Green Product
MDT15N10
100V N-Channel Power MOSFET
DESCRIPTION
KEY CHARACTERISTICS
The MDT15N10 uses advanced trench technology to provide
● VDS = 100V,ID = 15A
excellent RDS(ON), low gate charge. It can be used in a
RDS(ON) < 90mΩ @ VGS=10V
RDS(ON) < 115mΩ @ VGS=4.5V
wide variety of applications.
● High density cell design for lower Rdson
Application
● Fully characterized avalanche voltage and current
●Power switching application
● Good stability and uniformity with high EAS
●Hard switched and High frequency circuits
● Excellent package for good heat dissipation
●Uninterruptible power supply
100% UIS TESTED!
100% DVDS TESTED!
TO-252-2L Top View
Schematic diagram
Package Marking And Ordering Information
Device Marking
MDT15N10
Ordering Codes
Package
MDT15N10
TO-252
Product Code
Packing
MDT15N10
Absolute Maximum Ratings (TA=25℃
Parameter
unless otherwise noted)
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
Drain Current-Continuous
ID
(Note
1)
Drain Current-Pulsed
IDM
Maximum Power Dissipation(Tc=25℃)
PD
(Note
2)
Single pulse avalanche energy
EAS
Operating Junction and Storage Temperature Range
TJ,TSTG
Reel
Limit
Unit
100
V
±20
V
15
A
40
A
31
W
21
mJ
-55 To 175
4.8
℃/W
Thermal Characteristic
Thermal Resistance,Junction-to-Case
Page1
RθJC
www.mns-kx.com
Priamry
Green Product
MDT15N10
Electrical Characteristics (TA=25℃ unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Off Characteristics
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=250μA
100
V
Zero Gate Voltage Drain Current
IDSS
VDS=100V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=250μA
1
1.8
2.4
V
Drain-Source On-State Resistance(Note 3)
RDS(ON)
VGS=10V, ID=5A
80
90
90
115
5
S
680
pF
110
pF
85
pF
10
nS
On Characteristics
Forward Transconductance
gFS
VGS=4.5V, ID=5A
VDS=25V,ID=3.6A
mΩ
Dynamic Characteristics
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Switching
VDS=25V,VGS=0V,
f=1.0MHz
Characteristics (Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=50V, ID=5A,
7
nS
td(off)
VGS=10V,RGEN=2.5Ω
34
nS
9
nS
16
nC
4
nC
5
nC
1.2
V
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=80V,ID=3A
VGS=10V
Drain-Source Diode Characteristics
Diode Forward Voltage
VSD
VGS=0V,IS=15A
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. EAS condition :T j=25℃,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production.
Page2
www.mns-kx.com
Priamry
Green Product
MDT15N10
Characteristics Curves
Page3
Figure 1 Output Characteristics
Figure 2 Transfer Characteristics
Figure 3 On-Resistance vs. ID and VGS
Figure 4 On-Resistance vs. Junction Temperature
Figure 5 On-Resistance vs. VGS
Figure 6 Body Diode Forward Voltage
www.mns-kx.com
Priamry
Green Product
MDT15N10
Figure 7 Gate-Charge Characteristics
Figure 9
Maximum Forward Biased Safe
Figure 8 Capacitance Characteristics
Figure 10 Single Pulse Power Rating
Operation Area
Figure 11
Page4
Junction-to-Ambient
Normalized Maximum Transient Thermal Impedance
www.mns-kx.com
Priamry
Green Product
MDT15N10
Test Circuit and Waveform
Gate Charge Test Circuit
Gate Charge Test Waveform
Resistive Switching Test Circuit
Resistive Switching Test Waveforms
Unclamped Inductive Switching (UIS) Test Circuit
Unclamped Inductive Switching (UIS) Test Waveforms
Diode Recovery Test Circuit
Page5
Diode Recovery Test Waveforms
www.mns-kx.com
Priamry
Green Product
MDT15N10
Package Description
Values(mm)
Items
MIN
MAX
A
6.30
6.90
A1
B
5.70
6.30
C
2.10
2.50
D
0.30
0.60
E1
0.60
0.90
E2
0.70
1.00
F
0.30
0.60
G
0.70
1.20
L1
9.60
10.50
L2
2.70
3.10
H
0.60
1.00
M
5.10
5.50
N
2.09
2.49
R
0 .3
T
1.40
1.60
Y
5.10
6.30
TO-252
Page6
Package
www.mns-kx.com
Priamry
很抱歉,暂时无法提供与“MDT15N10”相匹配的价格&库存,您可以联系我们找货
