Preliminary Datasheet
LP4063
800mA Single Chip Li-Ion and Li-Polymer Charger
General Description
Features
The LP4063 is a complete constant-current/ constant
voltage linear charger for single cell lithium-ion battery.
Its SOT23-5 package and low external component
count make the LP4063 ideally suited for portable
applications. No external sense resistor is needed,
and no blocking diode is required due to the internal
MOSFET architecture. Thermal feedback regulates
the charge current to limit the die temperature during
high power operation or high ambient temperature.
The charge voltage is fixed at 4.2V, and the charge
current can be ISET programmed externally with a
single resistor.
The LP4063 automatically terminates the charge cycle
when the charge current drops to 1/10 setting current
value after the final float voltage is reached.
When the input supply is removed, the LP4063
automatically enters a low current state, dropping the
battery drain current to less than < 1µA.
Other features include charge current monitor, under
voltage lockout, automatic recharge and a status pin .
Input Voltage up to 28V
Input Over Voltage Protection:7V
Short-circuit protection
Programmable Charge Current:300mA to 800mA
< 1µA Battery Reverse Current
Protection of Reverse Connection of Battery
No MOSFET, Sense Resistor or Blocking Diode
Required
Constant-Current/Constant-Voltage Operation
with Thermal Regulation to Maximize Charge
Rate Without Risk of Overheating
SOT23-5 Package
RoHS Compliant and 100% Lead (Pb)-Free
Typical Application Circuit
LP4063
VIN
4
VIN
BAT
CIN
1uF
Order Information
10nF
ISET
CHRG
GND
Package Type
B5: SOT23-5
Portable Media Players/Game
Power Bank
Bluetooth Applications
PDA/MID
LP4063-01
Oct.-2018
LED1
2
Marking Information
Device
Applications
1
RISET
2K
F: Pb-Free
Charge Voltage
Default: 4.2V
COV
1uF
1K
5
LP4063
Battery
3
LP4063B5F
Marking
LP4063
BHYWX
Package
SOT23-5
Shipping
3K/REEL
Marking indication:
Y:Production year W:Production week X: Series Number
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 6
LP4063
Functional Pin Description
Package Type
Pin Configurations
SOT23-5
CHRG
1
GND
2
BAT
3
5
ISET
4
VIN
SOT23-5
TOP VIEW
Pin Description
No.
NAME
DESCRIPTION
Open-Drain Charge Status Output. When the battery is charging, the CHRG pin is pulled low
1
CHRG
by an internal NMOS. When the charge cycle is completed, the pin could be pulled High by an
external pull high resistor.
2
GND
GND is the connection to system ground.
BAT is the connection to the battery. Typically a 10µF Tantalum capacitor is needed for
3
BAT
stability when there is no battery attached. When a battery is attached, only a 1uF ceramic
capacitor is required.
4
VIN
VIN is the input power source. Connect to a wall adapter.
Charge Current Program. The charge current is programmed by connecting a 1%
5
LP4063-01
ISET
resistor(RISET) to ground.
Oct.-2018
Page 2 of 6
LP4063
Function Block Diagram
BAT
VIN
R1
CHRG
Control
Logic
R2
GND
ISET
Absolute Maximum Ratings Note 1
Input Voltage to GND ---------------------------------------------------------------------------------------- -0.3V to 28V
BAT Voltage GND ----------------------------------------------------------------------------------------------- - 5V to 7V
Other pin to GND -------------------------------------------------------------------------------------------- -0.3V to 6.5V
Maximum Junction Temperature ---------------------------------------------------------------------------------- 125℃
Maximum Soldering Temperature (at leads, 10 sec) --------------------------------------------------------- 260℃
Operating Junction Temperature Range (TJ) -------------------------------------------------------- -40℃ to 85℃
Storage Temperature ------------------------------------------------------------------------------------ -65℃ to 165℃
Thermal Information
Maximum Power Dissipation ( PD,TA=25°C) --------------------------------------------------------------------- 0.6W
Thermal Resistance (θJA) ---------------------------------------------------------------------------------------- 200℃/W
ESD Susceptibility
HBM(Human Body Mode) --------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) ---------------------------------------------------------------------------------------------------- 200V
Note 1.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not
implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
LP4063-01
Oct.-2018
Page 3 of 6
LP4063
Electrical Characteristics
(TA=25°C, VIN =5V, unless otherwise noted.)
SYMBOL
PARAMETER
CONDITIONS
MIN
TYP.
MAX
UNITS
4.4
5
6.5
V
VIN
Input Voltage
IIN
Input Supply Current
IBAT=0
VFLOAT
Regulated Output (Float) Voltage
IBAT=40mA,
4.158
4.2
4.242
V
VUV
VIN Under Voltage Lockout Threshold
From VIN Low to High
3.1
3.3
3.5
V
VUV_HYS
VIN Under Voltage Lockout Hysteresis
VOVP
Input Voltage OVP
VOVP_HYS
OVP Hysteresis
IBAT
BAT Pin Current
ITRIKL
Trickle Charge Current
VTRIKL
Trickle Charge Threshold Voltage
VTRHYS
1000
uA
150
mV
7
V
150
mV
RISET=2k, Current Mode
500
mA
RISET=3.3k, Current Mode
300
mA
VIN Rising
VBAT=4.2V
1
VIN=float or 0V
±1
1
VBAT
很抱歉,暂时无法提供与“LP4063B5F”相匹配的价格&库存,您可以联系我们找货
