SE6020DB
N-Channel Enhancement-Mode MOSFET
Revision: A
Features
General Description
Thigh Density Cell Design For Ultra Low
On-Resistance Fully Characterized Avalanche
Voltage and Current Improved Shoot-Through
For a single MOSFET
VDS = 60V
RDS(ON) = 24mΩ @ VGS=10V
FOM
Simple Drive Requirement
Small Package Outline
Surface Mount Device
Pin configurations
See Diagram below
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
Drain Current
Total Power Dissipation
Continuous
Pulsed
@TA=25℃
Operating Junction Temperature Range
ID
A
60
PD
45
W
TJ
-55 to 175
Thermal Resistance
Symbol
RθJC
Parameter
Thermal Resistance Junction to Case
ShangHai Sino-IC Microelectronic Co., Ltd.
Typ
Max
Units
3.3
℃/W
1.
SE6020DB
Electrical Characteristics
Symbol
(TJ=25℃ unless otherwise noted)
Parameter
Test Conditions
Min
Typ
Max
Units
OFF CHARACTERISTICS (Note 2)
BVDSS
Drain-Source Breakdown Voltage
ID=250μA, VGS=0 V
IDSS
Drain to Source Leakage Current
VDS=60V, VGS=0V
IGSS
Gate-Body Leakage Current
VGS=20V
VGS(th)
Gate Threshold Voltage
VDS= VGS, ID=250μA
RDS(ON)
Static Drain-Source On-Resistance
VGS=10V, ID=20A
Forward Transconductance
VDS=5V, ID=5A
gFS
60
V
1.2
24
1
μA
100
nA
2.5
V
30
mΩ
11
S
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VGS=0V, VDS=30V,
f=1MHz
500
pF
60
pF
25
pF
47
nC
6
nC
14
nC
5
ns
16.1
ns
SWITCHING PARAMETERS
Qg
Total Gate Charge
VGS=10V,
VDS=30V,
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
Turn-On Delay Time
VGS=10V, VDS=30V,
td(off)
Turn-Off Delay Time
RGEN=3Ω, ID=2A
td(r)
Turn-On Rise Time
2.6
ns
td(f)
Turn-Off Fall Time
2.3
ns
ID=4.5A
Source-Drain Ratings and Characteristics
IS
Diode Forward Current
VSD
Diode Forward Voltage
VGS=0V,IS=20A
trr
Reverse Recovery Time
TJ=25℃, IF=20A
35
ns
Qrr
Reverse Recovery Charge
Di/dt=100A/μs
53
nC
A
1.2
V
2.
SE6020DB
Test Circuits and Waveform
3.
SE6020DB
Typical Characteristics
4.
SE6020DB
5.
SE6020DB
Package Outline Dimension
TO-252
6.
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402
33932403
33932405
33933508
33933608
Fax: +86-21-33932401
Email: webmaster@sino-ic.net
Website: http://www.sino-ic.net
7.
很抱歉,暂时无法提供与“SE6020DB”相匹配的价格&库存,您可以联系我们找货
