD=30V,VG=10V,L=0.5mH,RG=25Ω
Version :J-B
2/5
JST80N30T2A
Typical Performance Characteristics
Figure 2: Typical Transfer Characteristics
Figure1: Output Characteristics
100
ID (A)
10V
80
100
7V
ID (A)
80
5V
3.5V
60
60
125℃
40
40
3V
25℃
VGS=2.5V
VDS(V)
2
3
4
5
VGS(V)
4.0
103
VGS=4.5V
4.0
102
TJ=150℃
VGS=10V
3.0
TJ=25℃
101
2.0
1.0
VGS=0V
ID(A)
40
100
0.2
Figure 5: Gate Charge Characteristics
10
8
6.0
5.0
IS(A)
RDS(ON) (mΩ)
5.0
3.0
Figure 4: Body Diode Characteristics
Figure 3:On-resistance vs. Drain Current
6.0
2.0
0.4
0.6
0.8
VSD(V)
1.0
1.2
1.4
1.6
1.8
Figure 6: Capacitance Characteristics
VGS(V)
2800
VDS=25V
ID=20A
C(pF)
2400
Ciss
2000
6
1600
1200
4
Coss
800
2
Qg(nC)
9
Version :J-B
18
Crss
VDS(V)
36
45
12
18
24
30
3/5
JST80N30T2A
Figure 7: Normalized Breakdown Voltage vs.
VBR(DSS)(V)
1.3
Figure 8: Normalized on Resistance vs.
RDS(on)(mΩ)
2.5
1.2
2.0
1.1
1.5
1.0
1.0
0.9
Tj (℃)
-50
100
150
200
Figure 9: Maximum Safe Operating Area
0.5
-100
-5
100
150
200
Figure 10: Maximum Continuous Drain Current
vs. Case Temperature
ID(A)
120
1000
Tj (℃)
ID(A)
Limited by R DS(on)
100
10μs
100μs
100
80
1ms
10ms
10
60
100ms
DC
40
TC=25℃
Single pulse
1
0.1
0.1
VDS (V)
10
1
50
Tc (℃)
75
100
125
150
175
Figure.11: Maximum Effective
Transient Thermal Impedance, Junction-to-Case
(TO-252)
101
ZthJ-C(℃/W)
100
10-1
PDM
D=0.5
t1
D=0.2
D=0.1
t2
D=0.05
D=0.02
D=0.01
Notes:
Single pulse 1.Duty factor D=t1/t2
2.Peak TJ=PDM*ZthJC+TC
TP(s)
10-2
10-3 -6
10
10-5
Version :J-B
10-4
10-3
10-2
10-1
100
101
4/5
JST80N30T2A
Version :J-B
5/5
很抱歉,暂时无法提供与“JST80N30T2A”相匹配的价格&库存,您可以联系我们找货
