AP60N03F
AP60N03F
    APM-MICROELECTRONICS(永源微)
    TO-220-3
AP60N03F 数据手册
AP60N03FITIP 30V N-Channel Enhancement Mode MOSFET Description The AP60N03F/T/P uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 4.5V. This device is suitable for use as a Battery protection or in other Switching application. General Features VDS = 30V ID =60A RDS(ON) < 8.5mΩ @ VGS=10V (Type:6.0mΩ) Application BLDC Wireless impact Mobile phone fast charging Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) AP60N03F TO-220-3L AP60N03F XXX YYYY 1000 AP60N03T TO-263-3L AP60N03T XXX YYYY 800 AP60N03P TO-220-3L AP60N03P XXX YYYY 1000 Rating Units Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter Drain-Source Voltage 30 V Gate-Source Voltage ±20 V ID@TC=25℃ Continuous Drain Current, VGS @ 10V1 60 A ID@TC=100℃ Continuous Drain Current, VGS @ 10V1 40 A IDM Pulsed Drain Current2 92 A EAS Single Pulse Avalanche Energy3 57.8 mJ IAS Avalanche Current 34 A PD@TC=25℃ Total Power Dissipation4 29 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ RθJA Thermal Resistance Junction-ambient 1 62 ℃/W RθJC Thermal Resistance Junction-Case1 4.32 ℃/W AP60N03F/T/P RVE1.1 永源微電子科技有限公司 1 VDS VGS AP60N03FITIP 30V N-Channel Enhancement Mode MOSFET Electrical Characteristics (TC=25℃unless otherwise noted) Symbol Parameter Conditions Min. Typ. Max. Unit BVDSS Drain-Source Breakdown Voltage VGS=0V , ID=250uA 30 33 --- V RDS(ON) Static Drain-Source On-Resistance2 VGS=10V , ID=12A VGS=4.5V , ID=10A VGS(th) Gate Threshold Voltage ----1.0 6.0 8.0 1.6 8.5 13 2.5 △VGS(th) VGS(th) Temperature Coefficient --- -5.8 --- IDSS Drain-Source Leakage Current VDS=24V , VGS=0V , TJ=25℃ --- --- 1 VDS=24V , VGS=0V , TJ=55℃ --- --- 5 IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 gfs Forward Transconductance VDS=5V , ID=15A --- 9.8 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 1.7 --- Ω --- 12.8 --- --- 3.3 --- --- 6.5 --- --- 4.5 --- --- 10.8 --- --- 25.5 --- VGS=VDS , ID =250uA mΩ V mV/℃ uA nA Qg Total Gate Charge (4.5V) Qgs Gate-Source Charge Qgd Gate-Drain Charge Td(on) Turn-On Delay Time Tr Rise Time Td(off) Turn-Off Delay Time Tf Fall Time --- 9.6 --- Ciss Input Capacitance --- 1317 --- --- 163 --- --- 131 --- --- --- 46 A --- --- 92 A --- --- 1 V Coss Output Capacitance Crss Reverse Transfer Capacitance IS Continuous Source Current1,6 Current2,6 ISM Pulsed Source VSD Diode Forward Voltage2 VDS=20V , VGS=4.5V , ID=12A VDD=12V , VGS=10V , RG=3.3Ω ID=5A VDS=15V , VGS=0V , f=1MHz VG=VD=0V , Force Current VGS=0V , IS=1A , TJ=25℃ nC ns pF Note : 1、The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2、The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3、The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=34A 4、The power dissipation is limited by 150℃ junction temperature 5、The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. 2 AP60N03F/T/P RVE1.1 永源微電子科技有限公司 AP60N03FITIP 30V N-Channel Enhancement Mode MOSFET Typical Characteristics 3 AP60N03F/T/P RVE1.1 永源微電子科技有限公司 AP60N03FITIP 30V N-Channel Enhancement Mode MOSFET 4 AP60N03F/T/P RVE1.1 永源微電子科技有限公司 AP60N03FITIP 30V N-Channel Enhancement Mode MOSFET Package Mechanical Data-PDFN5*6-8L-JQ Single 5 AP60N03F/T/P RVE1.1 永源微電子科技有限公司 AP60N03FITIP 30V N-Channel Enhancement Mode MOSFET Attention 1,Any and all APM Microelectronics products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your APM Microelectronics representative nearest you before using any APM Microelectronics products described or contained herein in such applications. 2,APM Microelectronics assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all APM Microelectronics products described or contained herein. 3, Specifications of any and all APM Microelectronics products described or contained here instipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. 4, APM Microelectronics Semiconductor CO., LTD. strives to supply high quality high reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives that could give rise to smoke or fire, or that could cause damage to other property. Whendesigning equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design,and structural design. 5,In the event that any or all APM Microelectronics products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. 6, No part of this publication may be reproduced or transmitted in any form or by any means,electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of APM Microelectronics Semiconductor CO., LTD. 7, Information (including circuit diagrams and circuit parameters) herein is for example only; it is not guaranteed for volume production. APM Microelectronics believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. 8, Any and all information described or contained herein are subject to change without notice due to product/technology improvement,etc. When designing equipment, refer to the "Delivery Specification" for the APM Microelectronics product that you Intend to use. 6 AP60N03F/T/P RVE1.1 永源微電子科技有限公司 AP60N03FITIP 30V N-Channel Enhancement Mode MOSFET Edition Date Change Rve1.0 2019/4/10 Initial release Rve1.1 2022/1/10 Reduce internal RDS Copyright Attribution“APM-Microelectronice” 7 AP60N03F/T/P RVE1.1 永源微電子科技有限公司
AP60N03F 价格&库存
很抱歉,暂时无法提供与“AP60N03F”相匹配的价格&库存,您可以联系我们找货
