LM1117T-5.0 P+
LM1117T-5.0 P+
    JSMICRO(杰盛微)
    TO-220-3
    输出类型:-;
LM1117T-5.0 P+ 数据手册
LM1117-系列 General Description 5 Features The LM1117 is a series of low dropout three-terminal regulators with a dropout of 1.15V at 1A output current. · CR MI JS The LM1117 series provides current limiting and thermal shutdown. Its circuit includes a immed bandgap reference to assure output voltage accuracy to be within 1% for 1.5V, 1.8V, 2.5V, 2.85V, 3.3V, 5.0V and adjustable versions or 2% for 1.2V version. Current limit is immed to ensure specified output current and conolled short-circuit current. On-chip thermal shutdown provides protection against any combination of overload and ambient temperature that would create excessive junction temperature. O The LM1117 has an adjustable version, that can provide the output voltage from 1.25V to 12V with only 2 external resistors. · Applications · · · · · · · · PC Motherboard LCD Monitor Graphic Card DVD-video Player NIC/Switch Telecom Equipment ADSL Modem Printer and other Peripheral Equipment SOT-223 SOT-89-3 TO-252-2 r to uc nd co mi Se The LM1117 series is available in the indusy standard SOT-223, SOT-89-3, TO-220-3, TO-252-2 and TO263-3 power packages. · · · Low Dropout Voltage: 1.15V at 1A Output Current immed Current Limit On-chip Thermal Shutdown Three-terminal Adjustable or Fixed 1.2V, 1.5V, 1.8V, 2.5V, 2.85V, 3.3V, 5.0V Operation Junction Temperature: -40 to 125oC TO-220-3 TO-263-3 Figure 1. Package Types of LM1117 www.jsmsemi.com 第1/23页 LM1117-系列 Pin 5 Configuration (SOT-89-3) (SOT-223) VOUT 3 INPUT 2 OUTPUT 1 ADJ/GND VOUT MI JS CR 3 INPUT VOUT O 2 INPUT 2 OUTPUT 1 ADJ/GND (TO-252-2) (TO-220-3) VOUT 3 3 INPUT 2 OUTPUT 1 ADJ/GND OUTPUT 1 ADJ/GND INPUT 2 OUTPUT 1 ADJ/GND r to uc nd VOUT 3 co mi Se (TO-263-3) Figure 2. Pin Configuration of LM1117 www.jsmsemi.com 第2/23页 LM1117-系列 Functional Block Diagram 5 JS O INPUT 2 OUTPUT 1 ADJ/GND + CR MI Thermal Protection 3 For Adjustable Output, disconnect A1 and A2, connect B For Fixed Output, connect A1 and A2, disconnect B A1 co mi B Se A2 Figure 3. Functional Block Diagram of LM1117 r to uc nd www.jsmsemi.com 第3/23页 LM1117-系列 Ordering Information 5 LM1117 - ADJ: Adjustable Output 1.2: Fixed Output 1.2V 1.5: Fixed Output 1.5V 1.8: Fixed Output 1.8V 2.5: Fixed Output 2.5V 2.85: Fixed Output 2.85V 3.3: Fixed Output 3.3V 5.0: Fixed Output 5.0V Circuit Type CR MI JS Temperature Range Part No. Marking ID O Package Tin Lead Tin Lead 1117-ADJ 1117-1.2 1117-1.5 1117-1.8 1117-2.5 1117-2.85 1117-3.3 1117-5.0 1117-ADJ 1117-1.2 1117-1.5 1117-1.8 1117-2.5 1117-2.85 1117-3.3 1117-5.0 LM1117T-ADJ LM1117T-1.2 LM1117T-1.5 LM1117T-1.8 LM1117T-2.5 LM1117T-2.85 LM1117T-3.3 LM1117T-5.0 SOT-89-3 -40 to 125oC TO-220-3 -40 to 125oC r to uc nd -40 to 125oC co SOT-223 Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tape & Reel Tube Tube Tube Tube Tube Tube Tube Tube mi Se LM1117-ADJ LM1117-1.2 LM1117-1.5 LM1117-1.8 LM1117-2.5 LM1117-2.85 LM1117-3.3 LM1117-5.0 LM1117-ADJ LM1117-1.2 LM1117-1.5 LM1117-1.8 LM1117-2.5 LM1117-2.85 LM1117-3.3 LM1117-5.0 LM1117T-ADJ LM1117T-1.2 LM1117T-1.5 LM1117T-1.8 LM1117T-2.5 LM1117T-2.85 LM1117T-3.3 LM1117T-5.0 Packing Type www.jsmsemi.com 第4/23页 LM1117-系列 Ordering Information (Continued) 5 Package Temperature Range JS -40 to 125oC TO-263-3 -40 to 125oC Marking ID Packing Type Tin Lead Tin Lead LM1117-ADJ LM1117-ADJ LM1117-1.2 LM1117-1.2 LM1117-1.5 LM1117-1.5 LM1117-1.8 LM1117-1.8 LM1117-2.5 LM1117-2.5 LM1117-2.85 LM1117-2.85 LM1117-3.3 LM1117-3.3 LM1117-5.0 LM1117-5.0 LM1117-ADJ LM1117-ADJ LM1117-1.2 LM1117-1.2 LM1117-1.5 LM1117-1.5 LM1117-1.8 LM1117-1.8 LM1117-2.5 LM1117-2.5 LM1117-2.85 LM1117-2.85 LM1117-3.3 LM1117-3.3 LM1117-5.0 LM1117-5.0 LM1117-ADJ LM1117-ADJ LM1117-1.2 LM1117-1.2 LM1117-1.5 LM1117-1.5 LM1117-1.8 LM1117-1.8 LM1117-2.5 LM1117-2.5 LM1117-2.85 LM1117-2.85 LM1117-3.3 LM1117-3.3 LM1117-5.0 LM1117-5.0 LM1117-ADJ LM1117-ADJ LM1117-1.2 LM1117-1.2 LM1117-1.5 LM1117-1.5 LM1117-1.8 LM1117-1.8 LM1117-2.5 LM1117-2.5 LM1117-2.85 LM1117-2.85 LM1117-3.3 LM1117-3.3 LM1117-5.0 LM1117-5.0 O CR MI TO-252-2 Part Number r to uc nd co mi Se Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel Tube Tape & Reel www.jsmsemi.com 第5/23页 LM1117-系列 Absolute Maximum Ratings (Note 1) 5 Parameter Symbol Input Voltage Max Unit VIN 20 V Maximum Junction Temperature TJ 150 oC Storage Temperature TS 150 oC TLEAD 300 oC ESD 600 V Lead Temperature (Soldering, 10sec) -65 O CR MI JS ESD (Machine Model) Min Se Recommended Operating Conditions Operating Junction Temperature Range Symbol VIN TJ Min co Input Voltage mi Parameter -40 Max Unit 15 V 125 oC r to uc nd www.jsmsemi.com 第6/23页 LM1117-系列 Elecical Characteristics 5 LM1117-ADJ Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Parameter Symbol Conditions Min Typ Max Unit 1.238 1.225 1.250 1.250 1.262 1.270 V 0.035 0.2 % VREF IOUT  m VIN-VOUT = 2V 10mA IOUT  , 1.4V VIN-VOUT  8V, P Maximum Power Dissipation Line Regulation VOUT IOUT = 10mA, 1.5V VIN-VOUT  V Load Regulation VOUT VIN -VOUT = 2V, 10mA IOUT   0.2 0.4 % VREF  , IOUT   1.00 1.1 V VREF  , IOUT   1.08 1.18 V VREF  , IOUT   1.15 1.25 V JS Reference Voltage Dropout Voltage MI Adjust Pin Current VIN-VOUT = 2V 1.25 1.4V VIN-VOUT  10V, 10mA  IOUT  1A O Adjust Pin Current Change ILIMIT CR Current Limit 1.5V VIN-VOUT  10V (ADJ only) Se Minimum Load Current (ADJ) VIN=VOUT +1.25V Ripple Rejection f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A Temperature Stability TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz Thermal Shutdown Hysteresis SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 60 120 A 0.2 5 A 1.7 5 mA 5 10 mA 75 dB 0.5 % 0.3 % 0.003 % r to uc nd Thermal Shutdown JC co Long -Term Stability Thermal Resistance, Junction to Case 60 mi Quiescent Current 1.35 www.jsmsemi.com 15 75 10 4.5 4 oC/W 150 oC 25 oC 第7/23页 LM1117-系列 Elecical Characteristics (Continued) 5 LM1117-1.2V Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Symbol Output Voltage VOUT IOUT  m VIN = 3.2V 10mA  IOUT  1A, 3.0V VIN 10V Line Regulation VOUT Load Regulation VOUT Dropout Voltage Current Limit Quiescent Current Conditions Min Typ Max Unit 1.176 1.152 1.2 1.2 1.224 1.248 V IOUT = 10mA, 1.5V VIN-VOUT  V 1 6 mV VIN -VOUT = 2V, 10mA IOUT  1 10 mV VOUT , IOUT   1.00 1.1 V VOUT , IOUT   1.08 1.18 V VOUT  , IOUT   1.15 1.25 V CR MI JS Parameter ILIMIT VIN-VOUT = 2V 1.25 VIN=VOUT +1.25V 5 O f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A Ripple Rejection TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 10 www.jsmsemi.com mA 75 dB 0.5 % 0.3 % 0.003 % 15 75 10 4.5 4 o r to uc nd Thermal Shutdown Hysteresis JC co Thermal Shutdown mi Long -Term Stability Thermal Resistance, Junction to Case 60 Se Temperature Stability 1.35 C/W 150 oC 25 oC 第8/23页 LM1117-系列 Elecical Characteristics (Continued) 5 LM1117-1.5V Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Symbol Output Voltage VOUT IOUT  m VIN = 3.5V 10mA  IOUT  1A, 3.0V VIN 10V Line Regulation VOUT Load Regulation VOUT Dropout Voltage Current Limit Quiescent Current Conditions Min Typ Max Unit 1.485 1.470 1.5 1.5 1.515 1.530 V IOUT = 10mA, 1.5V VIN-VOUT  V 1 6 mV VIN -VOUT = 2V, 10mA IOUT  1 10 mV VOUT , IOUT   1.00 1.1 V VOUT , IOUT   1.08 1.18 V VOUT  , IOUT   1.15 1.25 V CR MI JS Parameter ILIMIT VIN-VOUT = 2V 1.25 5 O VIN=VOUT +1.25V Ripple Rejection f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 10 www.jsmsemi.com mA 75 dB 0.5 % 0.3 % 0.003 % 15 75 10 4.5 4 o r to uc nd Thermal Shutdown Hysteresis JC co Thermal Shutdown mi Long -Term Stability Thermal Resistance, Junction to Case 60 Se Temperature Stability 1.35 C/W 150 oC 25 oC 第9/23页 LM1117-系列 Elecical Characteristics (Continued) 5 LM1117-1.8V Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Symbol Output Voltage VOUT IOUT  m VIN = 3.8V 10mA  IOUT 1A, 3.2V VIN  10V Line Regulation VOUT Load Regulation VOUT Dropout Voltage Current Limit Quiescent Current Conditions Min Typ Max Unit 1.782 1.746 1.8 1.8 1.818 1.854 V IOUT = 10mA, 1.5V VIN-VOUT  V 1 6 mV VIN -VOUT = 2V, 10mA IOUT   1 10 mV VOUT , IOUT   1.00 1.1 V VOUT , IOUT   1.08 1.18 V VOUT  , IOUT   1.15 1.25 V CR MI JS Parameter ILIMIT VIN-VOUT = 2V 1.25 5 O VIN=VOUT +1.25V f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A Ripple Rejection TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 10 www.jsmsemi.com mA 75 dB 0.5 % 0.3 % 0.003 % 15 75 10 4.5 4 o r to uc nd Thermal Shutdown Hysteresis JC co Thermal Shutdown mi Long -Term Stability Thermal Resistance, Junction to Case 60 Se Temperature Stability 1.35 C/W 150 oC 25 oC 第10/23页 LM1117-系列 Elecical Characteristics (Continued) 5 LM1117-2.5V Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Symbol Output Voltage VOUT IOUT  m VIN = 4.5V 10mA  IOUT 1A, 3.9V VIN  10V Line Regulation VOUT Load Regulation VOUT Dropout Voltage Current Limit Quiescent Current Conditions Min Typ Max Unit 2.475 2.450 2.5 2.5 2.525 2.550 V IOUT = 10mA, 1.5V VIN-VOUT  V 1 6 mV VIN -VOUT = 2V, 10mA IOUT   1 10 mV VOUT , IOUT   1.00 1.1 V VOUT , IOUT   1.08 1.18 V VOUT  , IOUT   1.15 1.25 V CR MI JS Parameter ILIMIT VIN-VOUT = 2V 1.25 5 O VIN=VOUT +1.25V f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A Ripple Rejection TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 10 www.jsmsemi.com mA 75 dB 0.5 % 0.3 % 0.003 % 15 75 10 4.5 4 o r to uc nd Thermal Shutdown Hysteresis JC co Thermal Shutdown mi Long -Term Stability Thermal Resistance, Junction to Case 60 Se Temperature Stability 1.35 C/W 150 oC 25 oC 第11/23页 LM1117-系列 Elecical Characteristics (Continued) 5 LM1117-2.85V Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Symbol Output Voltage VOUT IOUT  mA VIN = 4.85V 10mA  IOUT  1A, 4.25V VIN 10V Line Regulation VOUT Load Regulation VOUT JS Parameter Dropout Voltage Typ Max Unit 2.822 2.793 2.85 2.85 2.878 2.907 V IOUT = 10mA, 1.5V VIN-VOUT  V 1 6 mV VIN -VOUT = 2V, 10mA IOUT  1 10 mV VREF  , IOUT  0.1A 1.00 1.1 V VREF  , IOUT  0.5A 1.08 1.18 V VREF  , IOUT  1.0A 1.15 1.25 V ILIMIT VIN-VOUT = 2V 1.25 VIN=VOUT +1.25V Ripple Rejection TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 10 www.jsmsemi.com mA 75 dB 0.5 % 0.3 % 0.003 % 15 75 10 4.5 4 r to uc nd Thermal Shutdown Hysteresis JC co Thermal Shutdown mi Long -Term Stability Thermal Resistance, Junction to Case 60 Se f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A Temperature Stability 1.35 5 O Quiescent Current Min CR MI Current Limit Conditions o C/W 150 oC 25 oC 第12/23页 LM1117-系列 Elecical Characteristics (Continued) 5 LM1117-3.3V Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Symbol Output Voltage VOUT IOUT  m VIN = 5.0V 10mA  IOUT 1A, 4.75V VIN  10V Line Regulation VOUT Load Regulation VOUT Dropout Voltage Current Limit Quiescent Current Conditions Min Typ Max Unit 3.267 3.235 3.3 3.3 3. 333 3.365 V IOUT = 10mA, 1.5V VIN-VOUT  V 1 6 mV VIN -VOUT = 2V, 10mA IOUT   1 10 mV VOUT , IOUT   1.00 1.1 V VOUT , IOUT   1.08 1.18 V VOUT  , IOUT   1.15 1.25 V CR MI JS Parameter ILIMIT VIN-VOUT = 2V 1.25 5 O VIN=VOUT +1.25V f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A Ripple Rejection TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 10 www.jsmsemi.com mA 75 dB 0.5 % 0.3 % 0.003 % 15 75 10 4.5 4 o r to uc nd Thermal Shutdown Hysteresis JC co Thermal Shutdown mi Long -Term Stability Thermal Resistance, Junction to Case 60 Se Temperature Stability 1.35 C/W 150 oC 25 oC 第13/23页 LM1117-系列 Elecical Characteristics (Continued) 5 LM1117-5.0V Elecical Characteristics Operating Conditions: VIN0V, TJ =25oC, unless otherwise specified. Symbol Output Voltage VOUT IOUT  m VIN = 7.0V 10mA  IOUT 1A, 6.5V VIN  12V Line Regulation VOUT Load Regulation VOUT Dropout Voltage Current Limit Quiescent Current Conditions Min Typ Max Unit 4.950 4.900 5.0 5.0 5.050 5.100 V IOUT = 10mA, 1.5V VIN-VOUT  V 1 10 mV VIN -VOUT = 2V, 10mA IOUT   1 15 mV VOUT , IOUT   1.00 1.1 V VOUT , IOUT   1.08 1.18 V VOUT  , IOUT   1.15 1.25 V CR MI JS Parameter ILIMIT VIN-VOUT = 2V 1.25 5 O VIN=VOUT +1.25V f =120Hz, COUT =22F Tantalum, VIN-VOUT = 3V, IOUT =1A Ripple Rejection TA=125oC, 1000hrs RMS Output Noise (% of VOUT) TA=25oC, 10Hz  f  0kHz SOT-223 SOT-89-3 TO-252-2 TO-220-3 TO-263-3 Junction Temperature A 10 www.jsmsemi.com mA 75 dB 0.5 % 0.3 % 0.003 % 15 75 10 4.5 4 o r to uc nd Thermal Shutdown Hysteresis JC co Thermal Shutdown mi Long -Term Stability Thermal Resistance, Junction to Case 60 Se Temperature Stability 1.35 C/W 150 oC 25 oC 第14/23页 LM1117-系列 Typical Performance Characteristics 5 0.2 1.2 1.1 o T =0 C Output Voltage Deviation (%) 1.0 o T =25 C A 0.9 o T =125 C 0.8 0.7 JS Dropout Voltage (V) A A CR 0.5 0.2 MI 0.6 0.4 0.6 0.8 LM1117-ADJ 0.1 0.0 -0.1 -0.2 -50 1.0 -25 0 25 50 75 100 125 Junction Temperature (oC) Output Current (A) O Figure 4. Dropout Voltage vs. Output Current Figure 5. Load Regulation vs. Junction Temperature co mi Se 3.40 1.280 1.275 Output Voltage (V) Reference Voltage (V) LM1117-3.3V 1.265 1.260 1.255 1.250 1.245 1.240 3.30 3.25 3.20 3.15 1.235 1.230 r to uc nd 3.35 1.270 -50 -25 0 25 50 75 100 125 3.10 -50 o -25 0 25 50 75 100 125 o Junction Temperature ( C) Junction Temperature ( C) Figure 6. Reference Voltage vs. Junction Temperature Figure 7. Output Voltage vs. Junction Temperature www.jsmsemi.com 第15/23页 LM1117-系列 Typical Performance Characteristics (Continued) 5 100 5 80 Adjust Pin Current (uA) 3 2 -25 0 25 70 60 50 40 30 20 10 50 75 CR 0 -50 MI 1 JS Minimum Load Current (mA) 90 4 100 0 -50 125 -25 0 25 50 75 100 125 o Junction Temperature ( C) o Junction Temperature ( C) O Figure 9. Adjust Pin Current vs. Temperature Figure 8. Minimum Load Current vs. Junction Temperature mi Se 2.0 7.5 1.6 Power (W) Short-circuit Current (A) 1.8 1.4 5.0 SOT-223 2.5 1.2 1.0 -50 -25 0 25 50 75 100 125 o Junction Temperature ( C) r to uc nd co 10.0 0.0 25 50 75 100 125 Case Temperature ( C) o Figure 10. Short-Circuit Current vs. Junction Temperature Figure 11. Maximum Power Dissipation www.jsmsemi.com 第16/23页 LM1117-系列 Typical Performance Characteristics (Continued) 5 Line_ansient_response VIN=4.8V, VOUT=3.33V, CIN=COUT=10 (TAN) preload=0.1A Line_ansient_response VIN=4.8V, VOUT=3.33V, CIN=1,COUT=10 (TAN) VOUT VOUT VIN=5.8V IOUT=0.5A JS VIN=4.8V IOUT=0.1A CR MI Figure 12. Line ansient Response Figure 13. Load ansient Response O mi Se 60 50 40 30 20 10 100 1k 10k Frequency (Hz) 100k r to uc nd co Ripple Rejection (dB) 70 Figure 14. Ripple Rejection vs. Frequency www.jsmsemi.com 第17/23页 LM1117-系列 Typical Applications 5 VIN VOUT LM1117-ADJ 10F Tantalum + VIN VOUT + 22F Tantalum ADJ R1 JS R2 V =V REF * ( 1+R2/R1) + I ADJ * R2 O CR MI OUT LM1117-5.0 VIN=7V + 5V at 1A VOUT + 22F Tantalum Se 10F Tantalum VIN GND co mi Figure 15. Typical Applications of LM1117 r to uc nd www.jsmsemi.com 第18/23页 LM1117-系列 Mechanical Dimensions 5 SOT- 223 Unit: mm(inch) 6.300(0.248) 6.700(0.264) JS 2.900(0.114) 3.100(0.122) 3.300(0.130) 7.300(0.287) O 3.700(0.146) MIN CR 6.700(0.264) MI 0.900(0.035) 0.250(0.010) Se 1.750(0.069) TYP mi 0.610(0.024) 2.300(0.091) 0.810(0.032) 4.500(0.177) 0.020(0.001) 0.100(0.004) 0° 10° r to uc nd 4.700(0.185) co TYP 1.500(0.059) 1.520(0.060) 1.700(0.067) 1.800(0.071) www.jsmsemi.com 第19/23页 LM1117-系列 Mechanical Dimensions (Continued) 5 SOT-89-3 Unit: mm(inch) 4.400(0.173) 4.600(0.181) 1.630(0.064) 1.400(0.055) 1.600(0.063) 0.000(0.000) 0.076(0.003) 1.400(0.055)* 1.200(0.047) 0.900(0.035) 2.300(0.091) 2.600(0.102) Se 3.950(0.156) 4.250(0.167) R0.200(0.008) O CR MI JS 1.830(0.072) 3° mi 0.360(0.014) co 0.360(0.014) 0.480(0.019) 0.440(0.017) 0.480(0.019) 0.440(0.017) 0.560(0.022) r to uc nd 3.000(0.118) 0.360(0.014) R0.150(0.006) www.jsmsemi.com 第20/23页 LM1117-系列 Mechanical Dimensions (Continued) 5 TO-252-2 6.380(0.251) 6.680(0.263) 0.400(0.016)×45° 1.080(0.043) 1.320(0.052) 0.480(0.019) 0.540(0.021) 0.020(0.001) 0.120(0.005) 5° O CR 5.360(0.211) 5.560(0.219) 8° 5° r to uc nd 2.90° 3.10° 1.400(0.055) 1.760(0.069) 2.240(0.088) 2.340(0.092) 1° 7° 0.510(0.020) co 2.90° 3.10° 0.640(0.025) 0.780(0.031) 0.600(0.024) mi 2.240(0.088) 2.340(0.092) Se 0.750(0.030) 0.850(0.033) 2.600(0.102) 3.000(0.118) MI 9.500(0.374) 10.100(0.398) 0.650(0.026) 0.950(0.037) 2.180(0.086) 2.380(0.094) 0.460(0.018) 0.580(0.023) JS 5.230(0.206) 5.430(0.214) Unit: mm(inch) www.jsmsemi.com 第21/23页 LM1117-系列 Mechanical Dimensions (Continued) 5 TO-220-3 2.580(0.102) 3.380(0.133) 1.850(0.073) 0.550(0.022) 1.350(0.053) 14.230(0.560) 16.510(0.650) φ1.500(0.059) mi 0.381(0.015) 0.813(0.032) 8.763(0.345) 0.381(0.015) 2.540(0.100) 3.560(0.140) 4.820(0.190) 2.080(0.082) 2.880(0.113) 7° r to uc nd 60° 0.200(0.008) co 1.160(0.046) 1.760(0.069) 27.880(1.098) 30.280(1.192) Se 8.520(0.335) 9.520(0.375) O CR MI JS 9.660(0.380) 10.660(0.420) φ3.560(0.140) 4.060(0.160) 2.540(0.100) www.jsmsemi.com 0.356(0.014) 0.406(0.016) 第22/23页 LM1117-系列 Mechanical Dimensions (Continued) 5 TO-263-3 4.070(0.160) 4.820(0.190) Unit: mm(inch) 3° MI JS 9.650(0.380) 1.270(0.050) 1.390(0.055) mi 3° r to uc nd 2.390(0.094) 2.690(0.106) 7.980(0.314) co 2.540(0.100) 2.640(0.104) 2.700(0.106) 0.360(0.014) 0.400(0.016) 7° 2.200(0.087) 5.600(0.220) 0.020(0.001) 0.250(0.010) Se 8.640(0.340) 9.650(0.380) O 0.510(0.020) 0.990(0.039) 2.540(0.100) 7° 14.760(0.581) 15.740(0.620) 1.150(0.045) 1.390(0.055) 7.420(0.292) 1.150(0.045) 1.390(0.055) CR 10.290(0.405) 8.840(0.348) 2° 8° 0.380(0.015) 0° 6° www.jsmsemi.com 2.540(0.100) 2.540(0.100) 第23/23页
LM1117T-5.0 P+ 价格&库存
很抱歉,暂时无法提供与“LM1117T-5.0 P+”相匹配的价格&库存,您可以联系我们找货
