HSU60N02
N-Ch 20V Fast Switching MOSFETs
Description
Product Summary
The HSU60N02 is the high cell density trenched Nch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSU60N02 meet the RoHS and Green Product
requirement, 100% EAS guaranteed with full
function reliability approved.
VDS
V
RDS(ON),typ
4
mΩ
ID
60
A
TO252 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Battery protection
Power management
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
±12
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1
60
A
ID@TC=100℃
43
A
IDM
Pulsed Drain Current2
200
A
EAS
Single Pulse Avalanche Energy3
180
mJ
PD@TC=25℃
Total Power Dissipation4
60
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient (Steady State)1
RθJA
RθJC
www.hs-semi.cn
Max.
Unit
50
℃/W
Thermal Resistance Junction-Ambient 1 (t ≤10s)
25
℃/W
Thermal Resistance Junction-Case1
2
℃/W
Ver 2.0
Typ.
1
HSU60N02
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
Reference to 25℃ , ID=1mA
0.028
V/℃
VGS=4.5V , ID=30A
4
5.5
VGS=2.5V , ID=15A
6
9
0.5
0.8
1
V
-6.16
mV/℃
VDS=20V , VGS=0V , TJ=25℃
1
VDS=20V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=10V , ID=20A
15
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.7
Qg
Total Gate Charge (4.5V)
83
Qgs
Gate-Source Charge
15
Qgd
Gate-Drain Charge
32
Turn-On Delay Time
10
Td(on)
Tr
Td(off)
Tf
VDS=20V , VGS=10V , ID=40A
Rise Time
VDD=15V , VGS=10V , RG=3.3
15
Turn-Off Delay Time
ID=15A
31
nC
ns
Fall Time
15
Ciss
Input Capacitance
2200
Coss
Output Capacitance
400
Crss
Reverse Transfer Capacitance
270
Min.
Typ.
Max.
Unit
60
A
220
A
VDS=20V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
Parameter
Conditions
IS
Continuous Source Current1,5
ISM
Pulsed Source Current2,5
VSD
Diode Forward Voltage2
VGS=0V , IS=30A , TJ=25℃
1.4
V
trr
Reverse Recovery Time
IF=30A , dI/dt=100A/µs ,
31
nS
Qrr
Reverse Recovery Charge
TJ=25℃
60
nC
VG=VD=0V , Force Current
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=20V,VGS=10V,L=0.1mH,IAS=45A
4.The power dissipation is limited by 175℃ junction temperature
5.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSU60N02
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSU60N02
www.hs-semi.cn
Ver 2.0
4
HSU60N02
www.hs-semi.cn
Ver 2.0
5
HSU60N02
Ordering Information
Part Number
HSU60N02
www.hs-semi.cn
Package code
TO252-2
Ver 2.0
Packaging
2500/Tape&Reel
6
很抱歉,暂时无法提供与“HSU60N02”相匹配的价格&库存,您可以联系我们找货
