HSP0048
N-Ch 100V Fast Switching MOSFETs
Description
Product Summary
The HSP0048 is the high cell density trenched Nch MOSFETs, which provide excellent RDSON and
gate charge for most of the Synchronous
Rectification for AC/DC Quick Charger.
100% EAS Guaranteed
Low RDS(ON)
Low Gate Charge
RoHs and Halogen-Free Compliant
VDS
100
V
RDS(ON),typ
6.6
mΩ
ID
80
A
TO220 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
±20
V
Current 1,6
ID@TC=25℃
Continuous Drain
80
A
ID@TC=100℃
Continuous Drain Current 1,6
70.7
A
IDM
Pulsed Drain Current2
350
A
EAS
Single Pulse Avalanche Energy3
61
mJ
IAS
Avalanche Current
35
A
188
W
PD@TC=25℃
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
58
℃/W
0.8
℃/W
1
HSP0048
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
RDS(ON)
VGS(th)
IDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
Min.
Typ.
Max.
Unit
V
VGS=0V , ID=250uA
100
Static Drain-Source
On-Resistance 2
VGS=10V , ID=13.5A
6.6
9
Static Drain-Source
On-Resistance 2
VGS=4.5V , ID=11.5A
8.7
12
VGS=VDS , ID =250uA
1.2
3
VDS=80V , VGS=0V , TJ=25℃
1
VDS=80V , VGS=0V , TJ=55℃
5
Gate Threshold Voltage
Drain-Source Leakage Current
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=20A
85
S
Qg
Total Gate Charge (10V)
45
Qg
Total Gate Charge (4.5V)
19.3
Qgs
Gate-Source Charge
9.5
Qgd
Gate-Drain Charge
4.8
Td(on)
Turn-On Delay Time
VDS=50V , VGS=10V , ID=13.5A
nC
10
Rise Time
VDD=50V , VGS=10V , RG=3,
6.5
Turn-Off Delay Time
ID=13.5A
45
Fall Time
7.5
Ciss
Input Capacitance
3320
Coss
Output Capacitance
605
Crss
Reverse Transfer Capacitance
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
80
A
VGS=0V , IS=1A , TJ=25℃
1.1
V
Tr
Td(off)
Tf
VDS=50V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current 1,5,6
Voltage 2
Conditions
trr
Reverse Recovery Time
IF=13.5A , di/dt=100A/µs ,
33
nS
Qrr
Reverse Recovery Charge
TJ=25℃
150
nC
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.3mH,IAS=35A
4.The power dissipation is limited by junction temperature
5.The data is theoretically the same as I D and I DM , in real applications , should be limited by total power dissipation.
6.The maximum current rating is package limited.
www.hs-semi.cn
Ver 2.0
2
HSP0048
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
Fig.3 Source-Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
Fig.5 Normalized VGS(th) vs. TJ
Fig.6 Normalized RDSON vs. TJ
www.hs-semi.cn
Ver 2.0
3
HSP0048
Fig.8 Safe Operating Area
Fig.7 Capacitance
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
P DM
T ON
SINGLE
T
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.11 Unclamped Inductive Switching Waveform
Fig.10 Switching Time Waveform
www.hs-semi.cn
Ver 2.0
4
很抱歉,暂时无法提供与“HSP0048”相匹配的价格&库存,您可以联系我们找货
