ME6201A33PG
ME6201A33PG
    MICRONE(南京微盟)
    SOT89
    输出类型:固定;输出极性:正;输出通道数:1;最大输入电压:16V;输出电压:3.3V;压差:700mV@(50mA);输出电流:100mA;电源纹波抑制比(PSRR):-;
ME6201A33PG 数据手册
ME6201 High Input Voltage,Low Dropout,Low Supply Current ME6201 Series General Description Features ME6201 series are low-dropout linear voltage regulators with a built-in voltage reference module, error correction module and phase compensation module. ME6201 series are based on the CMOS process and allow high voltage input with low quiescent current. This series has the function of internal feedback resistor setting from 3V to 5V. The output accuracy is ± 2.5%. Selection Guide          High output accuracy: ± 2.5% Input voltage: up to 16V Output voltage: 3.0 V ~ 5.0V Ultra-low Supply current (Typ. = 4 µ A) Iout = 100mA (When Vin = 5.3V and Vout = 3.3V) Importation good stability: Typ. 0.1% / V Low temperature coefficient Ceramic capacitor can be used Package: SOT-89, TO-92,SOT23-3 Typical Application      Electronic weighbridge SCM Phones, cordless phones Security Products Water meters, power meters Typical Application Circuit Caution: The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. Input capacitor (CIN): 10.0 μF or more;Output capacitor (CL): 10 μF or more (tantalum capacitor) V05 www.microne.com.cn Page 1 of 12 ME6201 Pin Configuration Pin Assignment ME6201AXX PIN Number PIN NAME FUNCTION 1 VSS Ground 2 2 VIN Input 3 3 VOUT Output SOT23-3 SOT89-3 TO-92 1 1 3 2 Absolute Maximum Ratings PARAMETER SYMBOL RATINGS UNITS Input Voltage VIN 18 V Output Current Iout 200 mA Output Voltage Vout Vss-0.3 ~ Vout+0.3 V SOT-89 Pd 500 mW TO-92 Pd 500 mW Operating Ambient Temperature TOPR -25 ~ +85 ℃ Storage Temperature TSTG -40 ~ +125 ℃ Soldering Temperature And Time TSOLDER 260℃, 10s Power Dissipation Caution: The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. V05 www.microne.com.cn Page 2 of 12 ME6201 Block Diagram Electrical Characteristics ME6201A30 (VIN=VOUT+2V,CIN=COUT=10uF,Ta=25OC Unless otherwise stated) PARAMETER SYMBOL CONDITION MIN TYP MAX UNITS Output Voltage VOUT(E) (Note 2) IOUT=10mA, VIN=Vout+2V X 0.975 VOUT (T) X 1.025 V Input Voltage VIN 16 V Maximum Output Current IOUT (max) VIN=Vout+2V Load Regulation ∆VOUT VIN=Vout+2V, 1mA≤IOUT≤80mA 40 mV VDIF1 IOUT =10mA 170 mV VDIF2 IOUT =50mA 800 mV Supply Current ISS VIN=Vout+2V 4 Line Regulations ∆VOUT ∆VIN •VOUT IOUT =30mA Vout+2V ≤VIN≤16V 0.1 3.0 100(Note4) mA Dropout Voltage (Note 3) V05 www.microne.com.cn 8 μA %/V Page 3 of 12 ME6201 ME6201A33 (VIN=VOUT+2V,CIN=COUT=10uF,Ta=25OC Unless otherwise stated) PARAMETER SYMBOL CONDITION MIN TYP MAX UNITS Output Voltage VOUT(E) (Note 2) IOUT=10mA, VIN=Vout+2V X 0.975 VOUT (T) X 1.025 V Input Voltage VIN 16 V Maximum Output Current IOUT (max) VIN=Vout+2V Load Regulation ∆VOUT VIN=Vout+2V, 1mA≤IOUT≤80mA 40 mV Dropout Voltage (Note 3) Vdif1 IOUT =10mA 150 mV Vdif2 IOUT =50mA 700 mV Supply Current ISS VIN=Vout+2V 4 Line Regulations ∆VOUT ∆VIN •VOUT IOUT =30mA Vout+2V ≤VIN≤16V 0.1 3.3 100(Note4) mA 8 μA %/V ME6201A36 (VIN=VOUT+2V,CIN=COUT=10uF,Ta=25OC Unless otherwise stated) PARAMETER SYMBOL CONDITION MIN TYP MAX UNITS Output Voltage VOUT(E) (Note 2) IOUT=10mA, VIN=Vout+2V X 0.975 VOUT (T) X 1.025 V Input Voltage VIN 16 V Maximum Output Current IOUT (max) VIN=Vout+2V Load Regulation ∆VOUT VIN=Vout+2V, 1mA≤IOUT≤80mA 40 mV Dropout Voltage (Note 3) Vdif1 IOUT =10mA 150 mV Vdif2 IOUT =50mA 700 mV Supply Current ISS VIN=Vout+2V 4 Line Regulations ∆VOUT ∆VIN •VOUT IOUT =30mA Vout+2V ≤VIN≤16V 0.1 3.6 100(Note4) mA 8 μA %/V ME6201A44 (VIN=VOUT+2V,CIN=COUT=10uF,Ta=25OC Unless otherwise stated) PARAMETER SYMBOL CONDITION MIN TYP MAX UNITS Output Voltage VOUT(E) (Note 2) IOUT=10mA, VIN=Vout+2V X 0.975 VOUT (T) X 1.025 V Input Voltage VIN 16 V Maximum Output Current IOUT (max) V05 4.4 VIN=Vout+2V www.microne.com.cn 100(Note4) mA Page 4 of 12 ME6201 Load Regulation ∆VOUT VIN=Vout+2V, 1mA≤IOUT≤80mA 40 mV Dropout Voltage (Note 3) Vdif1 IOUT =10mA 120 mV Vdif2 IOUT =50mA 600 mV Supply Current ISS VIN=Vout+2V 4 Line Regulations ∆VOUT ∆VIN •VOUT IOUT =30mA Vout+2V ≤VIN≤16V 0.1 8 μA %/V ME6201A50 (VIN=VOUT+2V,CIN=COUT=10uF,Ta=25OC Unless otherwise stated) PARAMETER SYMBOL CONDITION MIN TYP MAX UNITS Output Voltage VOUT(E) (Note 2) IOUT=10mA, VIN=Vout+2V X 0.975 VOUT (T) X 1.025 V Input Voltage VIN 16 V Maximum Output Current IOUT (max) VIN=Vout+2V Load Regulation ∆VOUT VIN=Vout+2V, 1mA≤IOUT≤80mA 60 mV Dropout Voltage (Note 3) Vdif1 IOUT =10mA 100 mV Vdif2 IOUT =50mA 550 mV Supply Current ISS VIN=Vout+2V 5 Line Regulations ∆VOUT ∆VIN •VOUT IOUT =30mA Vout+2V ≤VIN≤16V 0.1 5 100(Note4) mA 8 μA %/V Note : 1、 VOUT (T) :Specified Output Voltage 2、VOUT (E):Effective Output Voltage ( le. The output voltage when “VOUT (T)+2.0V”is provided at the Vin pin while maintaining a certain Iout value.) 3、VDIF:VIN1 –VOUT (E)’ VIN1:The input voltage when VOUT(E)’ appears as input voltage is gradually decreased. VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized Iout {VOUT (T)+2.0V} is input. 4、The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. Application Conditions Precautions:Wiring patterns for the VIN, VOUT and GND pins should be designed so that the impedance is low. When mounting an output capacitor between the VOUT and VSS pins (CL) and a capacitor for stabilizing the input between VIN and VSS pins (CIN), the distance from the capacitors to these pins should be as short as possible(less than 0.5cm). V05 www.microne.com.cn Page 5 of 12 ME6201 Type Characteristics (1)Output Current VS. Output Voltage( Ta = 25 °C) ME6201A30PG ME6201A33PG Output Voltage VS.Output Current 3.7 3.5 3.3 3.1 2.9 2.7 2.5 2.3 2.1 1.9 Output Voltage(V) Output Voltage(V) Output Voltage VS.Output Current 0 20 40 60 80 100 4 3.8 3.6 3.4 3.2 3 2.8 2.6 2.4 2.2 120 0 20 40 Output Current(mA) 60 80 100 120 Output Current(mA) ME6201A36PG ME6201A44PG Output Voltage VS.Output Current 4.5 4.2 3.9 3.6 3.3 3 2.7 2.4 2.1 1.8 Output Voltage(V) Output Voltage(V) Output Voltage VS.Output Current 0 20 40 60 80 100 120 140 5.3 5 4.7 4.4 4.1 3.8 3.5 3.2 2.9 2.6 0 Output Current(mA) 20 40 60 80 100 120 140 Output Current (mA) ME6201A50PG Output Voltage(V) Output Voltage VS.Output Current 6 5.8 5.6 5.4 5.2 5 4.8 4.6 4.4 4.2 4 0 20 40 60 80 100 120 140 160 180 Output Current(m A) V05 www.microne.com.cn Page 6 of 12 ME6201 (2)Input Voltage VS. Output Voltage(Ta = 25 °C) ME6201A30PG ME6201A33PG Input VoltageVS.Output Voltage Input VoltageVS.Output Voltage 4 4.3 Output Voltage(V) 4.1 1mA 3.6 3.9 50mA Output Voltage(V) 3.8 3.4 3.2 3 2.8 2.6 100mA 2.4 1mA 3.5 3.3 3.1 2.9 100mA 2.7 2.2 50mA 3.7 2.5 2 2.3 4 6 8 10 12 14 16 4 6 8 Input Voltage(V) 10 12 14 16 Input Voltage(V) ME6201A36PG ME6201A44PG Input Voltage VS.Output Voltage 4.6 4.4 4.2 4 3.8 3.6 3.4 3.2 3 2.8 2.6 50mA 1mA Output Voltage(V) Output Voltage(V) Input Voltage VS.Output Voltage 100mA 6 8 10 12 14 16 5.4 5.2 5 4.8 4.6 4.4 4.2 4 3.8 3.6 3.4 1mA 50mA 100mA 6 Iutput Voltage(V) 8 10 12 14 16 Input Voltage(V) ME6201A50PG Input Voltage VS.Output Voltage Output Voltage(V) 6 5.8 5.6 5.4 1mA 50mA 5.2 5 4.8 4.6 4.4 100mA 4.2 4 7 9 11 13 15 Iutput Voltage(V) V05 www.microne.com.cn Page 7 of 12 ME6201 (3)Output Current VS. Dropout Voltage( Ta = 25 °C) ME6201A30PG ME6201A33PG Output CurrentVS.Droput Voltage 1400 1800 1600 1200 1400 1200 1000 Droput Voltage(mV) Droput Voltage(mV) Output CurrentVS.Droput Voltage 800 600 400 1000 800 600 400 200 0 200 0 10 20 30 40 50 60 70 0 80 0 10 20 Output Current(mA) ME6201A36PG 40 50 60 70 80 ME6201A44PG Output Current VS.Dropout Voltage Output Current VS.Dropout Voltage 1400 Dropout Voltage (mV) 1600 Dropout Voltage(mV) 30 Output Curren(mA) 1400 1200 1000 800 600 400 200 0 0 10 20 30 40 50 60 70 80 90 1200 1000 800 600 400 200 0 100 0 10 20 30 40 50 60 70 80 90 100 Output Current (mA) Output Current(mA) ME6201A50PG Output Current VS.Dropout Voltage Dropout Voltage(mV) 1200 1000 800 600 400 200 0 0 10 20 30 40 50 60 70 80 90 100 Output Current(mA) V05 www.microne.com.cn Page 8 of 12 ME6201 (4)Input Voltage VS. Supply Current(Ta = 25 °C) ME6201A30PG ME6201A33PG Input Voltage VS.Supply Current 6 6 5 5 Supply Current(uA) Supply Current(uA) Input Voltage VS.Supply Current 4 3 2 1 0 4 3 2 1 0 4 6 8 10 12 14 16 4 6 8 Input Voltage(V) 12 14 16 14 16 Input Voltage(V) ME6201A36PG ME6201A44PG Input Voltage VS.Supply Current Input Voltage VS.Supply Current 6 6 5 5 Supply Current(uA) Supply Current(uA) 10 4 3 2 1 0 4 3 2 1 0 4 6 8 10 12 14 16 4 Input Voltage(V) 6 8 10 12 Input Voltage(V) ME6201A50PG Input Voltage VS.Supply Current Supply Current(uA) 6 5 4 3 2 1 0 4 6 8 10 12 14 16 Input Voltage(V) V05 www.microne.com.cn Page 9 of 12 ME6201 Packaging Information: ● SOT89-3 ● TO-92 V05 www.microne.com.cn Page 10 of 12 ME6201 ● SOT23-3 V05 www.microne.com.cn Page 11 of 12 ME6201      V05 The information described herein is subject to change without notice. Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Nanjing Micro One Electronics Inc is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro One Electronics Inc. Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. www.microne.com.cn Page 12 of 12
ME6201A33PG 价格&库存
很抱歉,暂时无法提供与“ME6201A33PG”相匹配的价格&库存,您可以联系我们找货
ME6201A33PG
    • 10+0.41726
    • 100+0.33690
    • 300+0.29671
