WSR60N06D
N-Ch MOSFET
General Description
Product Summery
BVDSS
The WSR60N06D uses advanced trench technology
and design to provide excellent RDS(ON) with low
60V
gate charge. It can be used in a wide variety of
RDSON
ID
13.5mΩ
60A
applications.
Application
● Power switching application
● LED backlighting
● Uninterruptible power supply
Features
● High density cell design for ultra low Rdson
TO-220AB Pin Configuration
● Fully characterized avalanche voltage and current
● Good stability and uniformity with high EAS
● Excellent package for good heat dissipation
● Special process technology for high ESD capability
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=100℃
IDM
EAS
PD@TC=25℃
TJ TSTG
Rating
Units
Drain-Source Voltage
60
V
Gate-Source Voltage
±20
V
60
A
1
Continuous Drain Current, VGS @ 10V
1
41
A
120
A
390
mJ
Total Power Dissipation
89
W
Operating Junction Temperature Range
-55 to 150
Pulsed Drain Current
2
3
Single Pulse Avalanche Energy
4
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.winsok.tw
Page 1
1
Max.
Unit
62
℃/W
1.68
℃/W
Rev 1: Fed.2022
WSR60N06D
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
60
V
Reference to 25℃ , ID=1mA
0.057
V/℃
VGS=10V , ID=20A
13.5
VGS=4.5V , ID=10A
19
30
VGS=0V , ID 250uA
mΩ
1.2
1.8
2.5
V
-5.68
mV/℃
VDS=48V , VGS=0V , TJ=25℃
1
VDS=48V , VGS=0V , TJ=55℃
5
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=20A
25
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.7
Ω
Qg
Total Gate Charge (4.5V)
19.3
Qgs
Gate-Source Charge
7.1
Qgd
Gate-Drain Charge
7.6
7.2
50
Turn-Off Delay Time
36.4
Fall Time
7.6
Ciss
Input Capacitance
2426
Coss
Output Capacitance
145
Crss
Reverse Transfer Capacitance
97
Min.
Typ.
Max.
Unit
35
A
90
A
1.2
V
16.3
nS
11
nC
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Td(on)
Tr
Td(off)
Tf
VGS=VDS , ID =250uA
VDS=30V , VGS=4.5V , ID=15A
Turn-On Delay Time
VDS=30V , VGS=10V ,
ID=15A , R=3.3Ω.
Rise Time
VDS=15V , VGS=0V , f=1MHz
uA
nC
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,6
IS
Continuous Source Current
ISM
Pulsed Source Current2,6
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=1A ,dI/dt=100A/µs,TJ=25℃
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
5. EAS condition: Tj=25℃,VDD=30V,VG=10V,L=0.5mH,Rg=25Ω
www.winsok.tw
Page 2
Rev 1: Fed.2022
WSR60N06D
N-Ch MOSFET
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs Gate-Source Voltage
12
IS Source Current(A)
10
8
6
TJ=150℃
TJ=25℃
4
2
0.4
0.6
0.8
VSD , Source-to-Drain Voltage (V)
1
Fig.3 Forward Characteristics of Reverse
Fig.4 Gate-Charge Characteristics
2.0
Normalized On Resistance
Normalized VGS(th)
1.5
1.5
1
1.0
0.5
0.5
100
TJ ,Junction Temperature ( ℃)
-50
150
Fig.5 Normalized VGS(th) vs TJ
www.winsok.tw
100
TJ , Junction Temperature (℃)
150
Fig.6 Normalized RDSON vs TJ
Page 3
Rev 1: Fed.2022
WSR60N06D
N-Ch MOSFET
Capacitance (pF)
10000
F=1.0MHz
Ciss
1000
Coss
100
Crss
10
1
5
9
13
17
VDS Drain to Source Voltage(V)
21
25
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.3
0.1
0.1
0.05
PDM
0.02
0.01
0.01
0.00001
TON
D = TON/T
TJpeak = TC + PDM x RθJC
SINGLE PULSE
0.0001
T
0.001
0.01
0.1
1
10
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
BVDSS
BVDSS-VDD
VDD
IAS
Tf
Toff
Fig.10 Switching Time Waveform
www.winsok.tw
BVDSS
1
L x IAS2 x
2
VGS
Fig.11 Unclamped Inductive Switching Waveform
Page 4
Rev 1: Fed.2022
Attention
1,AnyandallWinsokpowerproductsdescribedorcontainedhereindonothavespecificationsthatcanhandle
applicationsthatrequireextremelyhighlevelsofreliability,suchaslifeͲsupportsystems,aircraft'scontrolsystems,or
otherapplicationswhosefailurecanbereasonablyexpectedtoresultinseriousphysicaland/ormaterialdamage.
ConsultwithyourWinsokpowerrepresentativenearestyoubeforeusinganyWinsokpowerproductsdescribedor
containedhereininsuchapplications.
2,Winsokpowerassumesnoresponsibilityforequipmentfailuresthatresultfromusingproductsatvaluesthatexceed,
evenmomentarily,ratedvalues(suchasmaximumratings,operatingconditionranges,orotherparameters)listedin
productsspecificationsofanyandallWinsokpowerproductsdescribedorcontainedherein.
3,SpecificationsofanyandallWinsokpowerproductsdescribedorcontainedhereinstipulatetheperformance,
characteristics,andfunctionsofthedescribedproductsintheindependentstate,andarenotguaranteesofthe
performance,characteristics,andfunctionsofthedescribedproductsasmountedinthecustomer’sproductsor
equipment.Toverifysymptomsandstatesthatcannotbeevaluatedinanindependentdevice,thecustomershouldalways
evaluateandtestdevicesmountedinthecustomer’sproductsorequipment.
4,WinsokpowerSemiconductorCO.,LTD.strivestosupplyhighͲqualityhighͲreliabilityproducts.However,anyandall
semiconductorproductsfailwithsomeprobability.Itispossiblethattheseprobabilisticfailurescouldgiverisetoaccidents
oreventsthatcouldendangerhumanlivesthatcouldgiverisetosmokeorfire,orthatcouldcausedamagetoother
property.Whendesigningequipment,adoptsafetymeasuressothatthesekindsofaccidentsoreventscannotoccur.Such
measuresincludebutarenotlimitedtoprotectivecircuitsanderrorpreventioncircuitsforsafedesign,redundantdesign,
andstructuraldesign.
5,IntheeventthatanyorallWinsokpowerproducts(includingtechnicaldata,services)describedorcontainedhereinare
controlledunderanyofapplicablelocalexportcontrollawsandregulations,suchproductsmustnotbeexportedwithout
obtainingtheexportlicensefromtheauthoritiesconcernedinaccordancewiththeabovelaw.
6,Nopartofthispublicationmaybereproducedortransmittedinanyformorbyanymeans,electronicormechanical,
includingphotocopyingandrecording,oranyinformationstorageorretrievalsystem,orotherwise,withouttheprior
writtenpermissionofWinsokpowerSemiconductorCO.,LTD.
7,Information(includingcircuitdiagramsandcircuitparameters)hereinisforexampleonly;itisnotguaranteedfor
volumeproduction. Winsokpowerbelievesinformationhereinisaccurateandreliable,butnoguaranteesaremadeor
impliedregardingitsuseoranyinfringementsofintellectualpropertyrightsorotherrightsofthirdparties.
8,Anyandallinformationdescribedorcontainedhereinaresubjecttochangewithoutnoticeduetoproduct/technology
improvement,etc.Whendesigningequipment,refertothe"DeliverySpecification"fortheWinsokpowerproductthatyou
Intendtouse.
9,thiscatalogprovidesinformationasofSep.2014. Specificationsandinformationhereinaresubjecttochangewithout
notice.
