SE100130A
N-Channel Enhancement-Mode MOSFET
Revision: A
General Description
Advanced trench technology to provide
excellent RDS(ON), low gate charge and
low operation voltage. This device is
suitable for using as a load switch or in
PWM applications.
Simple Drive Requirement
Small Package Outline
Surface Mount Device
Features
For a single MOSFET
VDS = 100V
RDS(ON) = 3.0mΩ @ VGS=10V
Pin configurations
See Diagram below
TO-220
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
100
V
Gate-Source Voltage
VGS
±20
V
Drain Current
Continuous
Pulsed
ID
Single Pulse Avalanche Energy
Total Power Dissipation
@TA=25℃
Operating Junction Temperature Range
ShangHai Sino-IC Microelectronic Co., Ltd.
130
500
A
1100
mJ
PD
285
W
TJ
-55 to 150
1.
SE100130A
Electrical Characteristics
Symbol
(TJ=25℃ unless otherwise noted)
Parameter
Test Conditions
Min
Typ
Max
Units
OFF CHARACTERISTICS (Note 2)
BVDSS
Drain-Source Breakdown Voltage
ID=250μA, VGS=0V
IDSS
Drain to Source Leakage Current
VDS= 100V, VGS=0V
IGSS
Gate-Body Leakage Current
VGS= 20V
VGS(th)
Gate Threshold Voltage
VDS= VGS, ID=250μA
RDS(ON)
Static Drain-Source On-Resistance
VGS=10V, ID=40A
3.0
Forward Transconductance
VDS=5V, ID=20A
75
S
3650
pF
290
pF
88
pF
56
nC
14
nC
18
nC
gFS
100
V
1.0
1
μA
100
nA
3.0
V
4.0
mΩ
DYNAMIC PARAMETERS
Ciss
Input Capacitance
VGS=0V, VDS=50V,
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
f=1MHz
SWITCHING PARAMETERS
2
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
Turn-On Delay Time
VGS=10V, VDS=50V,
17
ns
td(off)
Turn-Off Delay Time
RGEN=3Ω,
57
ns
td(r)
Turn-On Rise Time
40
ns
td(f)
Turn-Off Fall Time
37
ns
VGS=10V, VDS=50V,
ID=65A
REVERSE DIODE
Diode Continuous Forward Current
TC=25℃
VSD
Diode Forward Voltage
VDS=0V,IF=20V,
0.9
Trr
Reverse Recovery Time
VR=50V, IF=IS
50
ns
Qrr
Reverse Recovery Charge
dI/dT=500A/us
255
nC
IS
A
1.2
V
2.
SE100130A
Test Circuits and Waveform
3.
SE100130A
Typical Characteristics
4.
SE100130A
5.
SE100130A
Package Outline Dimension
TO-220
6.
SE100130A
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402
33932403
33932405
33933508
33933608
Fax: +86-21-33932401
Email: webmaster@sino-ic.net
Website: http://www.sino-ic.net
7.
很抱歉,暂时无法提供与“SE100130A”相匹配的价格&库存,您可以联系我们找货
