LNC04R035B
LNC04R035B
    LONTEN(龙腾半导体)
    TO-220-3
    类型:N沟道;漏源电压(Vdss):40V;连续漏极电流(Id):120A;功率(Pd):150W;导通电阻(RDS(on)@Vgs,Id):6mΩ@4.5V,10A;阈值电压(Vgs(th)@Id)...
LNC04R035B 数据手册
LNC04R035B/ LND04R035B Lonten N-channel 40V, 120A, 3.5mΩ Power MOSFET Description Product Summary These N-Channel enhancement mode power field VDSS 40V effect RDS(on).max@ VGS=10V 3.5mΩ ID 120A transistors are using trench DMOS technology. This advanced technology has been especially tailored to minimize on-state resistance, provide superior switching performance, and with Pin Configuration stand high energy pulse in the avalanche and commutation mode. These devices are well suited for high efficiency fast switching applications. Features  40V,120A,RDS(on).max=3.5mΩ@VGS = 10V  Improved dv/dt capability  Fast switching  100% EAS Guaranteed  Green device available D TO-220 TO-220MF G S Applications  Motor Drives  UPS  DC-DC Converter Absolute Maximum Ratings N-Channel MOSFET Pb TC = 25°C unless otherwise noted Parameter Drain-Source Voltage Continuous drain current ( TC = 25°C )1) Continuous drain current ( TC = 100°C )1) Symbol VDSS ID Value Unit 40 V 120 A 82 A Pulsed drain current2) IDM 480 A Gate-Source voltage VGSS ±20 V Avalanche energy3) EAS 1040 mJ 150 W 48 W Power Dissipation ( TC = 25°C ) TO-220 Power Dissipation ( TC = 25°C ) TO-220MF PD Storage Temperature Range TSTG -55 to +150 °C Operating Junction Temperature Range TJ -55 to +150 °C Value Unit 0.83 °C/W 2.6 °C/W 62 °C/W 80 °C/W Thermal Characteristics Parameter Thermal Resistance, Junction-to-Case TO-220 Thermal Resistance, Junction-to-Case TO-220MF Thermal Resistance, Junction-to-Ambient TO-220 Thermal Resistance, Junction-to-Ambient TO-220MF Version 1.4,Jan-2020 Symbol RθJC RθJA 1 www.lonten.cc Package Marking and Ordering Information LNC04R035B/ LND04R035B Device Device Package Marking LNC04R035B TO-220 LNC04R035B LND04R035B TO-220MF LND04R035B Electrical Characteristics Parameter TJ = 25°C unless otherwise noted Symbol Test Condition Min. Typ. Max. Unit Static characteristics Drain-source breakdown voltage BVDSS VGS=0 V, ID=250uA 40 --- --- V Gate threshold voltage VGS(th) VDS=VGS, ID=250uA 1.3 --- 2.5 V Drain-source leakage current IDSS VDS=40 V, VGS=0 V, TJ = 25°C --- --- 1 μA VDS=40 V, VGS=0 V, TJ = 125°C --- --- 5 μA Gate leakage current, Forward IGSSF VGS=20 V, VDS=0 V --- --- 100 nA Gate leakage current, Reverse IGSSR VGS=-20 V, VDS=0 V --- --- -100 nA Drain-source on-state resistance RDS(on) VGS=10 V, ID=20 A --- 2.7 3.5 mΩ VGS=4.5 V, ID=10 A --- 3.8 6.0 mΩ Forward transconductance gfs VDS =5 V , ID=50A 26 --- --- S --- 7810 --- --- 677 --- --- 370 --- --- 15 --- --- 17 --- --- 52 --- --- 23 --- --- 2.12 --- --- 36.4 --- --- 37.3 --- --- 139 --- Dynamic characteristics Input capacitance Ciss Output capacitance Coss Reverse transfer capacitance Crss Turn-on delay time td(on) Rise time tr Turn-off delay time td(off) Fall time tf Gate resistance Rg VDS = 20 V, VGS = 0 V, F = 1MHz VDD = 20V,VGS=10V, ID =20 A VGS=0V, VDS=0V, F=1MHz pF ns Ω Gate charge characteristics Gate to source charge Qgs Gate to drain charge Qgd Gate charge total Qg VDS=20 V, ID=100A, VGS= 10 V nC Drain-Source diode characteristics and Maximum Ratings Continuous Source Current IS --- --- 120 A Pulsed Source Current4) ISM --- --- 480 A Diode Forward Voltage VSD VGS=0V, IS=50A, TJ=25℃ --- --- 1.2 V Reverse Recovery Time trr IS=100A, di/dt=100A/us, --- 42 --- ns Reverse Recovery Charge Qrr TJ=25℃ --- 120 --- nC Notes: 1: The maximum junction current rating is package limited. 2: Repetitive Rating: Pulse width limited by maximum junction temperature. 3: VDD=20V, VGS=10V, L=1mH, IAS=45.6A, RG=25Ω, Starting TJ=25℃. 4: Pulse Test:Pulse Width ≤300μs, Duty Cycle≤2%. Version 1.4,Jan-2020 2 www.lonten.cc LNC04R035B/ LND04R035B Electrical Characteristics Diagrams Figure 1. Typ. Output Characteristics Figure 2. Transfer Characteristics Figure 3. Capacitance Figure 4. Gate Charge Waveform Characteristics Figure 5. Body-Diode Characteristics Version 1.4,Jan-2020 3 www.lonten.cc LNC04R035B/ LND04R035B Figure 6. Normalized Maximum Transient Thermal Impedance (RthJC) Figure 7. Normalized Maximum Transient Thermal Impedance (RthJA) Version 1.4,Jan-2020 4 www.lonten.cc LNC04R035B/ LND04R035B Test Circuit & Waveform Figure 8. Gate Charge Test Circuit & Waveform Figure 9. Resistive Switching Test Circuit & Waveforms Figure 10. Unclamped Inductive Switching (UIS) Test Circuit & Waveform Figure 11. Diode Recovery Circuit & Waveform Version 1.4,Jan-2020 5 www.lonten.cc LNC04R035B/ LND04R035B Mechanical Dimensions for TO-220 COMMON DIMENSIONS SYMBOL MM INCH MIN NOM MAX MIN NOM MAX A 4.37 4.57 4.70 0.172 0.180 0.185 A1 1.25 1.30 1.40 0.049 0.051 0.055 A2 2.20 2.40 2.60 0.087 0.094 0.102 b 0.70 0.80 0.95 0.028 0.031 0.037 b2 1.17 1.27 1.47 0.046 0.050 0.058 c 0.45 0.50 0.60 0.018 0.020 0.024 D 15.10 15.60 16.10 0.594 0.614 0.634 D1 8.80 9.10 9.40 0.346 0.358 0.370 D2 5.50 - - 0.217 - - E 9.70 10.00 10.30 0.382 0.394 0.406 E3 7.00 - - 0.276 - - e 2.54BCS 0.1BSC e1 5.08BCS 0.2REF H1 6.25 6.50 6.85 0.246 0.256 0.270 L 12.75 13.50 13.80 0.502 0.531 0.543 L1 - 3.10 3.40 - 0.122 0.134 ØP 3.40 3.60 3.80 0.134 0.142 0.150 Q 2.60 2.80 3.00 0.102 0.110 0.118 TO-220 Part Marking Information Lonten Logo Lonten LNC04R035B ABYWW99 Part Number “99” Manufacturing code “AB” Foundry & Assembly code “YWW” Date Code Version 1.4,Jan-2020 6 www.lonten.cc LNC04R035B/ LND04R035B Mechanical Dimensions for TO-220MF COMMON DIMENSIONS SYMBOL MM INCH MIN NOM MAX MIN NOM MAX E 9.96 10.16 10.36 0.392 0.400 0.408 A 4.50 4.70 4.90 0.177 0.185 0.193 A1 2.34 2.54 2.74 0.092 0.100 0.108 A2 0.30 0.45 0.60 0.012 0.018 0.024 A4 2.56 2.76 2.96 0.101 0.109 0.117 c 0.40 0.50 0.65 0.016 0.020 0.026 c1 1.20 1.30 1.35 0.047 0.051 0.053 D 15.57 15.87 16.17 0.613 0.625 0.637 H1 6.70REF 0.264REF e 2.54BSC 0.1BSC L 12.68 12.98 13.28 0.499 0.511 0.523 L1 2.88 3.03 3.18 0.113 0.119 0.125 ØP 3.03 3.18 3.38 0.119 0.125 0.133 ØP3 3.15 3.45 3.65 0.124 0.136 0.144 F3 3.15 3.30 3.45 0.124 0.130 0.136 G3 1.25 1.35 1.55 0.049 0.053 0.061 b1 1.18 1.28 1.43 0.046 0.050 0.056 b2 0.70 0.80 0.95 0.028 0.031 0.037 TO-220MF Part Marking Information Lonten Logo “AB” Foundry & Assembly code Lonten LND04R035B ABYWW99 Part Number “99” Manufacturing code “YWW” Date Code Version 1.4,Jan-2020 7 www.lonten.cc LNC04R035B/ LND04R035B Disclaimer The content specified herein is for the purpose of introducing LONTEN's products (hereinafter "Products"). The information given in this document shall in no event be regarded as a guarantee of conditions or characteristics. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. LONTEN does not assume any liability for infringement of patents, copyrights, or other intellectual property rights of third parties by or arising from the use of the Products or technical information described in this document. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). LONTEN shall bear no responsibility in any way for use of any of the Products for the above special purposes. Although LONTEN endeavors to improve the quality and reliability of its products, semiconductor products have specific characteristics such as the occurrence of failure at a certain rate and malfunctions under certain use conditions. Please be sure to implement safety measures to guard them against the possibility of physical injury, and injury or damage caused by fire in the event of the failure of a LONTEN product. The content specified herein is subject to change for improvement without notice. When using a LONTEN product, be sure to obtain the latest specifications. Version 1.4,Jan-2020 8 www.lonten.cc
LNC04R035B 价格&库存
很抱歉,暂时无法提供与“LNC04R035B”相匹配的价格&库存,您可以联系我们找货
