2A07G-T A0G
2A07G-T A0G
    TAIWANSEMICONDUCTOR(台半)
    DO-15(DO-204AC)
    二极管配置:-;直流反向耐压(Vr):1kV;平均整流电流(Io):2A;正向压降(Vf):1V@2A;
2A07G-T A0G 数据手册
4 2A01G-T - 2A07G-T Taiwan Semiconductor 2A, 50V - 1000V Glass Passivated Rectifier FEATURES KEY PARAMETERS ● ● ● ● ● ● Glass passivated chip junction High efficiency, Low VF High current capability High surge current capability Low power loss Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF(AV) 2 A VRRM 50 - 1000 V IFSM 70 A TJ MAX 150 °C Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters TV Monitor MECHANICAL DATA ● Case: DO-204AC (DO-15) ● Molding compound meets UL 94V-0 flammability rating ● Packing code with suffix "G" means green compound (halogen-free) ● Terminal: Pure tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 1A whisker test ● Polarity: As marked ● Weight: 0.4 g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode Junction temperature Storage temperature 2A01 2A02 2A03 2A04 2A05 2A06 2A07 G-T 2A01G G-T 2A02G G-T 2A03G G-T 2A04G G-T 2A05G G-T 2A06G G-T 2A07G VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V SYMBOL UNIT IF(AV) 2 A IFSM 70 A TJ - 55 to +150 °C TSTG - 55 to +150 °C 1 Version:A1703 4 2A01G-T - 2A07G-T Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL LIMIT UNIT Junction-to-case thermal resistance RӨJC 22 °C/W Junction-to- ambient thermal resistance RӨJA 60 °C/W Junction-to-lead thermal resistance RӨJL 25 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR per diode 2A01G-T 2A02G-T 2A03G-T 2A04G-T 2A05G-T 2A06G-T 2A07G-T IF = 2A,TJ = 25°C (2) TJ = 25°C Junction capacitance Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms TJ = 125°C 1 MHz, VR=4.0V SYMBOL TYP MAX UNIT - 1.1 V - 1.0 V - 5 µA - 100 µA 15 - pF VF IR CJ ORDERING INFORMATION PART NO. 2A0xG-T (Note 1, 2) PACKING PACKING CODE CODE SUFFIX A0 R0 B0 G PACKAGE PACKING DO-15 DO-15 DO-15 1,500 / Ammo box 3,500 / 13" Paper reel 1,000 / Bulk packing Notes: 1. "x" defines voltage from 50V (2A01G-T) to 1000V (2A07G-T) 2. Whole series with green compound (halogen-free) EXAMPLE P/N EXAMPLE P/N PART NO. PACKING CODE 2A01G-T A0G 2A01G-T A0 2 PACKING CODE SUFFIX G DESCRIPTION Green compound Version:A1703 4 2A01G-T - 2A07G-T Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 2 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 3 1 10 f=1.0MHz Vsig=50mVp-p 0 0 50 100 1 150 0.1 1 AMBIENT TEMPERATURE(oC) TJ=125℃ 1 TJ=75℃ 0.1 TJ=25℃ 0.01 20 40 60 80 100 120 10 10 1 TJ=125°C 1 TJ=25°C 0.1 2A03G-T - 2A07G-T 0.01 Pulse width 0.001 0.3 0.1 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) UF1DLW 2A01G-T - 2A02G-T (A) 100 0 100 Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) 0.4 0.5 0.8 0.6 0.7 0.8 1 0.9 1.2 1 1.1 1.4 FORWARD VOLTAGE (V) 3 Version:A1703 1.2 4 2A01G-T - 2A07G-T Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) PEAK FORWARD SURGE CURRENT(A) Fig5. Maximum Forward Surge Current 70 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version:A1703 4 2A01G-T - 2A07G-T Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) DIM. Unit (mm) Unit (inch) Min Max Min Max A 2.60 3.60 0.102 0.142 B 0.70 0.90 0.028 0.035 C 25.40 - 1.000 - D 5.80 7.60 0.228 0.299 E 25.40 - 1.000 - MARKING DIAGRAM P/N G YWW F 5 = Marking Code = Green Compound = Date Code = Factory Code Version:A1703 4 2A01G-T - 2A07G-T Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version:A1703
2A07G-T A0G 价格&库存
很抱歉,暂时无法提供与“2A07G-T A0G”相匹配的价格&库存,您可以联系我们找货
