Preliminary Datasheet
LP4068
800mA Single Chip Li-Ion and Li-Polymer Charger
General Description
Features
The LP4068 is a complete constant-current/ constant
Input Voltage up to 28V
voltage linear charger for single cell lithium-ion battery.
Input Over Voltage Protection:6.5V
Its SOT23-5 package and low external component
Short-circuit protection
count make the LP4068 ideally suited for portable
Programmable Charge Current up to 800mA
applications. No external sense resistor is needed,
1µA Battery Reverse Current
and no blocking diode is required due to the internal
Protection of Reverse Connection of Battery
MOSFET architecture. Thermal feedback regulates
No MOSFET, Sense Resistor or Blocking Diode
the charge current to limit the die temperature during
high power operation or high ambient temperature.
Required
Constant-Current/Constant-Voltage Operation
The charge voltage is fixed at 4.2V, and the charge
with Thermal Regulation to Maximize Charge
current can be ISET programmed externally with a
Rate Without Risk of Overheating
single resistor.
SOT23-5 Package
The LP4068 automatically terminates the charge cycle
RoHS Compliant and 100% Lead (Pb)-Free
when the charge current drops to 1/10 setting current
value after the final float voltage is reached.
Applications
When the input supply is removed, the LP4068
Portable Media Players/Game
automatically enters a low current state, dropping the
Power Bank
battery drain current to less than 1µA.
Bluetooth Applications
PDA/MID
Other features include charge current monitor, under
voltage lockout, automatic recharge and a status pin.
Marking Information
Device
Order Information
LP4068
LP4068B5F
Marking
LP4068
YWX
Package
Shipping
SOT23-5
3K/REEL
Marking indication:
F: Pb-Free
Y:Production year W:Production week X: Series Number
Package Type
B5: SOT23-5
LP4068-00
Jan.-2019
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 7
LP4068
Functional Pin Description
Pin Configurations
Package Type
LP4068B6F
SOT23-5
CHRG
1
GND
2
BAT
3
5
ISET
4
VIN
SOT23-5
TOP VIEW
Pin Description
No.
NAME
DESCRIPTION
Open-Drain Charge Status Output. When the battery is charging, the CHRG pin is
1
CHRG
pulled low by an internal NMOS. When the charge cycle is completed, the pin could
be pulled High by an external pull high resistor.
2
GND
GND is the connection to system ground.
BAT is the connection to the battery. Typically a 10µF Tantalum capacitor is needed
3
BAT
for stability when there is no battery attached. When a battery is attached, only a 1uF
ceramic capacitor is required.
4
VIN
VIN is the input power source. Connect to a wall adapter.
Charge Current Program. The charge current is programmed by connecting a 1%
5
LP4068-00
ISET
Jan.-2019
resistor(RISET) to ground.
Page 2 of 7
LP4068
Typical Application Circuit
LP4068
VIN
4
VIN
BAT
Battery
3
CIN
10uF
1K
5
ISET
CHRG
1
LED1
RISET
3.4K
GND
COV
10uF
2
Function Block Diagram
BAT
VIN
R1
CHRG
Control
Logic
R2
GND
ISET
LP4068-00
Jan.-2019
Page 3 of 7
LP4068
Absolute Maximum Ratings Note 1
Input Voltage to GND ---------------------------------------------------------------------------------------- -0.3V to 28V
BAT Voltage GND ---------------------------------------------------------------------------------------------- - 5V to 15V
Other pin to GND -------------------------------------------------------------------------------------------- -0.3V to 6.5V
Maximum Junction Temperature ---------------------------------------------------------------------------------- 125℃
Maximum Soldering Temperature (at leads, 10 sec) --------------------------------------------------------- 260℃
Operating Junction Temperature Range (TJ) -------------------------------------------------------- -20℃ to 85℃
Storage Temperature ------------------------------------------------------------------------------------ -65℃ to 165℃
Thermal Information
Maximum Power Dissipation ( PD,TA=25°C) --------------------------------------------------------------------- 0.6W
Thermal Resistance (θJA) ---------------------------------------------------------------------------------------- 200℃/W
ESD Susceptibility
HBM(Human Body Mode) --------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) ---------------------------------------------------------------------------------------------------- 200V
Note 1.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the
specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
LP4068-00
Jan.-2019
Page 4 of 7
LP4068
Electrical Characteristics
(TA=25°C, VIN =5V, unless otherwise noted.)
SYMBOL
PARAMETER
VIN
Input Voltage
IIN
Input Supply Current
IBAT=4.2V
VFLOAT
Regulated Output (Float) Voltage
IBAT=40mA,
VUV
VIN Under Voltage Lockout Threshold
From VIN Low to High
3.5
V
VOVP
Input Voltage OVP
VIN Rising
6.5
V
VOVP_HYS
OVP Hysteresis
150
mV
RISET=3.4k, Current Mode
500
mA
RISET=17k, Current Mode
100
mA
VBAT=4.2V( VIN=float or 0V)
1
uA
IBAT
CONDITIONS
BAT Pin Current
MIN
TYP.
MAX
UNITS
4.5
5
6
V
80
4.158
4.2
uA
4.242
V
ITRIKL
Trickle Charge Current
VBATVBAT+VDT), but is less
supplied to the battery. When the BAT pin approaches the
than OVP (VIN
很抱歉,暂时无法提供与“LP4068B5F”相匹配的价格&库存,您可以联系我们找货
