NP12N10G
100V N-Channel Enhancement Mode MOSFET
Description
Schematic diagram
The NP12N10G uses advanced trench technology
to provide excellent R DS(ON) and low gate charge.It can
be used in a wide variety of applications.
D
G
General Features
V DS =100V, I D =12A
R DS(ON) (Typ.)=105mΩ @V GS =10V
R DS(ON) (Typ.)=122mΩ @V GS =4.5V
High density cell design for ultra low Rdson
Fully characterized avalanche voltage and current
Good stability and uniformity with high E AS
Excellent package for good heat dissipation
Special process technology for high ESD
capability
S
Marking and pin assignment
TO-252-2L
(Top View)
Application
Automotive applications
Hard switched and high frequency circuits
Uninterruptible power supply
Package
XXXX—Wafer Information
YYYY—Quality Code
TO-252-2L
Ordering Information
Part Number
Storage Temperature
Package
Devices Per Reel
NP12N10G-G
-55°C to +150°C
TO-252-2L
2500
Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
parameter
symbol
limit
unit
Drain-source voltage
V DS
100
V
Gate-source voltage
V GS
±20
V
TC=25°C
Continuous Drain Current
TC=100°C
Pulsed Drain Current
(note1)
Avalanche energy( L=0.5mH)
Maximum power dissipation
TC=25°C
Operating junction Temperature range
Rev.1.1 —Oct. 26. 2017
1
ID
12
8
A
I DP
48
A
E AS
25
mJ
PD
50
W
Tj
-55—150
www.natlinear.com
NP12N10G
Electrical Characteristics (TA=25℃ unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
100
V
T J =25°C
1
T J =85°C
30
Static Characteristics
Drain-source breakdown voltage
BV DSS
V GS =0V, I D =250µA
Zero gate voltage drain current
I DSS
V DS =100V,
GS =0V
Gate Leakage Current
I GSS
V DS =0V, V GS =±20V
±100
nA
Gate threshold voltage
V GS(th)
V DS =V GS , I D =250µA
1
1.6
2.5
V
Drain-source on-state resistance1
R DS(ON)
V GS =10V, I D =12A
105
130
V GS =4.5V, I D =10A
122
150
12
A
12
A
22
ns
90
nC
730
36
On Status Drain Current
I D(ON)
VDS=100V, VGS=10V
µA
mΩ
Diode Characteristics
Diode Continuous Forward Current
IS
Reverse Recovery Time
trr
Reverse Recovery Charge
Qrr
IF=12A,
dI/dt=100A/us
Dynamic Characteristics2
Input capacitance
C ISS
V GS =0V ,V DS =50V
f=1.0MHz
Output capacitance
C OSS
Reverse transfer capacitance
C RSS
31
Turn-on delay time
t D(ON)
15
Turn-on Rise time
tr
5
Turn-off delay time
t D(OFF)
25
7
19
Turn-off Fall time
tf
Total gate charge
Qg
Gate-source charge
Q gs
Gate-drain charge
Q gd
V GS =10V, V DS =50V, I D =12A
V GS =10V,I D =12A
V DS =50V
pF
ns
nC
4.6
4.1
0.8
1.1
Drain-Source Diode Characteristics
Diode forward voltage
Note:
V SD
ISD=12A,VGS=0V
1:Eas test:VDD=50V,RG=50ohm,L=500uH
2:Pulse test; pulse width ≦ 300ns, duty cycle ≦ 2%.
3:Guaranteed by design, not subject to production testing.
2
www.natlinear.com
V
NP12N10G
Typical Performance Characteristics
30
25
24
ID-Drain Current(A)
ID-Drain Current(A)
27
21
10V
18
15
4.5V
12
9
6
3.3V
10
5
2.5V
3
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
0.0
5.0
0.5
180
1800
160
1600
VGS=4.5V
120
100
VGS=10V
80
60
2.0
2.5
3.0
3.5
4.0
4.5
5.0
1400
1200
1000
Ciss
800
600
40
400
Coss Crss
0.8
1.6
2.4
3.2
4.0
4.8
5.6
6.4
7.2
8.0
ID-Drain Current(A)
2
3
4
5
6
7
8
9
10
18
Vds Drain-Source Voltage(V)
Fig3 Rdson-Drain current
Fig4 Capacitance vs Vds
10
440
9
400
Vgs Gate-Source Voltage(V)
Rds- On Resistance(mR)
1.5
Fig2 Transfer Characteristics
2000
Capacitance(pF)
Rdson- On Resistance(mR)
Fig1 Output Characteristics
200
140
1.0
360
320
280
240
200
160
120
8
7
6
5
4
3
2
1
80
2
3
4
5
6
7
8
9
2
4
6
8
10
12
14
Qg Gate Charge(nC)
Fig5 Rdson-Gate Drain voltage
Fig6 Gate Charge
3
16
www.natlinear.com
NP12N10G
100
IS- Reverse Drain Current(A)
100
Power Dissipation (W)
90
80
70
60
50
40
30
30
45
60
75
90
105
120
135
150
1
0.1
0.0
TJ-Junction Temperature(ºC)
0.2
0.4
0.6
0.8
1.0
Vsd Source -Gate Voltage(V)
Fig7 Power De-rating
10
Fig8 Source-Drain Diode Forward
4
www.natlinear.com
1.2
NP12N10G
Package Information
TO-252-2L
5
www.natlinear.com
很抱歉,暂时无法提供与“NP12N10G-G”相匹配的价格&库存,您可以联系我们找货
