AP120N06PIT
65V N-Channel Enhancement Mode MOSFET
Description
The AP120N06P/T uses advanced trench technology
to provide excellent RDS(ON), low gate charge and
operation with gate voltages as low as 10V. This
device is suitable for use as a Battery protection
or in other Switching application.
General Features
VDS = 65V ID =125A
RDS(ON) < 5.6mΩ @ VGS=10V (Type:4.8mΩ)
Application
Battery protection
Load switch
Uninterruptible power supply
Package Marking and Ordering Information
Product ID
Pack
Marking
Qty(PCS)
AP120N06P
TO-220-3L
AP120N06P XXX YYYY
1000
AP120N06T
TO-263-3L
AP120N06T XXX YYYY
800
Absolute Maximum Ratings@Tj=25oC(unless otherwise specified)
Symbol
Parameter
Value
Unit
VDS
Drain source voltage
65
V
VGS
Gate source voltage
±25
V
ID
Continuous drain current1)
125
A
IDM
Pulsed drain current2)
492
A
IAS
Diode forward current
55
A
PD
Power dissipation
172
W
EAS
Single pulsed avalanche energy)
225
mJ
Tstg,Tj
Operation and storage temperature
-55 to 150
RθJC
Thermal resistance, junction-case
1.4
℃/W
RθJA
Thermal resistance, junction-ambient4)
62.5
℃/W
1
AP120N06P/T RVE1.0
永源微電子科技有限公司
AP120N06PIT
Electrical Characteristics (TJ=25℃, unless otherwise noted)
Symbol
Parameter
Test Condition
V(BR)DSS
Drain-Source Breakdown Voltage
VGS=0V, ID=250μA
65
72
V
IDSS
Zero Gate Voltage Drain Current
VDS=60V, VGS=0V,
1.0
μA
IGSS
Gate to Body Leakage Current
VDS=0V, VGS=±20V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=250μA
2.0
2.8
4.0
V
RDS(on)
Static Drain-Source on-Resistance note
VGS=10V, ID=55A
4.8
5.6
mΩ
Ciss
Input Capacitance
3135
pF
Coss
Output Capacitance
521
pF
Crss
Reverse Transfer Capacitance
306
pF
Qg
Total Gate Charge
77
nC
18
nC
VDS=30V, VGS=0V, f=1.0MHz
VDS=30V, ID=55A,
VGS=10V
Min. Typ. Max. Units
Qgs
Gate-Source Charge
Qgd
Gate-Drain(“Miller”) Charge
30
nC
td(on)
Turn-on Delay Time
15
ns
tr
Turn-on Rise Time
89
ns
td(off)
Turn-off Delay Time
36
ns
tf
Turn-off Fall Time
91
ns
123
A
492
A
1.2
V
32
ns
31
nC
IS
Maximum Continuous Drain to Source Diode ForwardCurrent
ISM
VSD
trr
Qrr
VDS=30V, ID=55A,
RG=1.8Ω, VGS=10V
Maximum Pulsed Drain to Source Diode Forward Current
Drain to Source Diode Forward Voltage
VGS=0V, IS=30A
Body Diode Reverse Recovery Time
Body Diode Reverse Recovery Charge
IF=550A, dI/dt=100A/μs
Note :
1、The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2、The data tested by pulsed , pulse width .The EAS data shows Max. rating .
3、The test cond≦ 300us duty cycle ≦ 2%, duty cycle ition is TJ =25℃, VDD =35V, VG =10V, R G =25Ω, L=0.5mH, IAS =55A
4、The power dissipation is limited by 175℃ junction temperature
5、The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
2
AP120N06P/T RVE1.0
永源微電子科技有限公司
AP120N06PIT
60V N-Channel Enhancement Mode MOSFET
Electrical Characteristics Diagrams
Figure1: Output Characteristics
Figure 3: Rds(on) vs Drain Current and
AP120N06P/T RVE1.0
Figure 4: Rds(on) vs Gate Voltage
Figure 6: Capacitance Characteristics
永源微電子科技有限公司
3
Figure 5: Rds(on) vs. Temperature
Figure 2: Typical Transfer Characteristics
AP120N06PIT
Figure 7: Gate Charge Characteristics
Figure 9: Power Dissipation
Figure 8: Body-diode Forward Characteristics
Figure 10: Drain Current Derating
Figure.11: Safe Operating Area
4
AP120N06P/T RVE1.0
永源微電子科技有限公司
AP120N06PIT
Package Mechanical Data-TO-220-3L-SLK
Symbol
A
A1
A2
b
b2
D
D1
D2
E
E1
E2
E3
e
e1
H1
L
L1
Φp
Q
θ1
θ2
F
F1
F2
Mim
4.27
1.15
2.10
0.70
1.17
0.40
8.80
5.70
9.70
9.63
7.00
6.00
12.75
3.45
2.60
4°
0°
13.30
15.50
2.80
Common
mm
Nom
4.57
1.30
2.40
0.80
1.27
0.50
9.10
6.70
10.00
8.70
10.00
8.00
0.37
0.10
6.50
13.50
3.10
3.60
2.80
7°
3°
13.50
15.90
3.00
Max
4.87
1.45
2.70
1.00
1.50
0.65
9.40
7.00
10.30
10.35
8.40
6.85
13.90
3.40
3.75
3.00
10°
6°
13.70
16.30
3.20
5
AP120N06P/T RVE1.0
永源微電子科技有限公司
AP120N06PIT
Package Mechanical Data-TO-263-3L-SLK
Symbol
A
A1
A2
b
b2
C
C1
D
D1
E
E1
H
e
L
L1
L2
R
θ
Θ1
Θ2
Mim
4.35
0.09
2.30
0.70
1.25
0.45
1.29
9.10
7.90
9.85
7.90
15.30
2.34
1.00
1.30
0.24
0°
4°
0°
Common
mm
Nom
4.47
0.10
2.40
0.80
1.36
0.50
1.30
9.20
8.00
10.00
8.00
15.50
2.54
2.54
1.10
1.40
0.25
4°
7°
3°
Max
4.60
0.11
2.70
1.00
1.50
0.65
9.40
9.30
8.10
10.20
8.10
15.70
2.74
1.20
1.50
0.26
8°
10°
6°
6
AP120N06P/T RVE1.0
永源微電子科技有限公司
AP120N06PIT
Attention
1,Any and all APM Microelectronics products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in
serious physical and/or material damage. Consult with your APM Microelectronics representative nearest
you before using any APM Microelectronics products described or contained herein in such applications.
2,APM Microelectronics assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition
ranges, or other parameters) listed in products specifications of any and all APM Microelectronics
products described or contained herein.
3, Specifications of any and all APM Microelectronics products described or contained here instipulate the
performance, characteristics, and functions of the described products in the independent state, and are
not guarantees of the performance, characteristics, and functions of the described products as mounted
in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an
independent device, the customer should always evaluate and test devices mounted in the customer’s
4, APM Microelectronics Semiconductor CO., LTD. strives to supply high quality high reliability products.
However, any and all semiconductor products fail with some probability. It is possible that these
probabilistic failures could give rise to accidents or events that could endanger human lives that could
give rise to smoke or fire, or that could cause damage to other property. Whendesigning equipment,
adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include
but are not limited to protective circuits and error prevention circuits for safe design, redundant
design,and structural design.
5,In the event that any or all APM Microelectronics products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from the authorities concerned in
accordance with the above law.
6, No part of this publication may be reproduced or transmitted in any form or by any means,electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or
otherwise, without the prior written permission of APM Microelectronics Semiconductor CO., LTD.
7, Information (including circuit diagrams and circuit parameters) herein is for example only; it is not
guaranteed for volume production. APM Microelectronics believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual
property rights or other rights of third parties.
8, Any and all information described or contained herein are subject to change without notice due to
product/technology improvement,etc. When designing equipment, refer to the "Delivery Specification" for
the APM Microelectronics product that you Intend to use.
7
AP120N06P/T RVE1.0
永源微電子科技有限公司
AP120N06PIT
Edition
Date
Change
Rve1.0
2021/12/14
Initial release
Copyright Attribution“APM-Microelectronice”
8
AP120N06P/T RVE1.0
永源微電子科技有限公司
