LTP3559
P-1
General Description
The LTP3559 is a high voltage, low power consumption and high performance LDO. The family uses
an advanced CMOS process and a P-MOSFET pass device to achieve fast start-up, with high output
voltage accuracy. The LTP3559 is stable with a 1.0μF~10μF ceramic output capacitor, and uses a
precision voltage reference and feedback loop to achieve a worst-case accuracy of 2% over all
load, line, process, and temperature variations.
Features
Wide Input Voltage Range : up to 45V
Output Current : 350mA
Standard Fixed Output Voltage Options : 1.8V, 2.5V, 3.0V, 3.3V, 3.6V, and 5.0V
More Output Voltage Options Available on Request
Low IQ : 2.5μA Typically
Low Dropout Voltage
Short current protection:150mA
Excellent Load and Line Transient Response
Line Regulation : 0.01%/V Typically
Normal Version Available in SOT23-3L, SOT23-5L and SOT89 Packages
Shutdown Version Available in SOT23-5L and Tiny DFN1×1-4L Packages
Order Information
Model
LTP3559
Package
Ordering Number Note1
Packing Option
SOT23-3L
LTP3559-xxXT3
Tape and Reel, 3000
SOT23-5L
LTP3559-xxNXT5
Tape and Reel, 3000
SOT23-5L
LTP3559-xxXT5
Tape and Reel, 3000
SOT89-3
LTP3559-xxXT4
Tape and Reel, 1000
SOT89-3R
LTP3559-xxRXT4
Tape and Reel, 1000
DFN1×1-4L
LTP3559-xxNXF4
Tape and Reel, 10000
Note1: xx stands for output voltage, e.g. if xx = 18, the output voltage is 1.8V; if xx = 30, the output voltage is 3.0V.
The device with suffix "N" is shutdown version with enable control input.
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
Linearin and designs are registered trademarks of Linearin Technology Corporation.
© Copyright Linearin Technology Corporation. All Rights Reserved.
All other trademarks mentioned are the property of their respective owners.
FN1620-28.2 — Data Sheet
350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs
LTP3559
P-2
Pin Description
Normal Version Without Enable (Top View)
3 IN
1
2
GND
OUT
IN
1
GND
2
NC
3
SOT23-3L
5
OUT
4
NC
1
GND
2
IN
1
OUT
3
OUT
SOT89-3
SOT23-5L
2
GND
3
IN
SOT89-3R
Shuntdown Version With Enable (Top View)
IN
1
GND
2
EN
3
4
5
OUT
4
NC
1
IN
EN
OUT
GND
SOT23-5L
3
2
DFN1×1-4L
Pin Function
Pin No.
SOT23-3L SOT23-5L
SOT89-3 SOT89-3R SOT23-5L DFN1×1-4L
LTP3559- LTP3559xxXT3
xxXT5
LTP3559 LTP3559-xxXT4 xxRXT4
LTP3559xxNXT5
LTP3559xxNXF4
1
2
1
2
2
2
1
2
3
3
5
3
1
3,4
Pin Name
Pin Function
2
GND
Ground.
1
4
IN
Supply input pin.
5
1
OUT
Output pin.
3
3
EN
Enable control input,
active high.
NC
No connection.
4
LTP3559
P-3
Block Diagram
OUT
IN
Short
Current protection
Voltage
Reference
GND
Functional Description
Input Capacitor
A 1μF-10μF ceramic capacitor is recommended to connect between VIN and GND pins to decouple input power
supply glitch and noise. The amount of the capacitance may be increased without limit. This input capacitor
must be located as close as possible to the device to assure input stability and less noise. For PCB layout, a
wide copper trace is required for both VIN and GND.
P-4
LTP3559
Output Capacitor
An output capacitor is required for the stability of the LDO. The recommended output capacitance is from
1μF to 10μF, Equivalent Series Resistance (ESR) is from 5mΩ to 100mΩ, and temperature characteristics
are X7R or X5R. Higher capacitance values help to improve load/line transient response. The output
capacitance may be increased to keep low undershoot/overshoot. Place output capacitor as close as
possible to OUT and GND pins.
Low Quiescent Current
The LTP3559, consuming only around 2.5μA for all input range and output loading, provides great power
saving in portable and low power applications.
Short Current Limit Protection
When output current at the OUT pin is higher than current limit threshold or the OUT pin is short-circuit to
GND, the short current limit protection will be triggered and clamp the output current to approximately
100mA to prevent over-current and to protect the regulator from damage due to overheating.
Absolute Maximum Ratings
Parameter
Rating
IN pin to GND pin
–0.3 to 48
V
OUT pin to GND pin
–0.3 to 6
V
Thermal Resistance (Junction to Ambient)
Unit
SOT-89
135
SOT23-5L
250
SOT23-3L
360
DFN1×1-4L
250
℃/W
Operating Junction Temperature
–40 to 125
Storage Temperature
–65 to 150
Lead Temperature (Soldering, 10 sec)
300
ESD (HBM mode)
ESDA/JEDEC
JS-001-2017
±2000V
Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits
are exceeded, device functionality should not be assumed, damage may occur and reliability may be
affected.
04
LTP3559
P-5
Electrical Characteristics
(VIN = VOUT + 2V; IOUT = 10mA, CIN = COUT = 1.0μF, unless otherwise noted. Typical values are at T A = +25°C.)
Symbol
Parameter
Test Conditions
Min
Typ
VIN
Operating Input
Voltage
LineREG
Line Regulation
VDROP
Dropout Voltage
LoadREG
Load Regulation
1mA ≤ IOUT ≤ 300mA,
VIN =VOUT+2V
IOUT
Maximum Output Current
VIN = VOUT +1V
IQ
Quiescent Current
IOUT = 0mA
2.5
4
μA
IQ_OFF
Standby Current
VEN = 0V, TA = 25°C
0.1
1
μA
VENH
EN Pin Threshold Voltage
EN Input Voltage “H”
VENL
EN Input Voltage “L”
IEN
EN Pin Current
VEN=0-36V
PSRR
Power Supply Rejection Ratio
VIN = VOUT+1V
IOUT = 20mA
eN
2.5V ≤ VIN ≤36V,
IOUT = 10mA
0.01
VOUT= 3.0V, IOUT = 100mA
330
VOUT= 3.0V, IOUT = 200mA
690
Max
Unit
45
V
0.04
%/V
mV
40
350
mV
mA
1.2
V
0.4
V
1
μA
f = 1 kHz
60
dB
Output Noise Voltage
VIN = VOUT+2V, IOUT = 1mA,
f = 10Hz to 100KHz,
(VOUT =3V) COUT = 1μF
100
μVrms
TSD
Thermal Shutdown
Temperature
Temperature Increasing
from TA=+25°C
155
TSDH
Thermal Shutdown
Hysteresis
Temperature Falling
From TSD
P-6
LTP3559
TYPICAL PERFORMANCE CHARACTERISTICS
Fig1. Line-Transient Response
Fig2. Load-Transient Response
Fig3. Start up Response
06
LTP3559
P-7
IQ vs. Temperature
VDROP VS. IOUT
3.5
1000
IQ (μA)
Dropout Voltage(mV)
3.2
100
2.9
2.6
10
2.3
2
1
100
150
200
250
300
-40 -20
350
60
80 100 120
Temperature(℃)
Output Current (mA)
Fig5. IQ VS Temperature
Fig4. Dropout Voltage VS Output Current
Application Circuits
VIN
VDD
OUT
VOUT
CIN
COUT
1µF
1µF
Enable
OFF
ON
EN
GND
LTP3559
P-8
Package Dimension
SOT-89
4.4~4.6
1.4~1.6
2.3~2.6
3.94~4.25
1.55
0.9~1.2
0.35~0.44
0.32~0.52
1.50
3.00
Unit:mm
SOT23-5L
2.82~3.02
0.3~0.6
0.7
1.5~1.7
2.65~3.05
0.35~0.5
0.95
0.08~0.2
1.05~1.25
0.03~0.15
1.8~2.0
Unit:mm
08
LTP3559
P-9
SOT23-3L
2.82~3.02
0.3~0.6
0.7
1.5~1.7
2.6~3.0
0.3~0.4
0.95
0.1~0.2
1.05~1.25
0.1max
1.8~2.0
Unit:mm
DFN1×1-4
0.65BSC
0.15~0.35
0.95~1.05
0.5Max
0.95~1.05
Detail A
0.125REF
0.00~0.05
Unit:mm
Detail A:PIN1 shape)
