AP60P02D
AP60P02D
    APM-MICROELECTRONICS(永源微)
    TO252
    类型:P沟道;漏源电压(Vdss):20V;连续漏极电流(Id):60A;功率(Pd):60W;导通电阻(RDS(on)@Vgs,Id):8Ω@4.5V,10A;阈值电压(Vgs(th)@Id):65...
AP60P02D 数据手册
AP60P02D -20V P-Channel Enhancement Mode MOSFET Description The AP60P02D uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 2.5V. This device is suitable for use as a Battery protection or in other Switching application. General Features VDS = -20V ID =-60A RDS(ON) < 12mΩ @ VGS=-4.5V (Type:8mΩ) Application Battery protection Load switch Uninterruptible power supply Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) AP60P02D TO-252-3L AP60P02D XXX YYYY 2500 Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter VDS VGS ID@TC=25℃ ID@TC=70℃ IDM PD@TC=25℃ PD@TC=70℃ Rating Units Drain-Source Voltage -20 V Gate-Source Voltage ±12 V Continuous Drain Current, VGS @ -4.5V1 -60 A Continuous Drain Current, VGS @ -4.5V1 -48 A Pulsed Drain Current2 -200 A Total Power Dissipation3 60 W Total Power Dissipation3 48 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ RθJA Thermal Resistance Junction-Ambient 1 75 ℃/W 40 ℃/W 3.6 ℃/W RθJA RθJC Thermal Resistance Junction-Ambient Thermal Resistance 1 (t Junction-Case1 ≤10s) 1 AP60P02D RVE1.0 永源微電子科技有限公司 AP60P02D -20V P-Channel Enhancement Mode MOSFET Electrical Characteristics (TJ=25℃, unless otherwise noted) Symbol Parameter Conditions Min. Typ. Max. Unit BVDSS Drain-Source Breakdown Voltage VGS=0V , ID=-250uA -20 -22 --- V △BVDSS/△TJ BVDSS Temperature Coefficient Reference to 25℃ , ID=-1mA --- -0.012 --- V/℃ RDS(ON) Static Drain-Source On-Resistance2 VGS=-4.5V , ID=-10A --- 8 12 RDS(ON) On-Resistance2 VGS=-2.5V , ID=-5.0A --- 11 116 -0.4 0.65 -1.0 V --- 2.94 --- mV/℃ Static Drain-Source mΩ VGS(th) Gate Threshold Voltage △VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current VDS=-20V , VGS=0V , TJ=25℃ --- --- 1 uA IGSS Gate-Source Leakage Current VGS=±12V , VDS=0V --- --- ±100 nA gfs Forward Transconductance VDS=-10V , ID=-10A 12 --- --- S Qg Total Gate Charge (-4.5V) --- 63 --- --- 9.1 --- VGS=VDS , ID =-250uA VDS=-10V , VGS=-4.5V , ID=10A Qgs Gate-Source Charge Qgd Gate-Drain Charge --- 13 --- Td(on) Turn-On Delay Time --- 10 --- Tr Rise Time --- 15 --- Td(off) Turn-Off Delay Time --- 110 --- Tf Fall Time --- 70 --- Ciss Input Capacitance --- 1600 --- Coss Output Capacitance --- 350 --- Crss Reverse Transfer Capacitance --- 300 --- VG=VD=0V , Force Current --- --- -50 A VGS=0V , IS=-15A , TJ=25℃ --- --- -1.2 V IS Continuous Source VSD Current1,4 Diode Forward Voltage2 VDD=-10V , VGS=-4.5V , RG=6.0Ω, ID=-1A VDS=-15V , VGS=0V , f=1MHz nC ns pF Note : 1、The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper. 2、The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3、The EAS data shows Max. rating . The test condition is VDD=-16V,VGS=-10V,L=0.1mH,IAS=12A 4、The power dissipation is limited by 150℃ junction temperature 5、The data is theoretically the same as I D and I DM , in real applications , should be limited by total power dissipation. 2 AP60P02D RVE1.0 永源微電子科技有限公司 AP60P02D -20V P-Channel Enhancement Mode MOSFET Typical Characteristics Figure 1:Power Dissipation Figure 3:Output Characteristics AP60P02D RVE1.0 Figure 4:Drain-Source On-Resistance Figure 6:Drain-Source On-Resistance 永源微電子科技有限公司 3 Figure 5:Transfer Characteristics Figure 2:Drain Current AP60P02D -20V P-Channel Enhancement Mode MOSFET Figure 7:Rdson vs Vgs Figure 9:Gate Charge Figure 8:Capacitance vs Vds Figure 10:Sourece-Drain Diode Forward Figure.11: Maximum Effective Transient Thermal Impedance, Junction-to-Case 4 AP60P02D RVE1.0 永源微電子科技有限公司 AP60P02D -20V P-Channel Enhancement Mode MOSFET Package Mechanical Data:TO-252-3L E Dimensions A B2 Ref. C2 Millimeters L V1 Min. 2.50 0.083 0.098 A2 0 0.10 0 0.004 B 0.66 0.86 0.026 0.034 B2 5.18 5.48 0.202 0.216 C 0.40 0.60 0.016 0.024 C2 0.44 0.58 0.017 0.023 D 5.90 6.30 0.232 0.248 6.80 0.252 Min. D H C DETAIL A V2 D1 V1 A2 V1 E1 5.30REF D1 G Max. 0.209REF E 6.40 E1 4.63 G 4.47 4.67 H 9.50 10.70 0.374 0.421 L 1.09 1.21 0.043 0.048 L2 1.35 1.65 0.053 0.176 7° V2 0.268 0.182 V1 L2 Typ. Max. 2.10 A B Typ. Inches 0° 0.184 0.065 7° 6° 0° 6° DETAIL A TO-252 Reel Spectification-TO-252 B D 0 P0 P2 Dimensions T E Ref. A B0 A D1 W F t1 K0 P1 A0 B B B 5° Φ3 29 A A 20 Φ13 Millimeters Inches Min. Typ. Max. Min. Typ. Max. W 15.90 16.00 16.10 0.626 0.630 0.634 E 1.65 1.75 1.85 0.065 0.069 0.073 F 7.40 7.50 7.60 0.291 0.295 0.299 D0 1.40 1.50 1.60 0.055 0.059 0.063 D1 1.40 1.50 1.60 0.055 0.059 0.063 P0 3.90 4.00 4.10 0.154 0.157 0.161 P1 7.90 8.00 8.10 0.311 0.315 0.319 P2 1.90 2.00 2.10 0.075 0.079 0.083 A0 6.85 6.90 7.00 0.270 0.271 0.276 B0 10.45 10.50 10.60 0.411 0.413 0.417 K0 2.68 2.78 2.88 0.105 0.109 0.113 T 0.24 t1 0.10 10P0 39.80 0.27 0.009 0.011 0.004 40.00 40.20 1.567 1.575 1.583 5 AP60P02D RVE1.0 永源微電子科技有限公司 AP60P02D -20V P-Channel Enhancement Mode MOSFET Attention 1,Any and all APM Microelectronics products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your APM Microelectronics representative nearest you before using any APM Microelectronics products described or contained herein in such applications. 2,APM Microelectronics assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all APM Microelectronics products described or contained herein. 3, Specifications of any and all APM Microelectronics products described or contained here instipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. 4, APM Microelectronics Semiconductor CO., LTD. strives to supply high quality high reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives that could give rise to smoke or fire, or that could cause damage to other property. Whendesigning equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design,and structural design. 5,In the event that any or all APM Microelectronics products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. 6, No part of this publication may be reproduced or transmitted in any form or by any means,electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of APM Microelectronics Semiconductor CO., LTD. 7, Information (including circuit diagrams and circuit parameters) herein is for example only; it is not guaranteed for volume production. APM Microelectronics believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. 8, Any and all information described or contained herein are subject to change without notice due to product/technology improvement,etc. When designing equipment, refer to the "Delivery Specification" for the APM Microelectronics product that you Intend to use. 6 AP60P02D RVE1.0 永源微電子科技有限公司 AP60P02D -20V P-Channel Enhancement Mode MOSFET Edition Date Change Rve1.0 2021/1/31 Initial release Copyright Attribution“APM-Microelectronice” 7 AP60P02D RVE1.0 永源微電子科技有限公司
AP60P02D 价格&库存
很抱歉,暂时无法提供与“AP60P02D”相匹配的价格&库存,您可以联系我们找货
