VBFB16R04
VBFB16R04
    VBSEMI(微碧)
    TO-251-3
    类型:N沟道;漏源电压(Vdss):600V;连续漏极电流(Id):4A;功率(Pd):125W;导通电阻(RDS(on)@Vgs,Id):2.2Ω@10V,3.7A;阈值电压(Vgs(th)@Id)...
VBFB16R04 数据手册
VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com /$IBOOFM07 %4 Power MOSFET FEATURES PRODUCT SUMMARY • • • • • • • 600 VDS (V) RDS(on) () VGS = 10 V 2.2 Qg (Max.) (nC) 39 Qgs (nC) 10 Qgd (nC) 19 Configuration Single Ultra Low Gate Charge Reduced Gate Drive Requirement Enhanced 30 V, VGS Rating Reduced Ciss, Coss, Crss Extremely High Frequency Operation Repetitive Avalanche Rated Compliant to RoHS Directive 2002/95/EC Available RoHS* COMPLIANT TO-251 TO-220AB D TO-220 FULLPAK TO-252 G G D S G D S G VBM16R04 S S G D S Top View Top View Top View Top View D VBMB16R04 VBE16R04 N-Channel MOSFET VBFB16R04 ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL LIMIT Drain-Source Voltage VDS Gate-Source Voltage VGS 600 ± 30 4 2.9 25 1.0 530 6.2 13 125 3.0 - 55 to + 150 300d 10 1.1 Continuous Drain Current VGS at 10 V TC = 25 °C TC = 100 °C Currenta Pulsed Drain Linear Derating Factor Single Pulse Avalanche Energyb Repetitive Avalanche Currenta Repetitive Avalanche Energya Maximum Power Dissipation Peak Diode Recovery dV/dtc Operating Junction and Storage Temperature Range Soldering Recommendations (Peak Temperature) Mounting Torque ID IDM TC = 25 °C for 10 s 6-32 or M3 screw EAS IAR EAR PD dV/dt TJ, Tstg UNIT V A W/°C mJ A mJ W V/ns °C lbf · in N·m Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. VDD = 50 V, starting TJ = 25 °C, L = 25 mH, Rg = 25 , IAS = 6.2 A (see fig. 12). c. ISD  6.2 A, dI/dt  80 A/μs, VDD  VDS, TJ  150 °C. d. 1.6 mm from case. * Pb containing terminations are not RoHS compliant, exemptions may apply 服务热线:400-655-8788 1 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com THERMAL RESISTANCE RATINGS SYMBOL TYP. MAX. Maximum Junction-to-Ambient PARAMETER RthJA - 62 Case-to-Sink, Flat, Greased Surface RthCS 0.50 - Maximum Junction-to-Case (Drain) RthJC - 1.0 UNIT °C/W SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT VDS VGS = 0 V, ID = 250 μA 600 - - V VDS/TJ Reference to 25 °C, ID = 1 mA - 0.70 - V/°C VGS(th) VDS = VGS, ID = 250 μA 2.0 - 4.0 V Gate-Source Leakage IGSS VGS = 20 - - ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = 600 V, VGS = 0 V - - 100 VDS = 480 V, VGS = 0 V, TJ = 125 °C - - 500 Static Drain-Source Breakdown Voltage VDS Temperature Coefficient Gate-Source Threshold Voltage Drain-Source On-State Resistance Forward Transconductance RDS(on) gfs ID = 3.7 Ab VGS = 10 V VDS = 100 V, ID = 3.7 Ab μA - 2.2 -  3.7 - - S - 1100 - - 140 - - 15 - - - 39 - - 10 Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs VGS = 0 V VDS = 25 V f = 1.0 MHz, see fig. 5 VGS = 10 V ID = 4 A, V DS = 360 V, see fig. 6 and 13b pF nC Gate-Drain Charge Qgd - - 19 Turn-On Delay Time td(on) - 12 - - 20 - - 27 - - 17 - - 4.5 - - 7.5 - - - 4.0 S - - 25 = 0 Vb - - 1.5 V - 440 680 ns - 2.1 3.2 μC Rise Time Turn-Off Delay Time tr td(off) Fall Time tf Internal Drain Inductance LD Internal Source Inductance LS VDD = 300 V, ID = 4 A Rg = 9.1 , RD = 47, see fig. 10b Between lead, 6 mm (0.25") from package and center of die contact D ns nH G S Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulsed Diode Forward Currenta ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Forward Turn-On Time ton MOSFET symbol showing the integral reverse p - n junction diode TJ = 25 °C, IS = 4 A, V D A G GS TJ = 25 °C, IF = 4 A, dI/dt = 100 A/μs b Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD) Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width  300 μs; duty cycle  2 %. 服务热线:400-655-8788 2 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 100 VGS 15 V 10 V 8.0 V 7.0 V 6.0 V 5.5 V 5.0 V Bottom 4.5 V Top 101 4.5 V 10-1 ID, Drain Current (A) ID, Drain Current (A) 101 25 °C 100 20 µs Pulse Width TC = 25 °C 10-2 10-2 10-1 100 101 91114_01 4 4.5 V 10-1 10-2 10-2 91114_02 20 µs Pulse Width TC = 150 °C 10-1 100 101 3.5 3.0 Fig. 2 - Typical Output Characteristics, TC = 150 °C 7 8 9 10 ID = 4 A VGS = 10 V 2.5 2.0 1.5 1.0 0.5 0.0 - 60 - 40 - 20 0 102 VDS, Drain-to-Source Voltage (V) 6 Fig. 3 - Typical Transfer Characteristics RDS(on), Drain-to-Source On Resistance (Normalized) ID, Drain Current (A) 100 VGS 15 V 10 V 8.0 V 7.0 V 6.0 V 5.5 V 5.0 V Bottom 4.5 V Top 5 VGS, Gate-to-Source Voltage (V) 91114_03 Fig. 1 - Typical Output Characteristics, TC = 25 °C 101 20 µs Pulse Width VDS = 100 V 10-1 102 VDS, Drain-to-Source Voltage (V) 150 °C 91114_04 20 40 60 80 100 120 140 160 TJ, Junction Temperature (°C) Fig. 4 - Normalized On-Resistance vs. Temperature 服务热线:400-655-8788 3 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com 2400 Capacitance (pF) 2000 ISD, Reverse Drain Current (A) VGS = 0 V, f = 1 MHz Ciss = Cgs + Cgd, Cds Shorted Crss = Cgd Coss = Cds + Cgd 1600 Ciss 1200 Coss 800 Crss 400 101 25 °C 0 101 0.6 VDS, Drain-to-Source Voltage (V) 91114_05 103 2 VDS = 300 V VDS = 180 V 12 Operation in this area limited by RDS(on) 5 VDS = 240 V 8 102 5 10 µs 2 10 100 µs 5 2 1 ms 1 10 ms 5 2 0.1 4 TC = 25 °C TJ = 150 °C Single Pulse 5 For test circuit see figure 13 0 0 8 16 24 32 2 10-2 0.1 40 QG, Total Gate Charge (nC) Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage 1.4 1.2 Fig. 7 - Typical Source-Drain Diode Forward Voltage ID = 3.2 A 16 1.0 VSD, Source-to-Drain Voltage (V) ID, Drain Current (A) 20 0.8 91114_07 Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage VGS, Gate-to-Source Voltage (V) VGS = 0 V 100 100 91114_06 150 °C 91114_08 2 5 1 2 5 10 2 5 102 2 5 103 2 5 104 VDS, Drain-to-Source Voltage (V) Fig. 8 - Maximum Safe Operating Area 服务热线:400-655-8788 4 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com RD VDS VGS D.U.T. Rg + - VDD 5.0 10 V ID, Drain Current (A) 4.0 Pulse width ≤ 1 µs Duty factor ≤ 0.1 % 3.5 Fig. 10a - Switching Time Test Circuit 3.0 2.5 VDS 2.0 90 % 1.0 0.0 25 50 75 100 125 150 10 % VGS TC, Case Temperature (°C) 91114_09 td(on) Fig. 9 - Maximum Drain Current vs. Case Temperature td(off) tf tr Fig. 10b - Switching Time Waveforms Thermal Response (ZthJC) 10 1 0 − 0.5 PDM 0.2 0.1 0.1 t1 0.05 t2 0.02 0.01 Notes: 1. Duty Factor, D = t1/t2 2. Peak Tj = PDM x ZthJC + TC Single Pulse (Thermal Response) 10-2 10-5 91114_11 10-4 10-3 10-2 0.1 1 10 t1, Rectangular Pulse Duration (s) Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case 服务热线:400-655-8788 5 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com L Vary tp to obtain required IAS VDS VDS tp VDD D.U.T. Rg + - IAS V DD VDS 10 V 0.01 Ω tp IAS Fig. 12a - Unclamped Inductive Test Circuit Fig. 12b - Unclamped Inductive Waveforms EAS, Single Pulse Energy (mJ) 1200 ID 1.8 A 2.9 A Bottom 4 A Top 1000 800 600 400 200 0 VDD = 50 V 25 91114_12c 50 75 100 150 125 Starting TJ, Junction Temperature (°C) Fig. 12c - Maximum Avalanche Energy vs. Drain Current Current regulator Same type as D.U.T. 50 kΩ QG 10 V 12 V 0.2 µF 0.3 µF QGS QGD + D.U.T. VG - VDS VGS 3 mA Charge IG ID Current sampling resistors Fig. 13a - Basic Gate Charge Waveform Fig. 13b - Gate Charge Test Circuit 服务热线:400-655-8788 6 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com TO-220AB MILLIMETERS A E F D H(1) Q ØP 3 2 L(1) 1 M* L b(1) INCHES DIM. MIN. MAX. MIN. MAX. A 4.25 4.65 0.167 0.183 b 0.69 1.01 0.027 0.040 b(1) 1.20 1.73 0.047 0.068 c 0.36 0.61 0.014 0.024 D 14.85 15.49 0.585 0.610 E 10.04 10.51 0.395 0.414 e 2.41 2.67 0.095 0.105 e(1) 4.88 5.28 0.192 0.208 F 1.14 1.40 0.045 0.055 H(1) 6.09 6.48 0.240 0.255 J(1) 2.41 2.92 0.095 0.115 L 13.35 14.02 0.526 0.552 L(1) 3.32 3.82 0.131 0.150 ØP 3.54 3.94 0.139 0.155 Q 2.60 3.00 0.102 0.118 ECN: X12-0208-Rev. N, 08-Oct-12 DWG: 5471 Notes * M = 1.32 mm to 1.62 mm (dimension including protrusion) Heatsink hole for HVM C b e J(1) e(1) 服务热线:400-655-8788 7 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com TO-220 FULLPAK (HIGH VOLTAGE) A E A1 ØP n d1 d3 D u L1 V L b3 A2 b2 c b e MILLIMETERS DIM. A A1 A2 b b2 b3 c D d1 d3 E e L L1 n ØP u v ECN: X09-0126-Rev. B, 26-Oct-09 DWG: 5972 MIN. 4.570 2.570 2.510 0.622 1.229 1.229 0.440 8.650 15.88 12.300 10.360 INCHES MAX. 4.830 2.830 2.850 0.890 1.400 1.400 0.629 9.800 16.120 12.920 10.630 MIN. 0.180 0.101 0.099 0.024 0.048 0.048 0.017 0.341 0.622 0.484 0.408 13.730 3.500 6.150 3.450 2.500 0.500 0.520 0.122 0.238 0.120 0.094 0.016 2.54 BSC 13.200 3.100 6.050 3.050 2.400 0.400 MAX. 0.190 0.111 0.112 0.035 0.055 0.055 0.025 0.386 0.635 0.509 0.419 0.100 BSC 0.541 0.138 0.242 0.136 0.098 0.020 Notes 1. To be used only for process drawing. 2. These dimensions apply to all TO-220, FULLPAK leadframe versions 3 leads. 3. All critical dimensions should C meet Cpk > 1.33. 4. All dimensions include burrs and plating thickness. 5. No chipping or package damage. 服务热线:400-655-8788 8 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com TO-252AA CASE OUTLINE E MILLIMETERS A C2 e b2 D1 e1 E1 L gage plane height (0.5 mm) L4 b L5 H D L3 b3 C A1 INCHES DIM. MIN. MAX. MIN. MAX. A 2.18 2.38 0.086 0.094 A1 - 0.127 - 0.005 b 0.64 0.88 0.025 0.035 b2 0.76 1.14 0.030 0.045 b3 4.95 5.46 0.195 0.215 C 0.46 0.61 0.018 0.024 C2 0.46 0.89 0.018 0.035 D 5.97 6.22 0.235 0.245 D1 5.21 - 0.205 0.265 E 6.35 6.73 0.250 E1 4.32 - 0.170 - H 9.40 10.41 0.370 0.410 e 2.28 BSC 0.090 BSC e1 4.56 BSC 0.180 BSC L 1.40 1.78 0.055 0.070 L3 0.89 1.27 0.035 0.050 L4 - 1.02 - 0.040 L5 1.14 1.52 0.045 0.060 ECN: X12-0247-Rev. M, 24-Dec-12 DWG: 5347 Note • Dimension L3 is for reference only. 服务热线:400-655-8788 9 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com TOĆ251AA (DPAK) E A L2 b2 Dim A A1 b b1 b2 c c1 D E e L L1 L2 L3 D L3 L1 b1 L b MILLIMETERS c1 e c A1 INCHES Min Max Min Max 2.21 2.38 0.087 0.094 0.89 1.14 0.035 0.045 0.71 0.89 0.028 0.035 0.76 1.14 0.030 0.045 5.23 5.43 0.206 0.214 0.46 0.58 0.018 0.023 0.46 0.58 0.018 0.023 5.97 6.22 0.235 0.245 6.48 6.73 0.255 0.265 2.28 BSC 0.090 BSC 8.89 9.53 0.350 0.375 1.91 2.28 0.075 0.090 0.89 1.27 0.035 0.050 1.15 1.52 0.045 0.060 ECN: S-03946—Rev. E, 09-Jul-01 DWG: 5346 Note: Dimension L3 is for reference only. 服务热线:400-655-8788 10 VBM16R04 / VBMB16R04 VBE16R04 / VBFB16R04 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBFB16R04 价格&库存
很抱歉,暂时无法提供与“VBFB16R04”相匹配的价格&库存,您可以联系我们找货
VBFB16R04
  • 100+1.60912
  • 500+1.57053
  • 3000+1.52650
