HY3008P/M/B/ MF /PL/PM
N-Channel Enhancement Mode MOSFET
Feature
z
Pin Description
80V/100A
RDS(ON)= 6.6mΩ(typ.)@VGS = 10V
z
z
z
100% Avalanche Tested
G
Reliable and Rugged
G
Lead- Free Devices Available
D
D
G
S
D
S
S
TO-220FB-3L
TO-263-2L
TO-220FB-3M
(RoHS Compliant)
Applications
z
Switching application
z
Power management for inverter systems
G
G
D
TO-220MF-3L
S
G
D
D
S
S
TO-3PM-3L
TO-3PM-3S
N-Channel MOSFET
Ordering and Marking Information
P
M
B
HY3008
HY3008
HY3008
YYXXXJWW G
YYXXXJWW G
YYXXXJWW G
MF
PM
PL
HY3008
HY3008
HY3008
YYXXXJWW G
YYXXXJWW G
YYXXXJWW G
Package Code
P :TO-220FB-3L
B:TO-263-2L
PM:TO-3PM-3S
M:TO-220FB-3S
MF:TO-220MF-3L
PL:TO-3PM-3L
Date Code
YYXXX WW
Assembly Material
G:Lead Free
Note: HUAYI lead -free products contain molding compounds/die attach materials and 100% matte tin plate TermiNation finish;which are fully compliant with RoHS. HUAYI lead -free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hymexa.com
V1.0
1
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (Tc=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
80
V
VGSS
Gate-Source Voltage
±25
V
Maximum Junction Temperature
-55 to 175
°C
Storage Temperature Range
-55 to 175
°C
Tc=25°C
100
A
Tc=25°C
400**
A
Tc=25°C
100
A
Tc=100°C
70
A
Tc=25°C
200
W
Tc=100°C
100
W
TJ
TSTG
IS
Source Current-Continuous(Body Diode)
Mounted on Large Heat Sink
Note:
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RTJC
Thermal Resistance, Junction-to-Case
0.75
°C/W
RTJA
Thermal Resistance, Junction-to-Ambient **
62.5
°C/W
EAS
SinglePulsed-Avalanche Energy ***
L=0.3 mH
407***
mJ
* Repetitive rating˗pulse width limited by max.junction temperature.
** Surface mounted on 1in2 FR-4 board.
*** Limited by TJmax , starting TJ=25°C, L = 0.3mH, RG= 25Ω, VGS =10V.
Electrical Characteristics(Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HY3008
Unit
Min
Typ.
Max
80
V
1
μA
50
μA
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Drain-to-Source Leakage Current
VGS(th)
IGSS
RDS(ON)
VGS=0V,IDS= 250μA
VDS= 80V,VGS=0V
TJ=125°C
Gate Threshold Voltage
VDS=VGS, IDS= 250μA
2
3
4
V
Gate-Source Leakage Current
VGS=f25V,VDS=0V
±100
nA
Drain-Source On-State Resistance
VGS= 10V,IDS= 50A
6.6
8.5
mΩ
ISD=50A,VGS=0V
0.8
1
V
62
ns
127
nC
Diode Characteristics
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ISD=50A,dISD/dt=100A/μs
www.hymexa.com
V1.0
2
Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HY3008
Min
Typ.
Max
Unit
Dynamic Characteristics
RG
Gate Resistance
VGS=0V,VDS=0V,F=1MHz
1.0
Ciss
Input Capacitance
VGS=0V,
3150
Coss
Output Capacitance
VDS= 25V,
440
Crss
Reverse Transfer Capacitance
Frequency=1.0MHz
199
td(ON)
Turn-on Delay Time
23
Tr
Turn-on Rise Time
VDD= 40V,RG=3Ω,
39
td(OFF)
Turn-off Delay Time
IDS= 50A,VGS= 10V
55
33
67
14
22
Tf
Turn-off Fall Time
Gate Charge
Ω
pF
ns
Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS = 64V, VGS= 10V,
IDs= 50A
nC
Note: *Pulse testˈpulse width ≤ 300usˈduty cycle ≤ 2%
www.hymexa.com
V1.0
3
Typical Operating Characteristics
Figure 2: Drain Current
ID-Drain Current(A)
Power Dissipation (w)
Figure 1: Power Dissipation
Tc-Case Temperature(ć)
Thermal
Z©jc
ID-Drain Current(A)
Impedance
Figure 4: Thermal Transient Impedance
Normalized Transient
Figure 3: Safe Operation Area
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
Figure 5: Output Characteristics
Figure 6: Drain-Source On Resistance
ID-Drain Current(A)
RDS(ON)-ON-Resistance(mΩ)
VDS-Drain-Source Voltage(V)
VDS-Drain-Source Voltage (V)
ID-Drain Current(A)
www.hymexa.com
V1.0
4
Typical Operating Characteristics(Cont.)
Figure 8: Source-Drain Diode Forward
IS-Source Current (A)
Normalized On-Resistance
Figure 7: On-Resistance vs. Temperature
Tj-Junction Temperature (ć)
VSD-Source-Drain Voltage(V)
Figure 9: Capacitance Characteristics
Figure 10: Gate Charge Characteristics
C-Capacitance(pF)
VGS-Gate-Source Voltage (V)
12
QG-Gate Charge (Q&)
www.hymexa.com
V1.0
5
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
V1.0
6
Device Per Unit
Package Type
Unit
Quantity
TO-220FB-3L
Tube
50
Package Information
TO-220FB-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.25
1.30
1.45
A2
2.20
2.40
2.60
b
0.70
0.80
0.95
b2
1.17
1.27
1.47
c
0.40
0.50
0.65
D
15.10
15.60
16.10
D1
8.80
9.10
9.40
D2
5.50
E
9.70
10.00
10.30
E3
7.00
e
2.54 BSC
e1
5.08 BSC
H1
6.25
6.50
6.85
L
12.75
13.50
13.80
L1
3.10
3.40
ΦP
3.40
3.60
3.80
Q
2.60
2.80
3.00
www.hymexa.com
V1.0
7
Device Per Unit
Package Type
Unit
Quantity
TO-220FB-3S
Tube
50
Package Information
TO-220FB-3S
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.25
1.30
1.45
A2
2.20
2.40
2.60
b
0.70
0.80
0.95
b2
1.17
1.27
1.47
c
0.40
0.50
0.65
D
15.10
15.60
16.10
D1
8.10
9.10
9.40
D2
5.50
E
9.70
10.00
10.30
E3
7.00
e
2.54 BSC
e1
5.08 BSC
H1
6.25
6.50
6.85
L
6.80
7.00
7.20
L1
3.10
3.40
ΦP
3.40
3.60
3.80
Q
2.60
2.80
3.00
www.hymexa.com
V1.0
8
Device Per Unit
Package Type
Unit
Quantity
TO-263-2L
Reel
50
Package Information
TO-263-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.22
1.27
1.42
A2
2.49
2.69
2.89
A3
0.25
b
0.7
0.81
0.96
b1
1.17
1.27
1.47
c
0.3
0.38
0.53
D1
8.5
8.7
8.9
D4
6.6
E
9.86
10.16
10.36
E5
7.06
e
2.54 BSC
H
14.7
15.1
15.5
H2
1.07
1.27
1.47
L
2
2.3
2.6
L1
1.4
1.55
1.7
L4
θ
0.25 BSC
0°
5°
www.hymexa.com
9°
V1.0
9
Device Per Unit
Package Type
Unit
Quantity
TO-220MF-3L
Tube
50
Package Information
TO-220MF-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
E
9.96
10.16
10.36
A
4.50
4.70
4.90
A1
2.34
2.54
2.74
A2
0.30
0.45
0.60
A4
2.56
2.76
2.96
c
0.40
0.50
0.65
c1
1.20
1.30
1.35
D
15.57
15.87
16.17
H1
6.70REF
e
2.54BSC
L
12.68
12.98
13.28
L1
2.93
3.03
3.13
ΦP
3.03
3.18
3.38
ΦP3
3.15
3.45
3.65
F3
3.15
3.30
3.45
G3
1.25
1.35
1.55
b1
1.18
1.28
1.43
b2
0.70
0.80
0.95
www.hymexa.com
V1.0
10
Device Per Unit
Package Type
Unit
Quantity
TO-3PM-3L
Tube
50
Package Information
TO-3PM-3L
www.hymexa.com
V1.0
11
Device Per Unit
Package Type
Unit
Quantity
TO-3PM-3S
Tube
50
Package Information
TO-3PM-3S
www.hymexa.com
V1.0
12
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmaxto TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tpto Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
SeeClassification Tempin table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
V1.0
13
Table 1.SnPb Eutectic Process – Classification Temperatures (Tc)
Package
Volume mmϢ
Volume mmϢ
Thickness
很抱歉,暂时无法提供与“HY3008P”相匹配的价格&库存,您可以联系我们找货
