SUL6001S5-ADJ
SUL6001S5-ADJ
    SUNTEK(洺太电子)
    SOT23-5
    LDO Low Noise High PSRR 1 Ch 1A Ultra Low Dropout LDO
SUL6001S5-ADJ 数据手册
SUL6001 Low Noise High PSRR 1 Ch 500mA/1A Ultra Low Dropout LDO FUNCTIONAL DESCRIPTION MAIN FEATURES The SUL6001 series is a CMOS-based positive low-dropout linear regulator (LDO) featuring 500 mA/ 1.0A that provides high PSRR, high output voltage accuracy, low-noise and low supply current ⚫ ⚫ ⚫ It consists of a voltage reference, an error amplifier, a resistor-ladder for output voltage setting. It also has under-voltage lockout (UVLO), over current/short circuit protection circuit and over temperature shutdown circuit. ⚫ Supply Current (no load): 85μA (typ.) Supply Current (Standby): 0.1μA (typ.) Dropout Voltage: 95mV (DFN1216-8, Iout=1A, Vout=3.3V, typ.) High-PSRR: 85dB @1kHz ⚫ Output Noise: 10μVrms (10-100KHz, 0.85V ⚫ ⚫ ⚫ The SUL6001 typically has 95mV dropout voltage (DFN1216-8, Iout=1A, Vout=3.3V) and 156mA dropout voltage (DFN1216-8, Iout=1A, Vout=1.8V) and chip enable function (EN) for long battery life. ⚫ ⚫ Excellent ripple rejection, load transient and line transient response make it ideal for the power sources of mobile communication devices or camera modules in low light condition. It can also turn on under full load condition, making it suitable for harsh system environment. output voltage settings, typ.) Line Regulation: 0.01%/V Fixed Mode Voltage Range: 0.85V to 4.3V with 0.05V step. Adjustable Mode Voltage Range: 0.85V to 4.6V. Built-in Short Current Protection Limit: 120mA (LCON=’H’, 1.0A, typ.) Bulit-in Peak Current Protection Limit: 1.7A (LCON=’H’, 1.0A, typ.) ⚫ Over Temperature Protection and Auto ⚫ ⚫ Recover Built-in Soft-Start and Inrush Current Limit Fast Auto Discharge Function for Power Down APPLICATIONS The SUL6001 series LDOs have option for output current limit between 1.0A or 500mA by alternating the LCON pin between “H” or “L” ⚫ ⚫ ⚫ Portable Device , Tablets and Smartphone Cameras, VCRs and Car Dash Cameras Low Light & Low Noise Cam Application ⚫ ⚫ Communications and Infrastructure AR or VR Application for DFN1216-8 package version. 上海洺太电子科技有限公司 -1- SUNTEK MICRO LTD BLOCK DIAGRAMS DFN1216-8 (8 PIN) VIN VOUT UVLO POR VIN VREF Cc Softstart VOUT VFB Transient Enhance CE Thremal Shutdown VREF GND Current Limiter LCON SOT-89-3 (3 PIN) VIN VOUT UVLO POR VREF Cc Softstart Transient Enhance Thremal Shutdown VREF GND Current Limiter 上海洺太电子科技有限公司 -2- SUNTEK MICRO LTD SOT-89-5 (5 PIN) VIN VOUT UVLO POR VREF Cc Softstart VFB Transient Enhance CE Thremal Shutdown VREF GND Current Limiter SOT-23-5 Fixed Mode (5 PIN) VIN VOUT UVLO POR VREF Cc Softstart VFB Transient Enhance EN Thremal Shutdown VREF GND Current Limiter 上海洺太电子科技有限公司 -3- SUNTEK MICRO LTD SOT-23-5 ADJ Mode (5 PIN) VIN VOUT UVLO POR Cc Softstart VREF VFB Transient Enhance EN GND Thremal Shutdown VREF Current Limiter It is not recommended to use the 1A version of the SOT-23-5 package. Ordering Information Part Number Package Tape/Reel SUL6001S5-XX SOT23-5 3000 SUL6001T5-XX SOT89-5 1000 SUL6001D6-XX DFN2x2-6 4000 SUL6001DRB DFN3x3-8 5000 SUL6001D8-XX DFN1216-8 3000 For example, 28 means product outputs 2.8V, ADJ means adjustable. SUL6001 devices are Pb-free and RoHS compliant. 上海洺太电子科技有限公司 -4- SUNTEK MICRO LTD PACKAGE INFORMATION & PIN DESCRIPTION 上海洺太电子科技有限公司 -5- SUNTEK MICRO LTD 上海洺太电子科技有限公司 -6- SUNTEK MICRO LTD *Note: Connect exposed pad (heat sink on the back) to GND. 上海洺太电子科技有限公司 -7- SUNTEK MICRO LTD TYPICAL APPLICATION CIRCUIT A. Fixed mode example * Recommended Ceramic Capacitors for Vin and Vout: 1uF B. Adjustable (ADJ) mode example The adjustable-version device requires external feedback divider resistors to set the output voltage. VOUT is set using the feedback divider resistors, R1 and R2 , according to the following equation: VOUT = VFB × (1 + R1 / R2 ) For this device, VFB = 0.85 V. To ignore the FB pin current error term in the VOUT equation, set the feedback divider current to 100x the FB pin current listed in the Electrical Characteristics table. This setting provides the maximum feedback divider series resistance, as shown in the following equation: R1 + R2 ≤ VOUT / (IFB × 100) For this device, IFB = 10 nA. 上海洺太电子科技有限公司 -8- SUNTEK MICRO LTD ABSOLUTE MAXIMUM RATINGS RECOMMENDED OPERATING CONDITIONS ELECTROSTATIC DISCHARGE 上海洺太电子科技有限公司 -9- SUNTEK MICRO LTD THERMAL DATA ELECTRICAL CHARACTERISTICS VIN = VOUT + 1.0 V, IOUT = 1 mA, CIN = COUT = 1.0 μF, typical values are at TJ = 25 °C; unless otherwise noted. 上海洺太电子科技有限公司 - 10 - SUNTEK MICRO LTD ELECTRICAL CHARACTERISTICS (continued) *This is SUL6001D8-33 measurement data. Other PSRR information please contact SUNTEK. 上海洺太电子科技有限公司 - 11 - SUNTEK MICRO LTD Load Regulation (Dynamic) Transient recovery time Δt1 Overshoot Voltage ΔV2 VOUT Undershoot Voltage ΔV1 ILOAD Transient recovery time Δt2 上海洺太电子科技有限公司 - 12 - SUNTEK MICRO LTD *This table is SUL6001D8-33 measurement data. For detail load regulation information about other SUL6001 series LDOs, please contact SUNTEK. 上海洺太电子科技有限公司 - 13 - SUNTEK MICRO LTD FUNCTION DESCRIPTION A. Short-Circuit Protect and Current Limitation SUL6001 series LDOs can protect internal circuit under short-circuit condition on the output. When the load current increases above 1.55 A, the current limit and current foldback mechanism starts to restrict the ILIM value. If the load resistance decreases even more then the foldback, circuit starts limiting the current to 0.2 A when VOUT = 0. B. Over Temperature Protection and Auto Recover In order to prevent over thermal condition from damaging the device, SUL6001 series LDOs have internal thermal limiting functions designed to protect the device. It will rapidly shut off PMOS pass element during over temperature condition. C. Current Foldback The current limiting/ current foldback circuit plays an important role by controlling any excessive output current. Our SUL6001 series LDOs provide a current foldback circuit that can detect accurately when an over-current condition occurs. D. Very Fast Transient Response In addition to the main feedback loop, SUL6001 series LDOs contain a fast-transient loop that allows the LDO to respond faster to large-output transients. SUL6001 series LDOs that contain this loop are better able to minimize the effects of a load transient even the output capacitance is small. The recommended output capacitance value is 1μF. It’s small size greatly reduce the cost and save PCB area. E. Ultra High PSRR and Extreme Low Noise SUNTEK’s SUL6001 series high-performance LDO regulators feature remarkable power supply rejection ratio characteristics (up to 104 dB at 10 kHz) and extreme-low noise operation (as low as 6.3 µVRMS with A-wt) resulting in cleaner and stable output voltages. Our LDO is very suitable for ultra-sensitive loads like camera module and security monitor, especially in low light condition. 上海洺太电子科技有限公司 - 14 - SUNTEK MICRO LTD F. Start-Up at Full Load SUL6001 series LDOs can start-up at full load, make it very suitable for heavy load start up condition and severe system timing constraint. G. Auto Discharge Function SUL6001 series LDOs have an auto discharge function to quickly force the output voltage to zero. When the LDO is disabled, the auto discharge function quickly discharge the output capacitor, thereby reducing the output voltage to nearly zero. This function is very useful for quickly ON/OFF application. H. Low Quiescent Current SUL6001 series LDOs consume only 85μA (typical) while operating with no load condition. By reducing the quiescent current, your application can stay in standby/sleep mode much longer than leading low quiescent current LDOs in the market. I. Uuder Voltage Lock OUT (UVLO) SUL6001 has an undervoltage lockout (UVLO) function to make sure that whole circuit does nothing until the power supply voltage is high enough. When power supply voltage is high enough, reference circuit can generate right voltage ; logic function can generate correct control signals. This UVLO function can guarantee robust system performance. 上海洺太电子科技有限公司 - 15 - SUNTEK MICRO LTD TYPICAL CHARACTERISTICS VIN = VSET(1) + 1.0 V, IOUT = 1 mA, CIN = COUT = 1.0 μF, LCON=’H’, typical values are at TJ = 25 °C; unless otherwise noted. Output Voltage vs. Input Voltage (CIN = COUT=1.0μF, Ta= 25 °C ) SUL6001D8-33 3.5 1 3 Output Voltage VOUT (V) Output Voltage VOUT (V) SUL6001D8-12 1.2 0.8 0.6 1 mA 0.4 50mA 0.2 100mA 0 0 1 2 3 4 2.5 2 50mA 1 100mA 0.5 0 5 1 mA 1.5 0 1 Input Voltage VIN (V) 2 3 4 5 Input Voltage VIN (V) Supply Current vs. Input Voltage (CIN = COUT = 1.0μF, Ta= 25 °C ) 100 100 90 90 80 80 Quiescent Current IQ (μA) Quiescent Current IQ (μA) SUL6001D8-12 SUL6001D8-090 70 60 50 40 30 20 10 0 0 1 2 3 4 5 Input Voltage VIN (V) 上海洺太电子科技有限公司 70 60 50 40 30 20 10 0 0 1 2 3 4 5 Input Voltage VIN (V) - 16 - SUNTEK MICRO LTD SUL6001D8-18 90 90 80 80 70 60 50 40 30 20 10 0 0 1 2 SUL6001D8-33 100 Quiescent Current IQ (μA) Quiescent Current IQ (μA) 100 3 4 5 70 60 50 40 30 20 10 0 0 1 2 3 4 5 Input Voltage VIN (V) Input Voltage VIN (V) Supply Current vs. Temperature (CIN = COUT = 1.0μF, IOUT= 0 mA ) SUL6001D8-12 Quiescent Current IQ (μA) 105 100 95 90 85 80 -20 0 20 40 60 80 100 120 Temperature TA (℃) 上海洺太电子科技有限公司 - 17 - SUNTEK MICRO LTD Over Current Protect Foldback Characteristic (LCON = VIN, CIN = COUT = 1.0 μF, Ta = 25°C) SUL6001D8-090 SUL6001D8-12 SUL6001D8-18 SUL6001D8-25 SUL6001D8-33 SUL6001D8-43 上海洺太电子科技有限公司 - 18 - SUNTEK MICRO LTD Output Noise Voltage (10 Hz to 100 kHz, CIN = COUT = 1.0 μF, Ta = 25°C) SUL6001D8-090, IOUT = 100 mA Amplitude Spectral Density VRMS from 10 Hz to 100 kHz SUL6001D8-12, IOUT = 100 mA Amplitude Spectral Density 上海洺太电子科技有限公司 VRMS from 10 Hz to 100 kHz - 19 - SUNTEK MICRO LTD SUL6001D8-33, IOUT = 100 mA Amplitude Spectral Density 上海洺太电子科技有限公司 VRMS from 10 Hz to 100 kHz - 20 - SUNTEK MICRO LTD Power Supply Ripple Rejection vs. Frequency (VIN=VOUT+1V , CIN = COUT = 1.0 μF, Ripple = 0.2 Vp-p, Ta = 25°C) SUL6001D8-090 ILoad=1mA I Load=10mA ILoad=30mA I Load=150mA 上海洺太电子科技有限公司 - 21 - SUNTEK MICRO LTD SUL6001D8-12 ILoad=1mA I Load=10mA ILoad=30mA I Load=150mA 上海洺太电子科技有限公司 - 22 - SUNTEK MICRO LTD SUL6001D8-18 ILoad=1mA I Load=10mA ILoad=30mA I Load=150mA 上海洺太电子科技有限公司 - 23 - SUNTEK MICRO LTD SUL6001D8-25 ILoad=1mA I Load=10mA ILoad=30mA I Load=150mA 上海洺太电子科技有限公司 - 24 - SUNTEK MICRO LTD SUL6001D8-33 ILoad=1mA I Load=10mA ILoad=30mA I Load=150mA 上海洺太电子科技有限公司 - 25 - SUNTEK MICRO LTD SUL6001D8-43 ILoad=1mA I Load=10mA ILoad=30mA I Load=150mA 上海洺太电子科技有限公司 - 26 - SUNTEK MICRO LTD Load Transient Response (VIN=VOUT+1V, CIN = COUT = 1.0 μF, tr = tf = 1 μs, Ta = 25°C) SUL6001D8-090 1mA -> 250mA 1mA -> 1000mA 1mA -> 500mA 0mA -> 300mA 0mA -> 1000mA 上海洺太电子科技有限公司 - 27 - SUNTEK MICRO LTD SUL6001D8-12 1mA -> 250mA 1mA -> 1000mA 1mA -> 500mA 0mA -> 300mA 0mA -> 1000mA 上海洺太电子科技有限公司 - 28 - SUNTEK MICRO LTD SUL6001D8-18 1mA -> 250mA 1mA -> 1000mA 1mA -> 500mA 0mA -> 300mA 0mA -> 1000mA 上海洺太电子科技有限公司 - 29 - SUNTEK MICRO LTD SUL6001D8-25 1mA -> 250mA 1mA -> 500mA 1mA -> 1000mA 0mA -> 300mA 0mA -> 1000mA 上海洺太电子科技有限公司 - 30 - SUNTEK MICRO LTD SUL6001D8-33 1mA -> 250mA 1mA -> 1000mA 1mA -> 500mA 0mA -> 300mA 0mA -> 1000mA 上海洺太电子科技有限公司 - 31 - SUNTEK MICRO LTD SUL6001D8-43 1mA -> 250mA 1mA -> 1000mA 1mA -> 500mA 0mA -> 300mA 0mA -> 1000mA 上海洺太电子科技有限公司 - 32 - SUNTEK MICRO LTD Turn-on waveform by VIN & CE @ light load (VIN = CE = 0 V to VOUT+1V, CIN = COUT = 1.0 μF, Ta = 25°C, IOUT = 1 mA) SUL6001D8-090 SUL6001D8-12 SUL6001D8-18 SUL6001D8-25 SUL6001D8-43 SUL6001D8-33 上海洺太电子科技有限公司 - 33 - SUNTEK MICRO LTD Turn-on waveform by VIN & CE @ full load (VIN = CE = 0 V to VOUT+1V, CIN = COUT = 1.0 μF, Ta = 25°C, IOUT=1A) SUL6001D8-090 SUL6001D8-12 SUL6001D8-25 SUL6001D8-18 SUL6001D8-43 SUL6001D8-33 上海洺太电子科技有限公司 - 34 - SUNTEK MICRO LTD Turn-on by CE pin & Inrush current @ no load (VIN = VOUT+1V, CE = 0V to 1V, CIN = COUT = 1.0 μF, Ta = 25°C, IOUT=0 mA) SUL6001D8-12 SUL6001D8-09 SUL6001D8-18 SUL6001D8-25 SUL6001D8-33 SUL6001D8-43 上海洺太电子科技有限公司 - 35 - SUNTEK MICRO LTD � SUNTEK Turn-on by CE pin @ full load (VIN = VOUT+1V , CE = 0V to 1V, CIN = COUT = 1.0 μF, Ta = 25°C, IOUT=1A) SUL6001D8-090 SUL6001D8-18 SUL6001D8-33 上海洺太电子科技有限公司 SUL6001D8-12 SUL6001D8-25 SUL6001D8-43 - 36 - SUNTEK MICRO LTD DFN1216-8 Package Information 上海洺太电子科技有限公司 - 37 - SUNTEK MICRO LTD SOT-23-5 Package Information NOTES: 1. 2. 3. 4. All dimensions refer to standard. Dimensions D does not include mold FLASH. Dimensions E1 does not include mold FLASH. FLASH or protrusion shall not exceed 0.25mm per side. 上海洺太电子科技有限公司 - 38 - SUNTEK MICRO LTD SOT-89-5 Package Information 上海洺太电子科技有限公司 - 39 - SUNTEK MICRO LTD DFN2020-6 Package Information 上海洺太电子科技有限公司 - 40 - SUNTEK MICRO LTD DFN3030-8 Package Information 上海洺太电子科技有限公司 - 41 - SUNTEK MICRO LTD
SUL6001S5-ADJ 价格&库存
很抱歉,暂时无法提供与“SUL6001S5-ADJ”相匹配的价格&库存,您可以联系我们找货
