YFW30N06AD/NF
60V N-CHANNEL
CHANNEL ENHANCEMENT MODE MOSFET
MAIN CHARACTERISTICS
ID
30A
VDSS
60V
RDSON-typ(@VGS=10V)
<28m
28mΩ(Type:18 mΩ)
Features
Fast Switching
Low ON Resistance
Low Gate Charge
100% Single Pulse avalanche energy Test
RoHS2011/65/EUdirectives
LeadfreeincomplywithEURoHS2011/65/EU
TO
TO-252
Mechanical Data
Case: Molded plastic
Mounting Position: Any
Molded Plastic: UL Flammability Classification Rating 94V
94V-0
Solder bath temperature275℃maximum,10s
maximum,10s per JESD22
JESD22-106
PDFN5*6
PDFN5*6-8L
Product Specification Classification
Part Number
Package
Marking
Pack
YFW30N06AD
TO
TO-252
YFW 30N06AD XXXXX
2500PCS/Tape
YFW30N06NF
PDFN5*6
PDFN5*6-8L
YFW 30N06NF XXXXX
5000PCS/Tape
www.yfwdiode.com
1/5
GuangDong YFW Electronics Co, Ltd.
YFW30N06AD/NF
Maximum Ratings at Tc=25°C unless otherwise specified
Characteristics
Symbols
Value
Units
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
Continue Drain Current
ID
30
A
Pulsed Drain Current (Note1)
IDM
90
A
Power Dissipation
PD
35
W
Single Pulse Avalanche Energy (Note5)
EAS
50
mJ
Operating Temperature Range
TJ
150
°C
Storage Temperature Range
TSTG
-55 to +150
°C
Thermal Resistance, Junction to Case
RθJC
3
°C/W
Thermal Resistance, Junction to Ambient
RθJA
62
°C/W
Characteristics
Drain-Source Breakdown Voltage
Drain-Source Leakage Current
Test Condition
Symbols
Min
Typ
Max
Units
VGS = 0 V,ID = 250 μA
BVDSS
60
V
1
UA
10
UA
VDS = 60 V, VGS = 0 V
IDSS
VDS=60V Tc=125°C
Gate Leakage Current
Gate-Source Threshold Voltage
Drain-Source On-State Resistance(Note3)
Forward Transconductance
VGS = ± 20 V, VDS = 0 V
IGSS
±100
nA
VDS = VGS , ID = 250 μA
VGS(th)
1
2.5
V
18
28
mΩ
26
40
mΩ
S
VGS = 10 V, ID = 25 A
VGS = 4.5 V, ID = 10 A
VDS = 50 V, ID = 25A
Input Capacitance
Output Capacitance
VGS = 0 V, VDS = 25 V,
f =1MHz
Reverse Transfer Capacitance
Turn-on Delay Time
Rise Time
Turn-Off Delay Time
VDS =30V ,RL=1.5Ω
VGS = 10 V,RG = 3Ω,
(Note3,4)
Fall Time
Total Gate Charge
Gate to Source Charge
Gate to Drain Charge
www.yfwdiode.com
VDS = 30A, ID = 20 V,
VGS = 10 V(Note3,4)
RDS(on)
gfs
Ciss
1750
Coss
85
Crss
62
td(ON)
6
tr
3.1
td(OFF)
18
tf
3.1
QG
30
QGS
5.5
QGD
8.6
2/5
pF
nS
nC
YFW30N06AD/NF
Source-Drain Diode Characteristics at Ta=25°C unless otherwise specified
Characteristics
Test Condition
Symbols
Min
Typ
Max
Units
IS
30
A
ISM
90
A
ISD = 30 A
VSD
1.2
V
IS = IF
ISD =20 A, VGS = 0 V,
dIF / dt = 100 A/μs(Note3)
trr
40
nS
Qrr
65
uC
Maximun Body-Diode Continuous Current(Note2)
Maximun Body-Diode Pulsed Current
Drain-Source Diode Forward
Voltage(Note3)
Reverse Recovery Time
Reverse Recovery Charge
Note:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
5. EAS condition:Tj=25 ,VDD= ℃ 30V,VG=10V,L=0.1mH,Rg
www.yfwdiode.com
3/5
YFW30N06AD/NF
Ratings and Characteristic Curves
www.yfwdiode.com
4/5
YFW30N06AD/NF
Package Outline Dimensions millimeters
TO-252
Dim.
A
B
C
D
D1
E
E1
E2
B1
B2
O
L1
L2
L3
Min.
2.1
0.95
0.4
6.4
5.1
5.8
Max.
2.5
1.55
0.6
6.7
5.8
6.4
Typ 2.3
Typ 4.6
0.6
0.75
-9.0
1.3
0.70
0.8
0.95
0.15
11.0
1.7
0.95
All Dimensions in millimeter
PDFN5*6-8L
Dim.
A
B
C
C1
C2
E
L
L1
L2
R
Min.
4.8
0.25
1
Max.
5.2
0.35
1.2
Typ 0.254
Typ 0.254
Typ 1.27
6
5.7
6.3
6
Max 0.2
Typ 13°
www.yfwdiode.com
5/5
很抱歉,暂时无法提供与“YFW30N06AD”相匹配的价格&库存,您可以联系我们找货
