HY3712P/M/B/PS/PM
N-Channel Enhancement Mode MOSFET
Features
Pin Description
• 125V/170A
RDS(ON) = 6.3 m(typ.) @ VGS=10V
100% avalanche tested
G
Reliable and Rugged
Lead Free and Green Devices Available
G
D
D
G
S
D
S
S
TO-263-2L
TO-220FB-3M
TO-220FB-3L
(RoHS Compliant)
G
G
D
TO-220MF-3L
Applications
Switching application
Power Management for Inverter Systems.
Ordering and Marking Information
S
G
D
D
S
S
TO-3PS-3L
TO-3PM-3S
N-Channel MOSFET
Package Code
P
HY3712
M
HY3712
B
HY3712
YYXXXJWW G
YYXXXJWW G
YYXXXJWW G
PS
HY3712
PM
HY3712
YYXXXJWW G
YYXXXJWW G
P : TO-220FB-3L
B: TO-263-2L
PM: TO-3PM-3S
Date Code
YYXXX WW
M : TO-220FB-3M
PS: TO-3PS-3L
Assembly Material
G : Lead Free Device
Note: HUAYI lead -free products contain molding compounds/die attach materials and 100% matte tin plate
Termination finish;which are fully compliant with RoHS. HUAYI lead -free products meet or exceed the leadFree requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature.
HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed
900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements
to this pr-oduct and/or to this document at any time without notice.
www.hymexa.com
1
V1.0
HY3712P/M/B/PS/PM
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (TC=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
125
VGSS
Gate-Source Voltage
±25
Maximum Junction Temperature
175
TJ
TSTG
IS
Storage Temperature Range
V
°C
-55 to 175
Diode Continuous Forward Current
°C
TC=25°C
170
A
TC=25°C
585**
A
TC=25°C
170
TC=100°C
124
TC=25°C
339
TC=100°C
170
Mounted on Large Heat Sink
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance-Junction to Case
0.44
RJA
Thermal Resistance-Junction to Ambient
62.5
A
W
°C/W
Avalanche Ratings
EAS
Avalanche Energy, Single Pulsed
L=0.5mH
1155***
mJ
Note: * Repetitive rating ; pulse width limiited by junction temperature
** Drain current is limited by junction temperature
*** VD=100V
Electrical Characteristics
Symbol
Parameter
(TC = 25C Unless Otherwise Noted)
Test Conditions
HY3712
Min.
Typ.
Max.
VGS=0V, IDS=250A
125
VDS=125V, VGS=0V
1
10
Unit
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
VGS(th)
IGSS
RDS(ON)*
TJ=85°C
V
A
Gate Threshold Voltage
VDS=VGS, IDS=250A
2.0
3.0
4.0
V
Gate Leakage Current
VGS=±25V, VDS=0V
±100
nA
Drain-Source On-state Resistance
VGS=10V, IDS=85A
6.3
7.5
m
ISD=85A, VGS=0V
0.8
1
V
70
ns
110
nC
Diode Characteristics
VSD *
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
www.hymexa.com
ISD=85A, dlSD/dt=100A/s
2
V1.0
HY3712P/M/B/PS/PM
Electrical Characteristics (Cont.)
Symbol
Parameter
Test Conditions
HY3712
Min.
Typ.
Max.
3.0
8162
980
509
35
46
95
52
189
29
70
Unit
Dynamic Characteristics
RG
Gate Resistance
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
td(ON)
Turn-on Delay Time
Tr
Turn-on Rise Time
td(OFF)
Turn-off Delay Time
Tf
VGS=0V,VDS=0V,F=1MHz
VGS=0V,
VDS=25V,
Frequency=1.0MHz
VDD=62.5 V, RG= 6 ,
IDS =85A, VGS=10V,
Turn-off Fall Time
pF
ns
Gate Charge Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=100V, VGS=10V,
IDS=85A
nC
Note * : Pulse test ; pulse width 300s, duty cycle2%.
www.hymexa.com
3
V1.0
HY3712P/M/B/PS/PM
Typical Operating Characteristics
Drain Current
Power Dissipation
180
350
160
ID - Drain Current (A)
Ptot - Power (W)
300
250
200
150
100
50
limited by package
140
120
100
80
60
40
o
o
TC=25 C
80 100 120 140 160 180 200
TC=25 C,VG=10V
40 60 80 100 120 140 160 180 200
Tc - Case Temperature (°C)
1000
100us
Rd
s(o
n)
Lim
it
Safe Operation Area
100
1ms
10ms
10
DC
1
o
TC=25 C
0.1
1
10
100
500
VDS - Drain - Source Voltage (V)
Thermal Transient Impedance
Normalized Effective Transient
1
Duty = 0.5
0.1
0.2
0.1
0.05
0.01
0.02
0.01
0.001
Single
Mounted on minimum pad
o
RJA : 62.5 C/W
0.0001
0.0001
0.001
0.1
0.01
1
10
Square Wave Pulse Duration (sec)
www.hymexa.com
4
V1.0
HY3712P/M/B/PS/PM
Typical Operating Characteristics (Cont.)
Output Characteristics
Drain-Source On Resistance
240
VGS= 5.5,6,7,8,9,10V
9.0
RDS(ON) - On - Resistance (m)
210
180
5V
150
120
4.5V
90
4V
60
30
1.0
2.0
3.0
4.0
5.0
8.0
VGS =10V
7.0
6.0
5.0
4.0
6.0
80
1.6
Normalized Threshold Vlotage
14
12
10
8
6
5
6
7
8
9
VGS - Gate - Source Voltage (V)
www.hymexa.com
1.4
1.2
1.0
0.8
0.6
0.4
0.2
-50 -25
10
200
IDS =250A
IDS=85A
4
160
VDS - Drain-Source Voltage (V)
16
4
120
50
75 100 125 150 175
Tj - Junction Temperature (°C)
5
V1.0
HY3712P/M/B/PS/PM
Source-Drain Diode Forward
160
2.4
VGS = 10V
2.2
100
IDS = 85A
1.8
IS - Source Current (A)
Normalized On Resistance
2.0
1.6
1.4
1.2
1.0
0.8
o
Tj=175 C
10
o
Tj=25 C
1
0.6
0.4
o
0.2
-50 -25
RON@Tj=25 C: 6.3m
50
0.1
0.0
75 100 125 150 175
0.6
0.8
1.0
1.2
VSD - Source-Drain Voltage (V)
Capacitance
Gate Charge
1.4
10
Frequency=1MHz
10000
VDS= 100V
VGS - Gate-source Voltage (V)
9
9000
C - Capacitance (pF)
0.4
11000
Ciss
8000
7000
6000
5000
4000
3000
2000
Coss
1000
5
10
15
30
35
7
6
5
4
3
2
www.hymexa.com
8
1
Crss
IDS= 85A
50
75
100 125 150 175 200
QG - Gate Charge (nC)
6
V1.0
HY3712P/M/B/PS/PM
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
7
V1.0
HY3712P/M/B/PS/PM
Device Per Unit
Package Type
Unit
Quantity
TO-220FB-3L
Tube
50
Package Information
TO-220FB-3L
COMMON DIMENSIONS
SYMBOL
www.hymexa.com
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.25
1.30
1.45
A2
2.20
2.40
2.60
b
0.70
0.80
0.95
b2
1.17
1.27
1.47
c
0.40
0.50
0.65
D
15.10
15.60
16.10
D1
8.80
9.10
9.40
D2
5.50
E
9.70
10.00
10.30
E3
7.00
e
2.54 BSC
e1
5.08 BSC
H1
6.25
6.50
6.85
L
12.75
13.50
13.80
L1
3.10
3.40
ĭP
3.40
3.60
3.80
Q
2.60
2.80
3.00
8
V1.0
HY3712P/M/B/PS/PM
Device Per Unit
Package Type
Unit
Quantity
TO-220FB-3S
Tube
50
Package Information
TO-220FB-3S
COMMON DIMENSIONS
SYMBOL
www.hymexa.com
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.25
1.30
1.45
A2
2.20
2.40
2.60
b
0.70
0.80
0.95
b2
1.17
1.27
1.47
c
0.40
0.50
0.65
D
15.10
15.60
16.10
D1
8.10
9.10
9.40
D2
5.50
E
9.70
10.00
10.30
E3
7.00
e
2.54 BSC
e1
5.08 BSC
H1
6.25
6.50
6.85
L
6.80
7.00
7.20
L1
3.10
3.40
ĭP
3.40
3.60
3.80
Q
2.60
2.80
3.00
9
V1.0
HY3712P/M/B/PS/PM
Device Per Unit
Package Type
Unit
Quantity
TO-263-2L
Reel
50
Package Information
TO-263-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.22
1.27
1.42
A2
2.49
2.69
2.89
A3
0.25
b
0.7
0.81
0.96
b1
1.17
1.27
1.47
c
0.3
0.38
0.53
D1
8.5
8.7
8.9
D4
6.6
E
9.86
10.16
10.36
E5
7.06
e
2.54 BSC
H
14.7
15.1
15.5
H2
1.07
1.27
1.47
L
2
2.3
2.6
L1
1.4
1.55
1.7
L4
ș
www.hymexa.com
0.25 BSC
0°
10
5°
9°
V1.0
HY3712P/M/B/PS/PM
Device Per Unit
Package Type
Unit
Quantity
TO-3PS-3L
Tube
50
Package Information
TO-3PS-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
3.36
3.56
3.76
A1
1.25
1.30
1.40
A2
1.39
1.54
1.69
b
0.75
0.80
0.90
b2
1.17
1.27
1.42
c
0.45
0.50
0.60
D
15.45
15.70
15.95
D1
9.00
9.20
9.40
E
9.88
10.00
10.20
e
2.54
L
13.20
13.40
13.60
L1
3.00
3.30
ĭP1
Q
www.hymexa.com
BSC
3.20
3.88
11
REF
4.00
4.12
V1.0
HY3712P/M/B/PS/PM
Device Per Unit
Package Type
Unit
Quantity
TO-3PM-3S
Tube
50
Package Information
TO-3PM-3S
www.hymexa.com
12
V1.0
HY3712P/M/B/PS/PM
Classification Profile
Classification Reflow Profiles
Profile Feature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 qC
150 qC
60-120 seconds
150 qC
200 qC
60-120 seconds
3 qC/second max.
3qC/second max.
183 qC
60-150 seconds
217 qC
60-150 seconds
See Classification Temp in table 1
See Classification Temp in table 2
Time (tP)** within 5qC of the specified
classification temperature (Tc)
20** seconds
30** seconds
Average ramp-down rate (Tp to Tsmax)
6 qC/second max.
6 qC/second max.
6 minutes max.
8 minutes max.
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmax to TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak
(Tp)*
package
body
Temperature
Time 25qC to peak temperature
* Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
13
V1.0
HY3712P/M/B/PS/PM
Table 1. SnPb Eutectic Process – Classification Temperatures (Tc)
3
Package
Thickness
很抱歉,暂时无法提供与“HY3712P”相匹配的价格&库存,您可以联系我们找货
