GR8853A
Self-oscillating Half-bridge Driver
Features
Floating
Description
channel
designed
for
GR8853A
bootstrap
is
a
high
voltage,
high
speed,
self-oscillating power MOSFET and IGBT driver
operation to +600V
with both high and low side referenced output
Noise immunity of transient voltage
Under-voltage lockout
Programmable oscillator frequency
Matched propagation delay for both channels
Ultra low startup current of 75uA
Shutdown function turns off both channels
Low side output in phase with RT
channels. Proprietary HVIC and latch immune
CMOS technologies enable ruggedized monolithic
construction.
The
front
end
features
a
programmable oscillator which is similar to the 555
timer. The output drivers feature a high pulse
current buffer stage and an internal dead time
designed for minimum driver cross-conduction.
Propagation delays for the two channels are
Applications
matched to simplify use in 50% duty cycle
HID lamp ballast
PDP sustain driver
Motor driver
SMPS
applications. The floating channel can be used to
drive an N-MOSFET or IGBT in the high side
configuration that operates off a high voltage rail
up to 600 volts.
Ordering and Marking Information
GR8853A
Package Code
RoHS Code
G: Green (Halogen Free) Device
L: PB Free Device
J: DIP-8
K: SOP-8
DIP-8/SOP-8
GR8853A
X X XXX
Serial No.
Code 1
Code 2
Code 1
Year
8
9
A
B
2008 2009 2010 2011
Code 2 1
Month Jan.
2
Feb.
3
Mar.
4
Apr.
G
H
I
J
2016
2017
2018
2019
9
Sep.
A
Oct.
B
Nov.
C
Dec.
Grenergy OPTO Inc. reserves the right to make changes to improve reliability or manufacture ability without
notice, and advise customers to obtain the latest version of relevant information to verify before placing
orders.
2011.03.ver. 1.0.Copyright Grenergy OPTO, Inc. www.grenergy-ic.com
1
GR8853A
Pin Configuration
TOP VIEW
VCC
1
8
VB
RT
2
7
HO
CT
3
6
VS
COM
4
5
LO
Pin Description
Pin No.
Name
Function
1
VCC
2
RT
3
CT
4
COM
5
LO
Low side gate drive output
6
VS
High side floating supply return
7
HO
High side gate drive output
8
VB
Low side and logic fixed supply
Oscillator timing resistor input, in phase with HO for normal IC operation
Oscillator timing capacitor input, the oscillator frequency according to the following
equation: f = 0.7213 / (RT x CT)
Low side return
Block Diagram
2
GR8853A
Absolute Maximum Ratings
Supply voltage VCC ------------------------------------------------------------------------------------------------------------ 19V
VB ------------------------------------------------------------------------------------------------------------------VS --------------------------------------------------------------------------------------------------------------
VB-25V ~ VB+0.3V
HO -------------------------------------------------------------------------------------------------------------
VS-0.3V ~ VB+0.3V
LO, RT, CT
-0.3V ~ VCC+0.3V
Junction temperature
Operating ambient temperature
Storage temperature range
150℃
-20℃ ~
85℃
-65℃ ~ 150℃
SOP-8 package thermal resistance
160℃/W
DIP-8 package thermal resistance
100℃/W
Power dissipation (SOP-8, at ambient temperature = 85℃)
Power dissipation (DIP-8, at ambient temperature = 85℃)
6
-0.3V ~ 625V
5
m
Lead temperature (All Pb free packages, soldering, 10sec)
ESD voltage protection, human body model
ESD voltage protection, machine model
400mW
W
260℃
3KV
200V
Recommended Operating Conditions
Item
Min.
Max.
Unit
Supply voltage VCC
10
18
V
Supply voltage VBS
VCC-0.7
18
V
3
GR8853A
Electrical Characteristics
VBIAS (VCC, VBS) = 12V, CL = 1000 pF, CT = 1 nF and TA = 25°C unless otherwise specified. The VIN, VTH and IIN
parameters are referenced to COM. The VO and IO parameters are referenced to COM and are applicable to the
respective output leads: HO or LO.
Parameter
Conditions
Symbol
Min.
Typ.
Max.
Unit
Rising VCC under-voltage lockout threshold
VCCUV+
8.1
9.0
9.9
V
Falling VCC under-voltage lockout threshold
VCCUV-
7.2
8.0
8.8
V
VCC under-voltage lockout Hysteresis
VCCUVH
0.5
1.0
1.5
V
IQCCUV
50
100
µA
Quiescent VCC supply current
IQCC
160
300
µA
VCC operating voltage
Vop
10
12
18
V
IQBSUV
µA
IQBS
30
50
µA
VB=VS=600V
ILK
50
µA
Oscillator frequency (CT=1008pF)
RT = 14.71k
fosc
47.2
48.2
49.2
kHz
RT pin duty cycle
fosc
很抱歉,暂时无法提供与“GR8853AJG”相匹配的价格&库存,您可以联系我们找货
