Preliminary Datasheet
LP3984
300mA,Ultra-low noise, Small Package
Ultra-Fast CMOS LDO Regulator
General Description
Features
The LP3984 is designed for portable RF and wireless
Ultra-Low-Noise for RF Application
applications with demanding performance and space
2.5V- 5.5V Input Voltage Range
requirements. The LP3984 performance is optimized
Low Dropout : 300mV @ 300mA
for battery-powered systems to deliver ultra low noise
300mA Output Current
and low quiescent current. The LP3984 also works
High PSSR:-68dB at 1KHz
with low-ESR ceramic capacitors, reducing the amount
1uA Standby Current When Shutdown
of board space necessary for power applications,
Available in SOT23-5 Package
critical in hand-held wireless devices. The LP3984
TTL-Logic-Controlled Shutdown Input
consumes less than 1µA in shutdown mode. The other
Ultra-Fast Response in Line/Load transient
features include ultra low dropout voltage, high output
Current Limiting and Thermal Shutdown
accuracy, current limiting protection, and high ripple
rejection ratio.
It is available in the 5-lead of SOT23-5
packages.
Applications
Order Information
LP3984
F: Pb-Free
Package Type
B5: SOT23-5
Output Type
12 : 1.2V
15 : 1.5V
18
25
28
30
33
36
LP3984-04
Protection
1.8V
2.5V
2.8V
3.0V
3.3V
3.6V
May.-2018
Portable Media Players/MP3 players
Cellular and Smart mobile phone
LCD
DSC Sensor
Wireless Card
Typical Application Circuit
VIN
VIN
CIN
1μF
CHIP ENABLE
Email: marketing@lowpowersemi.com
VOUT
VOUT
COUT
1μF
GND
EN
NC
www.lowpowersemi.com
Page 1 of 6
LP3984
Marking Information
Device
Marking
Package
Shipping
Device
Marking
Package
Shipping
LP3984-12B5F
LPS
SOT23-5
3K/REEL
LP3984-30B5F
LPS
SOT23-5
3K/REEL
SOT23-5
3K/REEL
SOT23-5
3K/REEL
4BYWX
LP3984-15B5F
LPS
4GYWX
SOT23-5
3K/REEL
LP3984-33B5F
LPS
4NYWX
LP3984-18B5F
LPS
4EYWX
SOT23-5
3K/REEL
LP3984-36B5F
LPS
4CYWX
LP3984-25B5F
LPS
4LYWX
SOT23-5
3K/REEL
Marking indication:
4DYWX
LP3984-28B5F
LPS
Y: Y is year code. W: W is week code. X: X is series number.
SOT23-5
3K/REEL
4HYWX
Functional Pin Description
Package Type
Pin Configurations
Top View
SOT23-5
SOT-23-5
VIN
1
GND
2
EN
3
5
VOUT
4
NC
Pin Description
Pin
Name
Description
1
VIN
Power Input Voltage.
2
GND
Ground.
3
EN
Chip Enable (Active High).
4
NC
No Connection.
5
VOUT
Output Voltage.
LP3984-04
May.-2018
Page 2 of 6
LP3984
Function Diagram
Absolute Maximum Ratings
Supply Input Voltage ------------------------------------------------------------------------------------------------------ 6.5V
Other Pin Voltage ---------------------------------------------------------------------------------------- -0.3V to VIN+0.3V
Power Dissipation, PD @ TA = 25℃
SOT23-5 ----------------------------------------------------------------------------------------------------------------- 500mW
Package Thermal Resistance
Thermal Resistance (SOT23-5) (JA) ---------------------------------------------------------------------------- 195℃/W
Thermal Resistance (SOT23-5) (JC) ------------------------------------------------------------------------------ 60℃/W
Maximum Junction Temperature ------------------------------------------------------------------------------------ 150℃
Maximum Soldering Temperature (at leads, 10 sec) ---------------------------------------------------------- 260℃
Storage Temperature Range ---------------------------------------------------------------------------- −65℃ to 150℃
ESD Susceptibility
HBM (Human Body Mode) ------------------------------------------------------------------------------------------------ 2kV
MM (Machine-Mode) ----------------------------------------------------------------------------------------------------- 200V
Recommended Operating Conditions
Supply Input Voltage ------------------------------------------------------------------------------------------- 2.5V to 5.5V
EN Input Voltage --------------------------------------------------------------------------------------------- 0V toVIN+0.3V
Operation Junction Temperature Range ------------------------------------------------------------- −40℃ to 125℃
Operation Ambient Temperature Range --------------------------------------------------------------- −40℃ to 85℃
LP3984-04
May.-2018
Page 3 of 6
LP3984
Electrical Characteristics
(VIN = VOUT + 1V, CIN = COUT = 1µF, TA = 25° C, unless otherwise specified)
Parameter
Symbol
Test Conditions
Min
Typ.
Max
Units
Output Voltage Accuracy
ΔVOUT
IOUT=1mA
−2
+2
Output Loading Current
ILOAD
VEN=VIN,VIN>2.8V
300
Current Limit
ILIM
RLOAD=1Ω
500
Quiescent Current
IQ
VEN≥1.2V, IOUT=0mA
50
130
Dropout Voltage
VDROP
IOUT=200mA, VOUT>2.8V
200
240
IOUT=300mA, VOUT>2.8V
300
360
Line Regulation
ΔVLINE
Load Regulation
ΔLOAD
1mA 25mΩ on the
PD = (VIN−VOUT) x IOUT + VIN x IQ
The maximum power dissipation depends on the
thermal resistance of IC package, PCB layout, the rate
of surroundings airflow and temperature difference
between junction to ambient.
The maximum power dissipation can be calculated by
following formula:
LP3984 output ensures stability. The LP3984 still
works well with output capacitor of other types due to
the wide stable ESR range. Output capacitor of larger
capacitance can reduce noise and improve load
transient response, stability, and PSRR. The output
capacitor should be located not more than 0.5 inch
from the VOUT pin of the LP3984 and returned to a
clean analog ground.
PD(MAX) = ( TJ(MAX) − TA ) / θJA
Where TJ(MAX) is the maximum operation junction
temperature 125℃, TA is the ambient temperature
and the θJA is the junction to ambient thermal
resistance. For recommended operating conditions
specification of LP3984, where TJ(MAX) is the maximum
junction temperature of the die (125℃) and TA is the
maximum ambient temperature. The junction to
Start-up Function Enable Function
ambient thermal resistance (θJA is layout dependent)
The LP3984 features an LDO regulator enable/disable
for SOT23-5 package is 195℃/W.
function. To assure the LDO regulator will switch on,
the EN turn on control level must be greater than 1.4
volts. The LDO regulator will go into the shutdown
mode when the voltage on the EN pin falls below 0.4
volts. For to protecting the system, the LP3984 have a
PD(MAX) = ( 125℃ − 25℃ ) / 195 = 500mW
The
maximum
power
dissipation
depends
on
operating ambient temperature for fixed T J(MAX) and
thermal resistance θJA.
quick-discharge function. If the enable function is not
needed in a specific application, it may be tied to VIN
to keep the LDO regulator in a continuously on state.
LP3984-04
May.-2018
Page 5 of 6
LP3984
Packaging Information
SOT23-5
LP3984-04
May.-2018
Page 6 of 6
很抱歉,暂时无法提供与“LP3984-28B5F”相匹配的价格&库存,您可以联系我们找货
